Question about Kenmore Washing Machines
Kenmore washer model 110.21102011
The machine try's to start up but it will not fill up with water. The lid light blinks. The motor sounds like it wants to start but will not work
3 Suggested Answers
ned_san_jose
  • 234 Answers
SOURCE: Kenmore 90 Series fills with water but would not agitate or spin
You have a problem with the motor coupling. Top-load washers use what's called a direct-drive system, meaning it does not use a belt but what's called a "motor coupling". I probably replace 5 a week because these little guys break because of 2 reasons that i've found.
1) The break mechanism is too dry and causing the basket to stop at a holt, which puts a lot of strain on the coupler.
2) They break because of over-loading. I don't think you're over-loading though because it was find for 5 straight years.
Good luck to you. The repair is kind of hard to do on your own for the first time, so I would call an authorized technician. It will run you anywhere between $90 to $120 at most.
Best of luck!
Posted on Jul 16, 2009
  • 56 Answers
SOURCE: Washing machine wont work at all
Obviously the first thing to check is that the socket is supplying power by plugging another appliance in such as a lamp. It is less likely to be the socket but you'd be daft not to check it out before calling an engineer as it does occasionally turn out to be a faulty wall socket. This is only necessary though if there are no led indicator lights lit up on your washer as any light that's on shows that the machine is getting a live and neutral supply from the socket.
The second thing to check is the fuse in the plug. Either put the fuse into something else and check the appliance still works or try another fuse that you know to be OK in the washer. Make sure you use a 13 amp fuse and never by-pass a fuse! If both of those are OK, then the most common cause for a washing machine that wont start is the door interlock, particularly if the mains lights on the washing machine has come on, but nothing works. However, the fault could also be in wiring to the door interlock or even the door catch not activating it properly, or the on off switch or the main control module. With some Indesit and Hotpoint washing machines even an open circuit heater or motor can cause the entire washing machine to stop working except the led lights.
You need to know what you are doing to trace this type of fault so if it isn't the wall socket or the plug you'd be better getting an engineer to trace it. Do not work on a live washing machine. Engineers should use a continuity test meter to trace faults with the washing machine unplugged and never test with a live washing machine.
Posted on Mar 19, 2010
Fills up with water, wont wash, drum motors works
Sounds as if this computer is trying to display an error code. If switching cycles manually makes it work, then it is most likely a bad circuit board. Try doing a google search for "Kenmore washer lights blinking" or something to that effect.
Jan 30, 2013 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
Please help me fix or get started my kenmore top loading washing machine
what's wrong with it?did it fill with water and then nothing or do you hear the motor running but no aggitation,what is it doing?the most common problems with kenmore washers is usually the lid switch breaks or the motor coupling breaks.http://www.youtube.com/watch?v=MFsvLiuTniU copy and paste and it will show you how to change the lid switch.that part number might not be the right one for your model,you'llneed to give the parts store the model number and it will start with 110.it's under the lid when it's open,http://www.youtube.com/watch?v=9K1KHEogf3c&feature=relmfu this is for the motor coupling,hope one of these is your problem,next time send the model number and more info on what problems you're having with the machine.
Oct 19, 2011 | Washing Machines
Will not wash or spin
the two most common things are a broken lid switch or motor coupling,if you can hear the motor running but nothing else is happening you have a broken motor coupling,if it filled with water and then nothing check the lid switch,close the lid and then open it a few inches,open and close it like this a few times,if you don't hear a clicking sound when the lid opens and closes then the lid switch is bad.next time send the model number off of the washer,it will start with 110. or similar. http://www.youtube.com/watch?v=MFsvLiuTniU this will help you with the lid switch but the part number could be wrong,when you call your parts store give them the model number and you'll find it right under the bottom of the lid when it's open.http://www.youtube.com/watch?v=9K1KHEogf3c copy and paste for the motor coupling,good lick and hope this helps
Oct 15, 2011 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore washer model #110.20022011. The other day it did not spin out all the way, now it will not start at all. The fill light and lid lock light comes on, but it does not start. Water and...
A friend of mine bought a Kenmore washer model 110.20022013 a year ago. Now washer stopped in the middle of washing and a clicking sound starts, and not washing or rinse or draining
Aug 22, 2011 | Kenmore Washing Machines
MY WASHER FILLED UP WITH WATER, BUT THEN IT JUST QUIT WORKING.
I believe it is your lid switch. I have replaced 3 this week. If you get me the model number i can tell you for sure. Another thing that caused this is the motor to go bad. Do you smell a burning smell when it is trying to run after the fill up? If not get me the model number and i will get you the part number for the lid switch.
Nov 21, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
500 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
