Question about Belkin Computers & Internet
Neighbor stealing from my Belkin internet connection.
I live across the street from him. He set up my Belkin router when I got my Acer, & made himself the administrator
  • Mary Litton Jan 25, 2013
    Hopefully this will work. I'm 68 & what I know about computers you could put in a thimble. Thanks so much, Mary
  • 3,904 Answers
Reinstall the software and set the router up again with yourself as the administrator and also set it up as a secured connection. It will walk you through the process screen to screen. You will then get him off of your network.
Posted on Jan 23, 2013
  • Mary Litton Jan 26, 2013
    Actually Jrry, I haveno idea how to reinstall the software. I have no idea how to uninstall it in the first place. I am68, & dumber than apost when it comes to twiddling with my computer. I thank you very much for trying to helpme. Mary
SOURCE: wireless ready laptop not getting connected to internet through belkin router
You may want to check if the wireless switch is "ON"
on the laptop most wireless ready laptops has either a
button or toggle switch to enable the wireless radio..
if it's already enabled and you still cant connect to
the wireless network,try changing the wireless channel
from the router.
Posted on Jun 19, 2008
Geekman
  • 32281 Answers
SOURCE: Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Posted on Sep 29, 2009
  • 38 Answers
SOURCE: setting up a belkin n wireless router. How do I
You have to go into the setup for the router. Most default to the 192.168.1.1 IP address. You would type that address into your internet browser and hit enter. Then you will be asked for a name and password. If you have your belkin manual it will tell you the default name and password. Once in the settings you can change the password. You can also turn off SSID broadcasting, enable the highest level of security that your particular router supports in conjunction with your computer and enable MAC authentication. If you enable MAC authentication you have to type in the MAC address for each device you wish to have access to the router.
Posted on Nov 07, 2009
garethmt
  • 116 Answers
SOURCE: New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
Posted on Nov 13, 2009
milan_cool
  • 65 Answers
SOURCE: I have Belkin N150 Rouer.
f the modem light keeps blinking, it means that the router hasn't been configured yet. Also, rarely, it can be an issue with WAN port/modem port on the router or the ethernet cable connecting the modem to router or finally, modem may not be working as its not applicable in this case(as you said).
1.Connect comp.--(gray port) router (yellow port)--modem
2.On the computer, open the router page by typing 192.168.2.1 in the address bar of browser
NOTE : IF YOUR INTERNET SERVICE PROVIDER IS CABLE FOLLOW THE BELOW STEPS
3.Under Internet WAN , SELECT the connection type as Dynamic.->NEXT
4.On the far left column, click on "MAC address" under Internet WAN.
5.Click on clone and apply changes and finally check Internet status
6.If internet status > Not connected, we need to do a network power cycle
7.For this, unplug the power from router, then from modem, then unplug the coaxial cable from cable modem.
8. Wait for 60 sec, then connect the coaxial cable, then connect power to modem, wait for lights on modem to get steady, then finally, plug in the power to router.
Now, you may see proper lights lit on the router.
All my best wishes for a fast internet service through the router.
FOR PPPOE OR DSL CONNECTIONS
1.Under Internet WAN , SELECT the connection type as PPPOE ->NEXT
2.ENTER THE USERNAME & PASSWORD PROVIDED BY YOUR IN INTERNET SERVICE PROVIDER
3.CLICK ON APPLY CHANGES
For any advanced help, revert asap!
Thanks and regards,
MILAN
Posted on Jan 24, 2011
Need to reset password on a Belkin d80
To restore it to the factory settings press a paperclip into the hole marked "reset" for 5-10 seconds. Do that wile the router is on. Then if you need to set a special password you can connect to it and change the password.
To change the password connect to your router by going to your browser on your computer after connecting to your router. The default address for belkin is usually "192.168.2.1" for login its either "admin" or just left blank. there shouldn't be any password. After you login you can go through the settings and change your wifi name and password. Most routers also have many other security options like only allowing certain computers on that you add their mac addresses. Hope this helped. If you need more help just leave a comment.
