Question about Fusion FEW12PK Car Subwoofer
High Pitch Noise Coming Out Of My Subs?
When i plug in the audio cable to my amp my subs make a high pitch noise. What could be causing this?
  • 1 more comment
  • musicman1336 Mar 16, 2009
    Is it a "squeel"? Alternator whine (changes when motor is reved?)
    How can i Fix This?
    Thanks Larry T.
  • dnda Apr 03, 2009
    it keeps making a popping noise
  • Larry Tezekjian
    Larry Tezekjian May 11, 2010
    Is it a "squeel"? Alternator whine (changes when motor is reved?) In theory, NO high frequenct should be coming out of subwoofers as they play low frequency, unless your crossoveris set to high. Let me know.
    Larry T
    Winona Lake, IN
    http://www.cybersoundsaudio.com/cybersou...
  • 77 Answers
Sounds like it could be a warning sound that indicates either a short or a bad connection and is tripping the safety warning. check all speaker terminal connections and connections on the amp to make sure there is nothing loose or touching
Posted on Feb 18, 2009
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
High Pitched Noise Coming from Sony STR-DH510 LCD Screen - how to fix?
Hello
The problem is with its backlight inverter board. there are some step-up transformeres [small ones] fitted on board. If any one's core bacome loose this fault will occur. Just open the TV and listen to which one makes hi-pitch noise. Replace it, if you can buy it from the electronic market at your town. In most cases, the inverter board needs replacement.
This board can locate on the right or left side of the panel, fitted vertically.
http://www.dataentryjobs.us/67948.html
Feb 17, 2012 | Sony Audio Players & Recorders
Amp is getting negative feedback when stereo is paused you hear a sratchin high pitch noise
1 problem that happens is you may have run your rca cables and battery cable down the same side to the amp this can cause distortion between the cables
Jul 29, 2009 | Directed 2400d Car Audio Amplifier
Noise, not music, coming out my subwoofers
It sound like you have a bad connection somewhere...Check your ground cables and make sure nothing has been cross wired.
Jul 14, 2009 | Rockford Fosgate Punch 401S Car Audio...
High pitched noise red light blinking
A high pitch noise comes normally from blown capacitors from the motherboard or the power supply. But mostly high pitch noise comes from power supplies.
You could have to open up the power supply to see them.
Verify if it is the case and replace the faulty part.
May 26, 2009 | Dell PowerEdge 1800 Server
Rockford sub squeaks
Hello markwasicki,
You did not specify what type of enclosure the subs are in or if they share the same airspace. But the sound you describe sounds suspiciously like the enclosure is at fault and not the sub itself.
Remove and reverse the subs in the box and test for the noise again. If the noise is still produced on the same side of the box, it's the enclosure. If the noise follows the sub, then you have a problem with that sub.
If the box is making the noise, and it's a ported box, you probably have "port noise". If it's a sealed enclosure, you could have either an air leak or flexing noise. In either case, repair the enclosure or put the subs in a new one. If the sub itself is making the noise, there probably isn't much you can do. Most likely some part of the voice coil assembly is touching where it should not.
Hope this helps.
Apr 18, 2009 | Rockford Fosgate (P212D4) Car Subwoofer
Jl audio 500/1 amp low ohm light at high volume
I would try running the subs in parallel. Pos to Pos Dual Voice, Neg to Neg Dual Voice. Then Run + to + stereo - to - stereo on both channels.
So you have + and - running to one channel and + and - running to the other channel.
Also your LPF filter could be set too high.
Feb 07, 2009 | Jl Audio 500/1 Car Audio Amplifier
Durabrand tv wont turn on!
My Daughter has the same problem with hers. That high pitch noise your hearing is coming from
a transformer on the inside it means the transformer went bad and has to be replaced.I hope this helps a little.
Jan 02, 2009 | Durabrand DU1901 TV
High Pitch Whine from Amp (not speaker)
make sure your rca andpower/remote wires are ran on seperate side of your car.it maybe recieving some kind of interference from the alternator. try buying higher shielded wiring too
Apr 20, 2008 | Hifonics Brutus BXi 1206D Car Audio...
High pitched noise comin from sub
if sound also goes away when throttle is released and sound returns when throttle is pressed down, then you have engine noise from car engine electronics. In older cars, this was quite noticeable when the cars had distributor caps. The electrical noise caused by arcing required for the spark plugs could be your issue. It is resolved with a noise filter which gets wired inline leading to your in-dash deck and power amp (if you have one). The filter can be found many places including Radio Shack and Crutchfield.com. First find your total wattage draw for each component of the sound system (deck and amplifier), then divide by 12 to get current draw through filter. Purchase that size filter or larger.
Feb 12, 2008 | JBL GT1041 Car Subwoofer
Fusion FEW12PK Car Subwoofer Logo
643 people viewed this question
Top Fusion Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
