Question about Mindscape Team Apache for Windows
Team apache windows 7 - Mindscape Team Apache for Windows
How to cool my Apache rtr 160 engine
Hi, Krishna for overheating issues the usual suspects are:
1. Engine oil level and SAE weight are too low or not circulating.
2. Insufficient or blocked air flow over the engine.
3. Heavy combustion chamber carbon deposits.
4. Ignition timing retarded due to faulty MAP, CKP, or CMP sensor.
5. Carburetor jetted too lean.
6. Leaking intake or exhaust valve.
7. Water coolant old or low change every two years.
8. Water pump failure.
9. Radiator clogged, cap loose or malfunctioning.
10. Radiator fans not coming on.
11. Clutch slipping, brakes dragging, heavy load, towing a trailer etc.
12. Idling too long without moving.
13. For constant hot weather temperatures, mountain, or desert riding conditions consider adding an oil cooler and or cylinder head cooler.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Top 10 things you need to know about the 2012 TVS Apache RTR 160 180
https://www.tvsmotor.com/pdf/Manuals-Apache-RTR-160-NEW.pdf
Life On 2 Wheels
TVS Apache RTR 160 2010
TVS Apache Wikipedia
Mar 10, 2017 | 2010 TVS Apache RTR 160
Somehow my PC has been downloaded with something called Apache a server? and I do not know how to get rid of it. I am unable to log onto Firefox my actual server to tell them about this problem
Hi to uninstall Apache as a service. 1 .open a command prompt window 2 navigate to default Apache installation directory.or wherever Apache.exe is located 3 at the command prompt.type 'apache -k uninstall without the quotes 4 close command prompt window ... Cheers
Nov 01, 2016 | Computers & Internet
Apache/2.2.9 (Debian) PHP/5.2.6-1+lenny9 with Suhosin-Patch Server at us.mg1.mail.yahoo.com Port 80 This is the 404 Not Found message that I get when I log into Yahoo Mail from my home computer. I can...
The Yahoo Server is facing problem with its Apache web service, this service is not working, you do not need to be anxious about this problem, the Yahoo Technical Team will take its notice soon and will remove the problem.
Jul 18, 2011 | Computers & Internet
Interactive Magic Apache Windows 95 program disk does not load into HP Pavilion - Light Strobe DVD/CD Burner. I have Windows Vista. Can it be done?
You must use Dosbox, get it at www.dosbox.com. Follow instructions and you will be able to play most old dos games. I started playing Apache 95, the game before the one you're trying to load and it plays just fine with graphics, etc... I love that game and when computer technology got better my old dos games fell by the wayside until I found dosbox.
Aug 31, 2009 | Interactive Magic Apache for Windows, Mac,...
How to create my hard disk as server like a website in my lan..............
you must install IIS (internet information service) or you can install wamp (mysql+ apache web server + php)
Jul 08, 2009 | Microsoft Windows XP Professional SP2 Full...
Uses of apache web server in open suse
Well, when using apache web server in open suse linux it is more secure and it is easy to manage than using apache in windows.
May 05, 2009 | Computers & Internet
Apache is not runing
Not Only Skype , Team-viewer is also using port 80 .
To know who uses port 80 go to command promt and type
" netstat -aon " in command prompt and and PID of app listening at port 80 and find athe app on Task Manager -> Servies and Stop it , Then try to Run Papche
If it is not solved
Try by editing httpd.conf of apache (can be found at c:/xampp/apache/conf/ )
If not solved Please attach the error log in order to troubleshoot it .
(log path c:/xampp/apache/log/error.log )
Mar 27, 2009 | Microsoft Windows Vista Home Premium with...
Mindscape Team Apache for Windows Logo
61 people viewed this question
Top Mindscape Video Game Consoles & Games Experts
James Wishart
Are you a Mindscape Video Game Console and Game Expert? Answer questions, earn points and help others
