My heil furnace fires up but then within a minute the burner shuts off and does this continuously
  • 80 Answers
SOURCE: My heil furnace comes on and lights the pilot but
You need to remove the flame sensor on the far left hand of the burner. In has a single wire going to it in between the jets. I believe it is a white wire. A 1/4" screw holds it in place. It has a white ceramic base with a stainless steel looking probe that protrudes into the flame of the burners. Pull the wire off of it, then remove the flame sensor from the burner assembly.. Use steel wool to clean the metal probe until shiny. Re-install and enjoy your heat.
Posted on Oct 07, 2009
gear001
  • 59 Answers
SOURCE: HEIL FURNACE W/ WHITE-ROGERS GAS VALVE 36C84/410
The problem might be with your safety switches other than you gas valve poilte
Posted on Oct 12, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: furnace wont start. heil gas furnace. on initial
Yes, inspect the air intake, exhaust pipe, filter and condensate piping for blockage or moisture. Also check for a hole in the hose that goes from the small exhaust blower to the pressure switch or a bad connection on the switch or control board. You may be able to temporalily jump the switch for diagnostic purposes only.
Posted on Oct 17, 2009
milten1
  • 1304 Answers
SOURCE: goodman furnace GSM100-4 model has constant ligt
for what ever reason, your shutting down on high temp
4 things to check
1 the filter
2. your fan, is it comming on....... to circulate the heat.
3. your hi temp thermostat is bad and needs to be replaced.... it should be a sqaure with two wires
you can just ohm it out to know sometimes orange but it differs some
4. above your fan are the coils, ar5e they clean and free of restriction
Posted on Oct 28, 2009
  • 89 Answers
SOURCE: Model GMPN furnace: burners light OK, but shut off
The unit is not sensing a flame. A flame sensor is a piece of metal rod about 1/8" in diameter which tells the unit it is burning. take it off and clean it with steel wool. if that doesn't work you'll need to replace it
Posted on Nov 03, 2009
My furnace fires up run for about five minutes then fire box shuts off and the fan runs until my furnace runs through its cycles but the fan runs almost continually runs it only shuts done for a few...
On a conventional furnace of today, your furnace may have a flame sensor which is typically located in front of an end burner opposite the ignitor. It is connected by 1 wire. This metal rod needs to be removed by 1/4'' screw in most cases and cleaned. Clean with steel wool or even a clean greenie scrubber will work. Wipe clean and re install. Many problems can cause these symptoms, but this is a very common one.
Mar 02, 2015 | Heating & Cooling
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
IT SOUNDS LIKE THE FAN CYCLE RELAY OR BOARD IS NOT MAKING THE FAN COME ON WHEN IT SHOULD THE BURNER SHUTS OFF PROBABLY BECAUSE IT REACHES THE HIGH LIMIT.
Feb 03, 2015 | Heating & Cooling
Heil nulk075dg05
You have a dirty or bad heat sensor. When you remove the front panel on you furnace you will see a probe that is 2 or 3 inches long that is in the flame when the furnace fires up. If it doesn't detect a certain temperature within the first 30 or 40 seconds it shuts down the furnace. You can either clean the probe off with sandpaper, or purchase a new one. They aren't very expensive and are easy to replace. In my experience it is usually a build up of carbon on the sensor and a good cleaning with sandpaper and alcohol usually takes care of the problem.
Feb 04, 2014 | Heating & Cooling
Ignition failure.
if furnace fires up then immediatly shuts off check the flame sensor. make sure it is sitting far enough inside the burner box and has proper continuity. if ur getting ignition failure without having furnace fire up, check proper voltage to hot surface igniter, continuity within igniter
Dec 05, 2013 | Heating & Cooling
Sometimes my Heil furnace combustible air blower comes on and just keeps blowing and the burner never fires up, nor does the heated air blower come on. If I turn the furnace power switch off for 5 or 10...
Flame sencer you can clean it for now but will have to be replaced it located on the opposite side of the igniter it has one wire pluged in to it 1/4 inch screw just wipe it with your fingers and put it back in
Mar 01, 2013 | Heating & Cooling
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
My Ruud furnace used to regulate 1 deg +\- the set temp. Now it regulates right at the set temp and the fan cuts off while the burner continues to fire for a minute or so then the fan kicks back on for...
It appears to be the fan limiter switch. It comes on at a certain temp when heating up and shuts off on the high end of its setting. Once the burners are shut down, the fan continues for a few minutes to cool down the burners. The limiter switch is adjustable but it sounds to me to be defective and should be replaced. Good luck and stay warm, :-)
Mar 15, 2011 | Ruud Heating & Cooling
Heil heater starts/stops before reaching temp
is installed in a vertical up flow or horizontal position , if in horz position you could have a bad or miss positioned roll out switch this is a thermal switch positioned toward the burner edge that if the flame rolls out of burner area trips and then resets as it cools allowing the furnace to re-start until it reaches temperature , something to check .
Dec 08, 2008 | Water Heaters
Furnace burner ignites then goes out
Sound like a thermocouple, or flame sensor.
If it has flame sensor make sure you check micro amps to verify operation, because it might be the board that controls the sensor.
Dec 01, 2008 | Cross Furnace Draft Inducer Blower 115...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
