Question about HP Deskjet D4260 Printer
Printer won't print
After I did a diagnostic check it said device not connected, check if divice is powered and properly connected to computer. The ink and arrow light are flashing, so it's powered. I have tried two different usb ports, no luck
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, it is possible that the printer is OFFLINE, try verifying/enabling it by performing a right click on the HP Deskjet D4260 icon in the Printers folder.
Post back results. Alternately, you can check/replace the USB cable.
Good luck and Thank you for using FixYa.
Posted on Jan 27, 2009
    Brigadier General:
  • 8,619 Answers
HI
Try to unplug the printer and then plug it back
My ricoh Aficio mp4500 give damage print and doble shade print on page any body hellp me
Sounds like a worn drum blade, if you open the right door is drum clean? If so bad fuser..
Nov 29, 2014 | Ricoh Office Equipment & Supplies
My HP deskjet 3930, will not print anything i send from my computer, however will print a test page just fine. I have done all of things that you have mentioned, uninstalled software, downloaded and...
Ensure that the cables are properly connected; you need to ensure that your printer is properly connected, and plugged in, and also the cable is accurately connected to the computer as well.
Check the power; make sure that the printer's power is switched on, ensure that all the computer necessary computer components are also turned on.
Make sure that the hardware is properly plugged in, and also turned on. Apply troubleshooting.
A troubleshooter is a tool, which is generated automatically and which can easily fix the problems that occur with your system.
Thus, if you are coming across different issues related to your printer, then you can consult the troubleshooter.
You require driver applications to run your hardware devices.
Make sure that the drivers are not outdated, corrupt, or incompatible, resulting in disrupting the communication between the printer and the computer.
Always make sure that you are making use of the most recent and latest device drivers, and also that are compatible with your system requirements and specifications, as this can be extremely useful in resolving printer issues.
May 03, 2011 | Office Equipment & Supplies
My lasejet 1100 print only test pages wether i print other documents please solve my problem soon
HP designed a quick and easy tool that diagnoses and resolves many printing problems: The HP Print Diagnostic Utility. HP recommends that you download and install the Print Diagnostic Utility any time you need to troubleshoot a printing problem.
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Nov 04, 2010 | HP LaserJet 1100 Printer
Printer give me erroe 57 and icannot working test for printer
  • Connectivity :
Oct 28, 2010 | HP LaserJet 2420 Printer
When printing a test diagnostic page I only get black and yellow other colors are blank. Tried cleaning heads still nothing
  • Connectivity :
Oct 27, 2010 | HP Photosmart 3210xi InkJet Printer
Printer says ' catridge error, refer to device documenation.' the catridge is was just refilled and the printer has been woirking all along
Try The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
  • Connectivity :
Oct 27, 2010 | HP Officejet 4315v All-In-One InkJet...
Wont print
  • Connectivity :
Oct 26, 2010 | HP DeskJet 712c InkJet Printer
I had to reinstall the software for an HP 3390 on a Windows XP workstion. The device can print and fax. However, when I try to scan a document I get the following message: The HP imaging device could...
  • Connectivity :
Oct 26, 2010 | HP LaserJet 3390 All-In-One Printer
My printer will copy but not print a document...
  • Connectivity :
Oct 26, 2010 | HP Office Equipment & Supplies
HP Deskjet D4260 Printer Logo
151 people viewed this question
Ben Johnson
