Question about GE Spacemaker JVM1640SJ Microwave Oven
I would like to replace the microwave oven handle.
The bottom of the microwave oven handle has been broken. Probably from every day usuage. It does not show any screws or any visable way to remove the old hande and put a new handle on. Does anyone know how I can do this or is it possible?
  • kingsleyjoe Jan 28, 2009
    I used some Gorilla Glue. Follow the instruction carefully. This was the best solution for my problem, because I could not replace my microwave handle. It really works.
The inside of the door has a Black Plastic frame about 1 inch wide. This frame can be removed by placing a thin screwdriver between it and the outer door frame and gently (very gently) prying it away from the door. It takes a little wiggling of the frame but it will unlock. On each end of the handle is a philips head screw that holds the handle to the door.
Posted on Feb 02, 2009
On my GE Spacemaker XL - there is a hard plastic gasket on the inner surface of the door. It pries off easily (and pops back in easily) with a gentle motion of a screwdriver - you will find the lower handle screw under the the gasket. My question is where can you find a replacement handle?
Posted on Feb 01, 2009
Yes, I fixed the problem. I would also like to offer FixYa my premium plan solution.
Posted on Jan 28, 2009
Microwave door handle broken
That's correct the door has to come apart. Just be careful that screen is actually a choke to keep in any microwave radiation. Put everything back exactly as you took it apart.
Good luck
Feb 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Broken door handle
The in side door panel ( at total pain) must come off
If the damage to the bottom is not too bad.
On mine I took the cover for the handle loose from the bottom ( it pops off, but be careful).
and put screws at the bottom
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE 1540 handle...bottom fastener is broken. How
remove w putty knife the inter face. you can see the screws at this point ,. just remove screws and reinstall handle . pop interface back in **** . you can get a brake down of how this fits on sears web sight . **** / hope this helps ( it;'s not a hard job /time 1/2 hr / mm .
Dec 22, 2009 | GE Spacemaker JVM1540 Microwave Oven
Handle on Frigidaire Microwave broken, probably because of heat from gas burner below - this is a defect becaquse the microwave oven was manufactured to be built-in above range. Frigidaire has finally...
im kinda confussed as to why Frig would do that,,,
but if you send the model number im sure we can help
most times repacing the door is really just a matter of lifting it off the pin hinges after you have removed the vent
but i can be more clear with the exact model
Oct 28, 2009 | Electrolux Microwave Ovens
The handle on my maytag microwave oven broke off at the bottom. How do I replace ? Model MMV5165BA
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
This is not difficult. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
Replacement parts can be found at any of the following sites:
appliancepartspros.com
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
I hope this helps you.
Aug 12, 2009 | Maytag Appliances Over-the-Range Microwave...
How to Replace Broken Handle
Sorry but the chat system seems slow and hard to work with.
Page 28 & 29 of the service manual tell you how to remove the door and take it apart to replace the handle.
The service manual is here.
And you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Jan 22, 2009 | GE Advantium 120 Convection/Microwave Oven
Another broken handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Hi have a nie day!
You may use a electric drill and the a screw extractor so the handle be released.
Mar 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 22, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
409 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
