Question about Lands Phones
Doesn't want to dry.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 23 Answers
More information! Im guessing its just blowing cold air?? If so all fire risk products such as this a fitted with safety switches. (High temperature cut cut) as your dryer looks fairly now im guessing the element is ok! So if its powering up and just not drying! Id put my money on a faulty thermostat. ... hope this helps
Posted on Jan 22, 2013
My beko wb 6004 ns doesn't spinning to dry the clothes
the issue is in the timer . have a qualified technician change it with a new one . thanks .
Jun 14, 2013 | Washing Machines
2001 grand marquis airbag light came on when car got wet
It's an American car, so it doesn't like to get wet per se. Dry it out and if the issue doesn't persist, then consider it fixed.
Nov 12, 2012 | 2001 Mercury Grand Marquis
Kitchenaid superba electric dryer doesn't dry on timed dry
Sounds like a controller problem. May be unable to start a normal dry cycle
Sep 11, 2012 | KitchenAid Dryers
Water got into my Xbox 360 by the fan can I fix it
Let it dry out give it a day or two before plugging it in put it in front of a fan or heater to dry out good. Was the Xbox plugged in when it got the water on it? Once its dryed out you can try plugging it in.If it doesn't power up you probably fried the power supply. But if it was like a glass of water got spilled and some splashed near fan it probably will work. I think there are even some fuses in side the Xbox but you should leave that to a professional. If it doesn't come on once its dryed out
Apr 11, 2012 | Microsoft Video Game Consoles & Games
I have a Kenmore front loader - when I turn the knob to start the dryer, it make a noise like it wants to start but doesn't. I have tried to move the knob which indicates what drying time you want to...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 20, 2011 | Dryers
The clean light keeps flashing clean and we can't start it. Plus it doesn't get any of the dishes clean and it's only 3 hrs old
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 14, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
I have a L G and it does not spin dry the wash load How can this be fixed
Do you mean it doesn't spin at all...or it doesn't spin fast enough to dry the clothes?
If it will not spin at all you may have a loose belt or broken belt.
If it does not spin fast enough, you may have a loose belt or too latge a load.
Jun 26, 2011 | Washing Machines
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
