Question about Sony Mdr-ds6500 Ds6500 7.1 Surround Sound Headphones
Time delay issues with wireless headphones
All my old ones worked fine without and echo when TV speakers are on at the same time I listened with headphones. Turning of the TV speakers are not an option since My wife and I watch TV together. I need the headphones because of severe hearing loss. I tries both the analog input and optical input; they both have the annoying echo.
3 Suggested Answers
SOURCE: can these be hooked up so you can hear the tv external speakers as well?
I have the headset running through an amplifier so my wife can listen at her volume level and I can adjust the headset volume for myself. The volume dial on the amp is set to zero; but the audio output jacks still provide plenty of volume to the headset. You can get a reasonable amplified for $100 or less
Posted on Aug 08, 2008
  • 11800 Answers
SOURCE: New Sony MDR-DS6500 wireless headphones.
Simple test to see if the unit is functional: get a cable like
http://www.amazon.com/3-5mm-Stereo-Male-Cable-ft/dp/B002T4OMG8
plug it in the headphones output from your pc or whatever device which you know it works since you are using it with other regular headphones (even a phone will do) and see if you hear something. If you don't then it's defective, if you hear then the problem is with your HT.
The biggest one is the fact that the only way in which this HT is capable of delivering sound to another unit is thru the wireless S-Air connection which the wireless module from the headphones doesn't support - it can connect strictly only to the module from its base which accepts only cabled connections, which your HT doesn't have..
To put it simply there is no way to connect this headphones to this HT. If you want to use those headphones you will need to get a real receiver and use this HT strictly as an BR player.
Posted on Sep 11, 2011
I have a lg tv and we bought headphones to listen without bothering anyone else. however I used headphones last nite and unplugged from back of tv and now I cannot get sound on my tv (ONLY SOUND THROU
Simply click on your menu button, goto Audio, notice the TV speakers switched to off? Sometimes the TV won't switch it back. Problem Solved. Goodnight
Jan 18, 2015 | LG Televison & Video
Pioneer VSX-456 headphone jack problem
No the headphone jack doesn't disable the speakers. There are two switches in the lower middle of the receiver that are labeled speaker A and B. Pushing one of these should disconnect the speakers from the receiver.
Feb 16, 2014 | Audio Players & Recorders
Echo through speakers
Unintended reverberation, or "echoing," from your computer speakers is a common problem that can arise from improper setup of your audio properties.
Resetting all of your audio information to default will correct this problem, allowing you another chance to strike a good balance to satisfy your audio tastes.
This can be accomplished by accessing the Sounds menu in your operating system.
Select the "Start" menu from the bottom-left corner of your screen, and click on "Control Panel." Find the "hardware and Sound" button and click to select.
Click on the sound icon and select the third tab labeled "Sounds" in the window that appears. A list of sounds will appear, beginning with "Asterisk." Click on a sound to highlight and select test.
Listen to hear if the echoing problem occurs.
If it does, you need to configure your speakers or check to see if it is a third-party issue.
Select the first tab labeled "Playback" from the same window. Right-click on the "Speakers" icon. Click on "Configure Speakers" from the top of the list.
Choose a setup from the list that appears and select test to test different sound configurations for the speakers.
Listen to decipher if one configuration has less echo than another. If so, choose the speaker configuration without the echo to fix the problem.
However, if none of the configurations remove the echo, you need to attempt to troubleshoot the issue from "Safe Mode."
Turn on your computer if it is off or restart your computer. Continuously press the "F8" key until the "Advance Boot Options" screen appears.
Use your arrow keys to navigate the screen, pressing down until you have highlighted the "Safe Mode" option. Hit "Enter" to select. Wait for the drivers to load.
Log on from the "Administrator" account. Test the sounds again, and if the echo does not occur, the cause is a third-party driver or service.
hope this helps
Sep 15, 2012 | ASUS Computers & Internet
When i connected the 5.1 home theatre to the LCD tv, there is a lag between the sound from tv and stereo system (just like echo).
That is very common because of video processing delay. You have to listen with either TV speakers or surround sound; but not both. Some TVs have an audion delay adjustment for TV speaker sync.
Apr 19, 2010 | Televison & Video
The sounds is making an echo when it gets to loud
As long as these headphones are not the wireless type. Then your problem sounds like the earth connection has become detached. Perhaps at the plug/jack end. If you can't solve it cut the ******** and fit a new one.
Jan 30, 2010 | Sony MDR-XD200 Consumer Headphones
My headphones connect with the adapter, the blue light is on on both but nothing comes from the ipod. I have performed the factory reset but it still doesn't work. The headphones had worked fine and then...
I have same issue....just took my transmitter apart - the wires connecting the male jack to the silicon board are frayed, disconnected.....you might check that...it's only 2 small screws holding the outercase together....be careful though
Jul 07, 2009 | Logitech Bluetooth Wireless Headphones
System echos when dvd is in. When I mute the Bose sytem I can hear the TV sound without the echo.
The echo you hear is the audio delay between your TV speakers and Bose speakers. Muting (or lowering the volume) on the TV will eliminate the echo. Some TVs have a setting to turn of TV speakers entirely, allowing you to listen to your TVs audio strictly through your Bose system.
Dec 20, 2008 | Bose 3·2·1 II System
Sony Mdr-ds6500 Ds6500 7.1 Surround Sound Headphones Logo
241 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