Feb 11, 2014 | Belkin (F5D7230-4) Router (587009)
Where is the administration located?
You need to encrypt your wireless router.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 22, 2013 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do I prevent my neighbor from using my wireless router?
If you do not have any wireless network security enabled on the router, your neighbor can see this SSID and connect to the network without authorization. While this is generally frowned upon as being unethical, it is technically not illegal as you have "made the network available" by failing to secure it. The easiest way to secure the network is through the use of a WEP key or a WPA pass-phrase. WEP keys are generally 5, 10, 13 or 26 randomly generated characters long. WPA pass-phrases are just that - a phrase such as "The sun is yellow". Either method will prevent unauthorized users from accessing your network. Only those individuals who possess the key or pass-phrase are granted access.
These options is located under the Wireless > Wireless Security tabs from within the router administration.After login you can change the password.
If you need any kind of technical assistance you can contact support cell at here
Jan 22, 2013 | Belkin Computers & Internet
I'm in the middle of my afternoon internet time, (2pm-6pm daily) & my belkin wireless router's internet light begins flashing & I then lose connectivity, what could it be? A driver issue maybe?
it could be. i owned a wireless router one time, (a fairly cheap one) and it was under almost constant, heavy usage (2 - sometimes 3 wireless laptops, 1 desktop and xbox live) and one day it just gave out. it could be a driver problem, but what i would do is unplug the router, let it set for 30 seconds or so, then plug it back in. this almost always fixed any router i stumbled across.
Feb 24, 2011 | Computers & Internet
I forget how to go wireless. I have a belkin router, but when my old neighbors were still living near by they kept stealing my internet access. So I unhooked it and now I can't figure out how to get my...
How to secure the wireless network
Change the Name of the wireless network and change the password of the wireless network. So that they will not be able to get in to your wireless network.
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Aug 31, 2010 | Belkin (F5D7231-4) Wireless Router
How do i block someone from illegally stealing my wireless intern
You have two options to stop someone from stealing your wireles connection.
The first is to use a more secure encryption.
Use WPA2 personnal with AES encryption.
You can set this security mode by logging on to your router and changinhg the wireless security.
The next solution is to turn on MAC filtering and make sure her computer is not listed as a safe MAC address.
This is also turned on from the router.
Hope this helps.
Thanks,
Pat
Apr 26, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a belkin g wireless router in living room and having trouble keeping connection to internet on my laptop, which has wireless built in
Make sure DHCP is turned OFF. START>>RUN>>services.msc enter. Scroll down to DHCP, and set to OFF & Disable. Also if there is Zero Configuration, service disable that too. Make sure there is a good clear path between the Antenna and computer.
Mar 01, 2010 | Belkin F5D7234-4 Router
Hi There, I have had an N1 modem router now for about 12 months and previously had both my Apple PC & Windows PC connected via same on a home network ethernet cable. Recently I purchased a new Acer PC...
Win 7, Ensure DHCP is turned OFF. All network settings are set, & shared, A password, all in same workgroup, and a PC Name too. Do all as Administrator.
Feb 28, 2010 | Belkin N1 Vision Modem Router -...
I have an Linksys Wireless G WRT54GS router. I
This is strange... Never heard of it in all my years. Call Linksys www.linksys.com and then ask them becuase this is rare. If they can't find a solution just steal the internet :)
Oct 13, 2009 | Linksys Wireless-G WRT54GS Router...
Problem with router; Msn gets disconnected frequently.
It could be the proxy or firwall setting in the router.
you need to open the router page and check the firewall and proxy setting ..
or you can download the tool from the below site
www.ultrareach.com/
and it will take off all proxy setting and you winows messenger should work.
This should help you identifing if its a proxy issu.
THanks & all the best
May 27, 2009 | Belkin (F5D8231-4) Wireless Router...
Computers & Internet Logo
108 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
