Question about Brother SE-270D Computerized Sewing Machine
How can I place the shuttle back in correctly on a Brother UTL 2003
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Brother Expert
  • 300 Answers
You probably mean the bobbin case, (the black part that the bobbin goes into). It shows you in the instruction book.
Posted on Feb 26, 2013
How do i put the shuttle back correctly to stop needle hitting shuttle
If you are inserting the shuttle and locking it in place but the needle continues to hit, the needle may be bent. If a new needle is installed and it continues to hit, most likely the needle/hook timing is off. Take it for service.
Feb 23, 2016 | Sewing Machines
MY THREAD GETTING WRAPPED AROUND THE BOBBING WHEN TRYING TO SEW THE TOP THREAD WRAPPING AROUND THE BOBBING CASE AND DRAGGING CAUSING THE TOP THREAD TO BREAK ?
It sounds like the lower shuttle is out of place. You should be able to take out the bobbin case and unlatch the shuttle. It will probably be in 2 pieces. Clean out the dust behind it and replace the shuttle pieces. You may have to fiddle with it a little to get them back in place. Then you can test it by manually turning the wheel. Make sure the bobbin is placed into the bobbin case and that the bobbin turns in the direction that you pull the thread.
Good luck.
Nov 11, 2014 | Brother Disney PE-180D Computerized Sewing...
Plastic shuttle not slotting into brother XL-2220
Look in your book or download one for the XL2230 (nearly the same as the XL2220) here:
http://www.brother-usa.com/VirData/Content/en-US%5CHAD%5CConsumer%5CUsersManual%5CUM_XL_2230_EN_205.PDF
Apr 07, 2014 | Brother XL-3510 Mechanical Sewing Machine
Shuttle on a Brother VX-1120 sewing machine will not pick up the bobbin thread
Bobbin in backwards, needle in backwards, needle damaged, needle too small for the thickness of fabric or needle not the correct needle system for the machine are my first guesses. Try a new size 12/80 needle, flat of the needle to the back of the machine, completely up in the needle clamp as a first pass at the problem.
Feb 18, 2014 | Brother Sewing Machines
Brother XL-2022 Bobbin Problem
Removable parts are the race and bobbin case.
Raise the needle to it's at the highest position and set the race hook into the shuttle so the hook is at the lower left.
Re-place the hook race cover and move the levers or pegs to hold the cover in place.
Apr 18, 2010 | Sewing Machines
Bobbin thread won't engage.
The bobbin case is not in the shuttle.
Raise the needle to it's highest position.
Lift the lever on the back of the bobbin case and hold it open as you insert the case into the shuttle; arm on the case pointing up. You may have to turn a bit to the left or right - it will click when in place.
Mar 20, 2010 | Brother CS-8072 Computerized Sewing...
Brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Feb 04, 2010 | Brother SE-270D Computerized Sewing...
My machine is a Brother XL5600; I think I am having a shuttle hook problem. When I lower the sewing needle to "catch" the bobbin thread and pull through- it won't catch and pull through. I have changed out...
Hi
Thanks for using FixYa. The upper thread could be tangled. Remove the thread completely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine according to the directions in the manual.
Place a spool of thread on a spool pin and check the upper threading.
Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
Also please check that the bobbin is installed in its case rightly. Needle thread is too tight. Hold the thread lightly to keep the end from going down into the shuttle.
The needle could be thread incorrectly. Thread the needle eye from the front to the back.
The needle could be bent or improperly inserted and install a new needle with the flat side of the needle facing the back.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | Brother LS-2125 Mechanical Sewing Machine
Cannot get the shuttle race and bobbin case in properly. It keeps falling out, and the foot will not go into the notch.
Will the shuttle lock in place without a bobbin inside?  If it does, look for thread in there, wrong bobbin, etc.  If it doesn't, maybe the shuttle is bent?  Really hard to tell without seeing it...  Hope this helps.
Jul 14, 2009 | Brother Sewing Machines
Corect threading needle for sewing on brother lx3125
please follow the instruction
1. raise needle to its hieghest position
2. remove hand hole cover plate
3. remove bobbin case from shuttle, pull open latch of bobbin case
4. pull bobbin case straight out of shuttle
5 insert bobbin into bobbin case making sure thread is coming from bobbin.
6. pull thread through slot
7. pull thread under tension spring
8. holding latch open position case into shuttle, and release latch. case should lock into place when latch is released
happy sewing.
regards please rated me.. thanks
Mar 31, 2009 | Brother Sewing Machines
Brother SE-270D Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
