Question about Watches
JSprings Movement, Seiko VF62, battery change
Hi I have replaced a similar J-Springs battery but was baffled by the label on the inside of the watch back "after installing the battery, be sure to short + on battery with 'Area AC" - I do understand the principle but where, or what, is 'Area AC' please? Your advice would be appreciated.
  • Watches Master
  • 18,394 Answers
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.
Posted on Jan 23, 2013
  • 29 Answers
SOURCE: Opening back of watch for battery replacement
Turn the watch sideways & look around the edges of the back of the watch. You may have to use a magnifier to do this. Look for an area that has a gap. Put the knife there & pry it open. Hope this helps.
Posted on Mar 01, 2008
SOURCE: Replaced battery, now no beep.
I have a Timex Digital Heart Rate Monitor 585 (product code T5C351F5)m, which has the same Short AC Pad and battery +ve message. There is an arrowhead pointing to the pad. It's a raised metal platform - a bit different to some of the Ironman's mentioned above. Here is a pic...6e1fe0e.jpg
Posted on Jul 06, 2008
SOURCE: I am trying to change
I have a similar model.  The electronics sometimes needs to be reset after the battery is changes.  Get a magnifying glass and look closely at the stainless frame around the battery.  There is a small AC mark and a triangle which points toward a small gold contact down in an adjacent hole.  This contact must be shorted momentarily to the + side of the battery to reset the display.  You can bend a metal paper clip to make the connection.  You may have to try several times before it resets. It should reset to 12:00 and start running.
Posted on May 20, 2009
  • 12 Answers
SOURCE: how to remove back for battery replacement - 19
This is a little tricky, I think this has a screw on back. It takes a two or better a three prong tool to remove back. A new seal shoud be on hand to replace this. Watch should have a consumption test and a min run voltage test, if either of these fail a new circuit board or movement should be installed. Take it to a good watchmaker and they will clean the outside before opening and do a water resistance test after assembly.
Posted on Jun 14, 2009
SOURCE: reset timer after battery change in seiko sna285
If the stop watch hands are not in the "0" (12 o clock) Position, follow the prodedure below to set them to the 12 o Clock position
1, Pull the crown to secound position
2, Press Button "A" for 2 seconds.
3, Press Button "B" to Adjust the minute Hand to "0" Position
4, Press Button "A" for 2 secounds then press Button "B" to adjust secound hand to "0" Position
5, Press crown into normal position
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Posted on Aug 28, 2009
Is there a way to get seiko to repair my 7N43-8A38 "A1" Watch?
If it has a battery op movement you could have a non original batt op movt installed for 15 bucks and it will work like new but if it is a mechanical movement then you will have to replace necessary damaged parts
Feb 01, 2015 | Seiko Watches
Hi, I am a seiko 8f33 perpetual calendar watch. I just got it back from Seiko...had the battery changed and new band. the problem is that I tried to set the date and the watch stopped working. Does...
If your watch stopped working while changing the time it can be for a couple of reason . One is i never set the watch between the hours of 11 pm and 4 am or else your movement can be damaged. The main reason is usually that the watch crown was not pushed all the way in to the first set . If the watch crown and stem is pulled out and not in the start position the watch will not run. Also after setting time you might need to reengage the watch by pressing on the jumper buttons on the top side of the crown they look like push buttons.
Oct 17, 2010 | Seiko SKA192 Wrist Watch
Need owners manual for Seiko Quartz Chronograph Sports 150
I feel sure that Seiko will have a copy of the instructions in their archive, so if you contact them they should be able to send you a copy.
(Either that or advise you which watch has similar instructions).
May 31, 2010 | Watches
Seiko watch ser#687612,need a new battery,need to know which one
Hi there, can you look on the back of the watch for the model number. It should be similar to 7T62-0AC0 - I can then tell you which battery you require -
May 11, 2010 | Seiko SNA413 Wrist Watch
My watch has had the battery changed and when you reset the stopwatch, the second hand and the small hour/minute hands no longer rests on 12. How do I reset these hands
I have the same problem with my Seiko Coutura Chronograph. Ever since battery was changed, the stopwatch resets to 32' 8" instead of 0'0". How to re-zero the hands?
May 08, 2010 | Watches
Can I use an ordinary button cell in a seiko kinetic
I have been trained by a Master watch maker and I have worked on many Seiko Kinetic watches. Yes the original watches came with a capacitor that is charged by your arm movement. But unfortunately, they seem to only last a few years. All replacements are now done with a Lithium Ion battery that is much better and lasts longer than the original capacitor. This is the correct solution and don't try to use a battery type that is used in other quartz watches.
Oct 01, 2009 | Seiko Kinetic watch
My seiko kenetic watch stopped, and will not say wound
I thing required cleaning for the movement and new capacitor.
Chicago, IL 60601
Ph: 312 641 7000
Sep 24, 2009 | Seiko Kinetic watch
My seiko stops overnight but works during the day
if the watch is solar power it may not be getting enough to last through the night. if it is battery powered it may just be stuck when in certin postion like upside down or somthing
Jun 03, 2009 | Seiko Kinetic watch
Time keeping
Hi suliva,
If you check the manual of the watch you will see that error of these watches is +-15sec/month (depends on the movement and temperature of operation that you have) which brings your error inside the range. Don't worry. If you keep your watch around 28oC it will have min. error.
Cheers,
RzA
May 28, 2009 | Seiko Chronograph SNAA61 Gents Watch
Seiko Chronograph 7T32 minute hand inactive after battery replace
you often need to do a full reset on 7T32s (& other seikos) after a battery change. there is a small reset contact in the rear of the movement which needs to be shorted to the top of the battery (the movement is engraved with wording to this effect, something like "AC reset", I can't remember exactly). you might also try pulling out the crown all the way (2 clicks) then holding both upper pushers in for a few seconds. it's unlikely to be a buggered motor unless it's one of the subdials that's failed.
hth-
duncan.
Feb 20, 2009 | Seiko Le Grand Sport SDWF73 Wrist Watch
Watches Logo
148 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
