Question about HP Laserjet M2727nf Multifunction Printer
Our printer thinks it is out of paper and you have to hit ok all the time
What could cause this error, the paper tray is full.
  • kballew12 Jan 22, 2013
    Thank you for responding, there isn't a paperjam at all. It just starts blinking and stating pap is not full you hit ok and it starts prininting again.
SOURCE: Out of Paper. Load Paper Error
I have the same problem with a new psc 1610. The paper is not grabbed. Their might be a sticky spray for the rubber rollers to help? Handfeeding each page currently (sigh). All else works well though. good luck.
Posted on Jun 25, 2007
Inkworks
  • 87 Answers
SOURCE: Keep getting "out of paper" error message
Unfortunately this printer and alot of others like it have a very poor paper feed mechanism. I am finding that the (1) small pickup roller that is used in this and other machines like it is failing (not picking paper) prematurely or faster than i think it should (this is looking at page counts on some of these machines). We have been disassembling them and rubber restoring the pickup roller which fixes the paper jam/paper out errors.
Inkworks
Posted on May 21, 2008
  • 3422 Answers
SOURCE: hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Jun 18, 2008
SOURCE: Printer will not print
I had the same problem and to fix it there was a blue tray I had to pull out (the tray for the photopaper). Once it was pulled out so it was about flush with grey part beside it, the printer worked again. (The photopaper tray is just above where you put the regular paper.)
Posted on Mar 26, 2009
shadiabed
  • 72 Answers
SOURCE: Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Posted on Jan 08, 2010
Jan 08, 2010 | HP LaserJet 3800n Printer
My printer Lexmark T634 is showing "remove paper standard bin"
What your printer is telling you is that it thinks or knows that the top exit tray for the paper is full. This is the tray that is moulded into the top of the printer.
This caused by two things. It is actually full or the Bin Full Actuator is out of position and forcing the error condition.
Look at the standard bin. Over to the top at the top left corner there should be finger (almost the same as paper clip) hanging down. If it is not there, then it is more then likely that the finger is jammed up.
Don
Nov 04, 2009 | Lexmark T634 Laser Printer
Error states that paper needs to be loaded... gives me an option to Bypass or from Tray... does it every time. Loads it find when I push the feed but I have to do it every time. Why is it doing this and...
Bad sensor and/or actuator in the paper tray. We see it all the time and it usually happens when users add more paper. The tray gets caught on the actuator and snaps. Or the tray is put back in too harshly and causes the actuator to punch the sensor out of place.
Oct 05, 2009 | Ricoh Aficio CL3500N Laser Printer
HP C6150 All in one won't feed paper from main tray.
I did fix it. Please sign up for my Premium Assistance Plan to find out how!!!!!!
Feb 08, 2009 | HP Office Equipment & Supplies
PIXMA ip8500 not printing
i have a pixma ip4300 i keep getting the error number 1250 "paper output try is closed" but infact its is open i have tried opening and closing and restarting and everything else i can think of. any ideas of what to do?
Jun 23, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Out of paper indicator is always on
try to take out some paper, maybe the stack i too high/tight. check if there's an obstruction on the paper tray... i had this issue just last week, where a student place a bracelet in the paper tray and the roller can't pickup the paper.
Jun 02, 2008 | HP Photosmart C3180 All-In-One InkJet...
Konica 7155 Main Error Code : 74 ,printer stops for no reason
There are a few code 74's, and Konica has a bulletins on them.
DESCRIPTION: Code 74-0 from the E-mail alert system. SOLUTION ID: 154045
SOLUTION: CAUSE: Paper remains at finisher main tray paper exit opening.
DESCRIPTION: Code 74-1 from the E-mail alert system. SOLUTION ID: 154055
SOLUTION: CAUSE: Booklet tray is full.
SOLUTION: Remove the paper from bottom exit of the finisher.
DESCRIPTION: Code 74-4 from the E-mail alert system. SOLUTION ID: 154058
SOLUTION: CAUSE: Paper remains inside finisher.
SOLUTION: Please remove copies from the finisher.
DESCRIPTION: Code 74-5 from the E-mail alert system. SOLUTION ID: 154059
SOLUTION: CAUSE: Punch trash box is full.
SOLUTION: Trash basket of punching unit is full. Please empty trash basket.
DESCRIPTION: Code 74-6 from the E-mail alert system. SOLUTION ID: 154066
SOLUTION: CAUSE: Sub-tray (first tray) is full.
SOLUTION: Sub tray is full. Please remove paper.
I'm guessing it just means the finisher thinks it's full, and wants you to take the copies / prints out.
Apr 23, 2008 | Office Equipment & Supplies
Epson AcuLaser C900 Printer
Error Code 6001 ~ 6999 are simply service required errors and are very general. I would imagine that if the tray is missing the printer will produce a fault. For starters it will think it has no paper and therefore will not try to pick up paper from the tray. If the tray is opened during operation I believe the printer stops, therefore there must be a sensor for the tray - no tray means sensor is operated. Best guess - fit a tray.
Apr 07, 2007 | Epson AcuLaser C900 Printer
Clicking Noise
Go to: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00587637&lc=en&cc=us&dlc=en&product=439488&rule=44236&lang=en and I think you'll find what you need to solve the problem. often this type of error is caused by trying to clear a paper jam by pulling it out the wrong way, one or two of the gears slip and everything gets out of sync. If you can't solve your problem with the HP troubleshooter, please ask again and I can try and talk you through the resetting process. Hope this helps:)
Feb 27, 2007 | HP Photosmart 3210 Printer
HP Laserjet M2727nf Multifunction Printer Logo
93 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
