Question about AOpen AX34-U Motherboard
I need to disable com 2 in the bios
I need to diablet the com 2 port as i need the interupt for something else
  • ral_sales Jan 30, 2009
    I have looked at everything in the bios and could not find anything to disable the com2 port
  • 56 Answers
TO ENT THE CMOS IS FIRST TURN ON THE MACHINE CTRL-ALT-ESC FOR OLDER MACHINE, NEW SYSTEMS ASK YOU WHEN U TURN ON THE MACHINE IF YOU WANT TO CHANGE THE CONFIGURATION OR DO YOU WANT TO GO INTO THE BOIS IT IS GOING TO BE "F" PLUS A NUMBER LIKE F2 OR F10 OR F12,
SAVE EVERYTHING YOU CHANGE IN BOIS SETTING IT IS F10 AND YES TO EVERYTHING AND REBOOT
Posted on Jan 27, 2009
How can i disable the on-board sound to prevent conflicts with the additional sound card..?
If you are using windows, right click on "My Computer" and click on "Properties." Then click on "Device Manager." There should be a section for "Sound, Video, and Game Controllers." Here you can disable whatever conflicting devices you have. Hope this was helpful!
May 02, 2011 | Computers & Internet
Need to shut off bios password on my L300
Removing the BIOS battery will not reset the BIOS and remove the BIOS password.
On earilier model Toshiba a parallel port dongle will remove thw BIOS password.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.
Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Mar 29, 2010 | Toshiba Satellite Pro L300 Notebook
ACPI\PNPB006 for A8N32-SLI DELUXE Windows-7
disable MIDI and GAME port in BIOS:
Power up PC, Press DELETE to go in BIOS
Go to Onboard Device Configuration
Feb 20, 2010 | Computers & Internet
Ver, very SLOW when booting up! Sometimes the
BIOS System defaults are best used for installing a new operating system or performing diagnostics. Bootchecks and memory checks due to settings on antivirus/antispyware programs are notorious for causing slow boots. In most cases these scans are unnecessary. Saying that, it is also possible you have acquired a trojan. Run a full system scan and if you have a clean machine, disabling the bootchecks and memory checks will speed up your booting. If after doing this your boots are still slow, tweak your BIOS as follows per Intel:
  • Set the hard drive as the first boot device in the boot order in the BIOS setup (Boot > Boot Device Priority menu).
  • Enable Intel® Rapid BIOS boot in the BIOS setup (Boot menu).
  • Disable Hard Disk Pre-Delay in the BIOS Setup (Advanced > Drive Configuration menu).
  • Disable system functions and features if you do not need them. Examples include:
    • Legacy USB - this must be enabled if you use a USB keyboard or USB mouse outside the Windows* environment (Advanced > USB Configuration).
    • Unused I/O ports, such as serial, parallel and IEEE-1394 ports (Advanced > Peripheral Configuration menu).
    • Event logging (Advanced > Event Log Configuration menu).
    I hope you find this solves your problem. All the best! Greg
Nov 10, 2009 | Intel D845GVSR Motherboard
MOB ITOX G4620-N won't reconize ISA Cards
WOW must be a fairly old system if it still has ISA slots.
Are you running XP or something else?
I assume you have the manufactures drivers that match the operating system you are using?
Have the isa cards worked in this system before?
My memory of isa cards is they are really useless at managing interrupts and I/O addresses. Go into device manager and see if there are any conflicts.
Try installing one card at a time. once it is recognised you can try the second one.
Also go into the bios settings page and turn off devices you are not using like serial ports and parrallel ports. if you have a sound card remove it or disable it if is onboard.
If you know what Interupt the cards is tyring to uses you should be able to reserve it in the bios so that plug and play devices won't touch it.
With a some trial and error and a combination of all these settings you should be able to figure it out.
Apr 01, 2009 | Computers & Internet
USB ports quit working
I had this happened to me also. you need to check the system bios to see if something shut the USB ports off. normally hitting DEL or f10 prior to bootup will put you in the system BIOS. Normally all usb ports disable because a device was unplugged without properly shuting the device off.
Mar 29, 2009 | Dell Inspiron XPS M140 Notebook
Hardware conflict
You might have your internal modem set to the same com port as your com ports that are on your motherboard. You can try to go into BIOS and disable all com ports OR you can try to configure your internal modem in windows to use com 3 or com 4. Remember, that if your computer does have com ports in the back, then is is probably set to the same address as your internal modem so something needs to be moved.
Feb 11, 2009 | Hiro V.92 56K PCI DATA FAX VOICE MODEM...
Disabling COMM ports
If you're pretty sure its your comm ports, boot up into your bios setup screen. (Tap Del while booting) Then go to the onboard devices page or any page that lists your com ports and change the property value to disabled.
Regards,
Worldvet
Jun 19, 2008 | EliteGroup K7VZA Motherboard
Setting up the camera on my Gateway computer
Your PC serial port is possibly not setup properly causing it to not recognize the camera. Gateway has information concerning their special COM A port on some model computers and how to set it up properly for external devices. Basically, you need to hit F1 at boot to enter the BIOS setup utility. Go to Advanced / Peripheral Configuration / Serial Port 2 then hit Enter. Then Disable. Go to Serial Port 1 Address and hit Enter. Change it to Com 2 (2F8h). Save the settings and exit. After Windows 95 boots, go to Control Panel / System / Device Manager / Ports and delete the serial port 2 with the (!) -- exclamation mark. Go back to Ports and select Properties for Com 2 / Port Settings and change the speed to 38400. Now go into Easy Photo...select Com2, and set the speed to 38400. Test the camera by downloading the snapshots.
Sep 13, 2005 | Epson PhotoPC 600 Digital Camera
AOpen AX34-U Motherboard Logo
56 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
