Question about Office Depot Ativa DXC180D Shredder
Ativa dx180u shredder only operates in reverse
5 Suggested Answers
splintellz1
  • 37 Answers
SOURCE: Need Ativa X1800 Shredder Parts
Hey check out this link they service all types of shredders hopefully they should be able to service yours.
http://www.factory-express.com/blog/2005/10/paper-shredder-parts.html
Posted on Jul 03, 2009
  • 255 Answers
SOURCE: I need a fuse for our Ativa AT 1250 shredder ..
Read ITS RATING or remove it and buy from electronics shop.
Posted on Sep 25, 2009
SOURCE: Ativa X1000 paper shredder that doesn't turn on
took the shredder section apart, cleaned out the gears of paper and a broken mount (plastic piece), and hand turned the electric motor to free it up. After assembly, the ready light works and so does the FWD/REV directions for shredding.
Posted on Nov 10, 2009
  • 42 Answers
SOURCE: Our Ativa HD PRO 1600 shredder will not operate
SOUNDS LIKE THE SENSOR OR SWITCH MAY HAVE TRASH ON IT.
LOCATE THESE ITEMS USUALLY ON LEADING EDGE CLEAN
SENSOR WITH A "Q" TIP AND ALCOHOL. IF THERE IS SWITCH CHECK
TO SEE THAT IT IS NOT JAMMED AND WORKING PROPERLY.
Posted on Oct 19, 2011
Ativa shredder X1800 - shredder does not respond. green light present. Reverse works fine. I killed it with too much shredded paper.
Unplug it. Lift the shredder unit off the catch-bucket. Remove any paper caught in the blades. You may need needle-nose pliers to pull jammed paper out from between the cutters.
Aug 22, 2016 | Office Depot Ativa X1800 Shredder
I have an ativa shredder model MD 1250. Became jammed on some staples. Reversed it and pulled it out but no the auto shutoff won't work Is it fixable? The shredder still runs.
Robert,
Double check that you do not still have any paper that may have become stuck in front of the sensor for the auto shutoff. If there is something in front of the sensor it will keep running.
Jun 15, 2015 | Ativa MD1250 12-Sheet Cross-Cut Shredder -...
My ativa 12 x-cut paper shredder runs for 1/2 sheet then stops. how would you identify problem and fix it
The sheet detector may be malfunctioning. Your shredder may have to be cleaned to restore proper operation. Mine gets clogged periodically and has to have the bin removed so the entire shredder can be turned upside down to perform dental hygiene on the teeth. Paper shreds even get jammed in the spaces between the teeth. Flossing doesn't help!
Mar 07, 2015 | Shredder Office Equipment & Supplies
No power to shredder, no reset button, reverse will not solve
The motor may have overheated and failed, especially if the shredder was operated at its rated capacity or operated continuously for long periods of time. The specs for these devices tend to be exaggerated.
Apr 22, 2014 | Ativa Hd1600 16-sheet Cross-cut Shredder
Jammed shredder
If your Ativa shredder has a bin, you can gain access to the shredding mechanism by removing the bin and turning the shredder upside down. With power disconnected, be prepared to spend considerable time picking out bits and pieces of material. Tweezers and a utility knife are useful tools. Eventually your shredder will be back in working order.
Feb 28, 2014 | Ativa MDM6000 6-Sheet Micro-Cut Shredder
I have an Ativa MD 460 shredder, it is misaligned with paper. Can you help?
ativa md460 misaligned Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your ativa md460 misaligned question. Get free help, tips ... I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
Just purchased ativa MD 460C and it will not work. misaligned
www.fixya.com/support/t9496803-just_purchased_ativa_md_460c
Jun 16, 2011 - Look for a curve in the lip on the back of the shredder and align it with the ... I have an Ativa MD 460c paper shredder that reads misalignment.
Ativa MD460 paper shredder: misalignment light is on - Fixya
www.fixya.com/.../t7580117-ativa_md460_paper_shredder_misalignme...
Jan 1, 2011 - I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had ...
Office Depot Ativa DQ60M Shredder Misaligned - Questions ...
www.fixya.com > ... > Office Depot Ativa DQ60M Shredder
just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help... I have an Ativa MD 460c paper shredder that reads misalignment.
Jun 07, 2011 | Office Depot Office Equipment & Supplies
I have an Ativa DX 180 du shredder that has no forward motion but does reverse. I've keep the blades well oiled so I am not sure of what the problem could be. Please advise.
My shredder was only running in reverse, and it would make a clicking sound when i fed in the paper in forward. The sensor was okay, so this is what i did. Obvisouly something is blown on the mother board, and i can't fix that. I switched the wires around that go to the motor from the mother board. They just unplug, and it can easily be switched. Now when you put it in reverse, reverse is forward. You have no sensor, but you can still use it. Not the right way to fix it, but it's a fix if you are going to trash it anyway.
Oct 07, 2010 | Office Depot Ativa DXC180D Shredder
DQ83M ATIVA SHREDDER ...LIGHT IS ON BUT DOES NOT SHREDD
The RUN green light is on but no motor is operating for any function of the Ativa DQ 83Mn Shredder. What can be inop?
Sep 17, 2010 | Office Depot Ativa DQ60M Shredder
Nov 10, 2009 | Office Depot Ativa DQ60M Shredder
Where can I find gears for the ativa Model DQ120Dn?
they don't make replacement parts. was designed to operate thru the warranty period then you buy another one. Fellows makes a better shredder.
Oct 29, 2009 | Office Depot Ativa DQ60M Shredder
Office Depot Ativa DXC180D Shredder Logo
Top Office Depot Office Equipment & Supplies Experts
Jim Keysor
Anthony Karuku
quennie732
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
