Question about HP DeskJet Office Equipment & Supplies
Hp deskjet 3600 won't print. light keeps flashing
Light keeps flashing. troubleshooting says printer not turned on
SOURCE: Troubleshooting HP Deskjet 2460
hp deskjet d 2460, the printer icon is missing . pl note that we need to operate the machine
Posted on Aug 18, 2008
  • 11 Answers
SOURCE: flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Posted on Mar 04, 2009
MCSE_Fixit
  • 23 Answers
SOURCE: hp deskjet 5652 not printing, orange light flashing continuously
1. Check to insure the cover is shut down completely.
2. If the "Ink Drop" Icon is blinking you are either out of ink, or there is a problem with the cartridge carrier. So open the cover - the carriage should move to the middle, if not it is bound up somewhere. Check the guides and around the carriage area for gummy labels etc..
3. If the carriage moves to the middle, release the ink cartridges and replace.
4. If the "Arrow" Icon is blinking, this could be a result of a paper feed error. Remove the paper from the tray, open the cover and insure no jams are in the rollers. Shuffle the paper lightly and place back in tray. Check to make sure the tray is pushed completely forward and then press the "Arrow" Icon button until a sheet is fed into the printer.
* * Note: When you are replacing the Ink cartridges and before you remove the tape from the bottom heads, give them a shake to lossen up the ink before installing.
This link will take route you to HP's support and more troubleshooting techniques for your printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013363&lc=en&dlc=en&cc=us&product=304442&rule=35720&lang=en
Hope this helps..
God Bless.......
Posted on Jun 18, 2009
princegh158
  • 56 Answers
SOURCE: hp deskjet 3325 light flashing have turned device
no problems
:just go ahead and take out the power cable when the printer is still on
:nw press and hold the power button fr 30 seconds
;while holding the power button,plug back the power cable
:nw u will be able to work well
Posted on Jun 28, 2009
ihavsolution
  • 152 Answers
SOURCE: orange ink light keeps flashing and printer won't print
hello,
To correct this problem, unlock the carriage from the printer‘s capping station.
  1. Lift the lid to the printer (cartridges are on the right side.)
  2. Turn the printer off, then power it on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts.
  4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct.)
  5. Take out the cartridges and close the top cover.
  6. Reconnect the power cord. The power and the resume lights (green and red) should be on.
  7. Open the top cover, reinstall the cartridges, and close the top cover.
  8. The printer should print the alignment page.
  9. Print from another application.
    thank u
Posted on Jul 29, 2009
HP Deskjet 5650 - Troubleshooter keeps saying paper is low or out.
How to use the solutions in this document To resolve the issue, try each solution in this document, and then use the steps in this section to print a self-test report. This step determines if the product hardware functions correctly. When you have resolved the issue, and the product successfully prints a self-test report, there is no need to continue troubleshooting. Print a self-test page Follow these steps to print a self-test report.
  1. Load plain paper in the paper tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press and hold the Power button (c01602202.gif ).
  4. Press the Resume button (c01678098.gif ) four times. The self-test page prints.
c01733891.gif IMPORTANT : Try to print a self-test report after every solution even if the solution resolves the issue.
Mar 28, 2013 | HP DeskJet 5650 InkJet Printer
Hp deskjet 948c. What Do The Button's Do
buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on ink or incorrectly installed.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. When the problem is fixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
Jun 17, 2011 | HP Office Equipment & Supplies
I have HP Deskjet 3420 printer, which I am using with my Compaq 7500 computer (window xp). Printer was purchased by me some 7 years back. I now want to use this printer with my dell laptop having windows 7...
There are no official drivers Win 7 avaliable for your AIO hp DJ 3420, but you can use an alternate compatible drivers for your model ie. hp DJ 3600 series. Read this link from hp Installing the Printer with an Alternate Driver in Windows 7 for a USB Cable Connection. Suggestions What have you tried to get Windows Update to work? I would suggest the following: Go to the Devices and Printers folder, Add a printer, Local Printer, LPt1, etc...when the list of printers comes up select Windows Update. After several minutes the list of printers should be updated and the Deskjet 3600 should be in the updated list. (Also keep in mind to look under 'HP' section of the driver (hp 3600) list and not 'Hewlett Packard'). Cancel the install the wizard & select "hp 3600" drivers to install on your Win 7 system. Hope it helps.
Jun 11, 2011 | Office Equipment & Supplies
HP 1280 Deskjet is not printing on network
sounds like the computers are not seeing it have the drivers loaded okay,,cartridge contacts may be dirty
Jul 06, 2010 | HP DeskJet 1280 InkJet Printer
Printer won't print and resume light keeps flashing
I went through the HP troubleshooting and it started printing OK when I Stopped and Started the Print Spooling under Administration Services:
-START
-Control Panel
-Administrative Tools
-Services
-Scroll Down & Right Click on Print Spooler, Choose STOP, then OK (if needed)
-Right Click again, choose START, then OK (If needed)
After a few moments, it started right up for me and the Test Page I had in the que.
Hope this helps someone.
Mar 20, 2009 | HP Deskjet D4160 InkJet Photo Printer
Printer has all lights flashing
Remove all ink cartridges. Then unplug your printer and plug it in again
Jun 07, 2017 | HP DeskJet 5150 InkJet Printer
HP DESKJET 3420
Control Panel
Printers
Add New Printer
Add a local printer
keep as LPT1
Click HP Deskjet 3600 series
Click next
Change name to HP Deskjet 3420
Dont print test page.
Bak to printers
Left click "properties"
Ports
Change to USB
Done:)
Oct 19, 2008 | HP DeskJet 340 InkJet Printer
Jul 23, 2008 | HP Deskjet 2460 InkJet Printer
394 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
