Question about Delta 31 735B 6" Belt, 12' Disc 3 Ph Finishing Sander
31-735 delta belt/disc sander - dust collection nightmare
Got this to replace my old trusty belt only Delta sander. The new one does great at dust collection for the disc, but has no opening/pathway that I can see on the machine or in the manual that allows for collection and I and my students are coated in dust. The plate that anchors the belt component to the base has a solid plate attached. Could it be that this is supposed to have an opening?
    President:
  • 2,976 Answers
The belt cover that does down the front of the belt, below the table, should have an opening inside the baes/vacuum unit. Make sure this isn't clogged with buildup.
Posted on Jan 30, 2009
How to fix motor delta belt disc sander
What is it doing or not doing, when u turn on the switch, either the switch or motor is probably bad or you have too much tension on the belt.
Aug 22, 2014 | Delta 31 695 6" Belt/9" Disc Sander
I have lost the screw that holds the sanding from spinning on its own. I can't find the part number. Could you assist please?
I do not know if this will help because I do not know which screw you need. If you click on the link below you can look at the delta service manual parts list.
http://www.ereplacementparts.com/images/delta/31-695_TYPE_1.pdf
Otherwise can you be more specific on the location of the screw?
Apr 29, 2011 | Delta 31 695 6" Belt/9" Disc Sander
I'd like to download a manual for the Delta 1" Belt/5" Disc Sander I just picked up at a yard sale. I can't seem to find one. Thanks.
you might try going to dewaltservicenet.com and typing in your model number in the middle of the page towards the bottom under need a manual. If not let me know and I will try and locate another source for you.
Oct 03, 2010 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
Delta disc and 1" belt worled yesterday, not today. I turn the switch on and the disc "twitches" and the motor hums. I can turn the disc by hand so it's not jammed. Belts are good. Any ideas???
the motor has lost its polarity it uses magnetic electric polarity to turn around. the fault is just as bad as a burned out motor you could have the motor rewound but it would cost more than the entire unit..
sorry
take care.
Aug 03, 2010 | Delta Machinery 1" Belt and 8" Disc Sander
Should I buy an old Delta sanding Center? Is it wise to buy an older Delta sanding center 31-730F Not all parts are still available. They want $250.00 for the sander
If it's the kind with a round disk sander and a wide belt sander, as far as I know belts and disks are still available. There is not much else to wear out. Make sure you test it before purchase.
May 12, 2010 | Delta Machinery Sanders Sanding Center -...
My delta sander stalls while sanding on the belt.
Mine was underpowered from the get go. I have since sold it. Keeping it well lubricated does help though.
Jan 23, 2010 | Delta Machinery 4x6 Belt/Disc Sander
New belts on drum sander shear off inside clip
Belt sander are very tempermentel and require a light machine oil (3-in-one) on the metal slides and Tension lever and springs to opperate properally, if not they will drive you nuts, it will make a big differance, a few drops will do ya, more it needed, to much will cause a reverse action and collect dust, clean areas before oiling with air preasure and fluids if needed to get rid of build up from wood dust
Jan 20, 2009 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
Delta 31 735B 6" Belt, 12' Disc 3 Ph Finishing Sander Logo
485 people viewed this question
Top Delta Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Delta Measuring Tool and Sensor Expert? Answer questions, earn points and help others
