Question about Garden
I have a Murray Sentinel ride on mower that is letting all the petrol into the sump from the tank while it is turned off what could be the cause of this?
This is a 1999 model with a briggs and stratton 13 hp Diamond I/C engine
  • 2,239 Answers
The cause is a leaking inlet needle in the carb, if the machine runs ok and only does this whilst left, fit an in line fuel tape this will stop the fuel leaking whilst stood.
Posted on Jan 22, 2013
  • 7 Answers
SOURCE: is there an oil filter on a Briggs/Stratton riding lawn mower. Model#42A700
Yes there is a spin on oil filter. Depending on the date code when the motor was built there are two possibilities. The easiest way is to measure the length of the filter, If the filter is 2 1/4" long the Part Number is 492932.
If the filter is 3 1/4" long, the Part Number is 491056.
Posted on May 25, 2009
miket756
  • 2702 Answers
SOURCE: My Briggs & Stratton Diamond I/C 13.5 HP has
it could be worn out piston rings letting unburnt fule past into the sump oil
Posted on Jun 20, 2010
Testimonial: "Thank you for theinformation. I did suspect it may be the Piston Rings but I always thought you would get heavy smoke from the exhaust if the rings were going??"
SOURCE: rally ride on lawn mower not starting. briggs and
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
Posted on Jul 29, 2010
  • 130 Answers
SOURCE: 24 hp Briggs Stratton sears
If the mower starts and continues to run after injecting, you may want to make sure the choke is working properly. If the choke plate is not closing all the way, it will make cold starts difficult.
Posted on Feb 12, 2011
Testimonial: "thanks for the help the choke was open just a little"
  • 3074 Answers
SOURCE: what is the battery voltage
same as a vehicle 12 volts, you can use a pair of jumper cables and use you vehicle to jump start it. Good Luck Tim
Posted on Mar 13, 2011
Engine won't stay running. Seams to turn over fine but acts as if it is not getting fuel.
Have you checked the sediment bowl for water? Possibly there is some bad gas if you have let the mower sit for months with gas in the tank. If you empty the gas tank and start fresh. Also add about a tablespoon of acetone to a full tank . If you're having a fuel issue this will fix it. If not then the carb needs to be rebuilt.
Sep 26, 2014 | Murray Garden
I have a murray riding mower, 10hp, 30'' I filled my gas tank and 2 days later the gas was gone. but I did not see a leak. in the tank
check to see if gas running out of carberator also check your oil make sure gas is not in there if it is or fuel running out of carb replace needle and seat in carb check for cracked seam on gas tank also make sure fuel line not leaking
Sep 15, 2014 | Garden
Murry ride on mower manual 145ic/102
hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. that model number is not working and it is a sentinel by murray,,
Feb 15, 2012 | Garden
Who stocks spare cutter decks for a murray sentinel 30" ride on mower
check with a Murray or Briggs & Stratton dealer for avalibility, Have model I can check for ya. Murray went out of biz and was took over by Briggs 5-7 years ago. If ya find one you may not like the $$
Sep 04, 2011 | Garden
I need a diagram on how to fit a cutter deck belt for a murray sentinel 15.5/ 106. Belt number 037 x 88 Keith
The routing is usually pictured on the belt cover such as in your picture. If you send me the model no. to the rider, I will verify proper routing.
Feb 11, 2011 | Murray 38 Lawn Mower Blade Belt '90'96...
Gas is spitting out the exhaust when I try to start the mower. If it does come on it doesn't stay on long.Can anyone help me solve my problem ?????
sounds like the engine has wet sumped and is extremly full of diluted oil / petrol
does your oil smell like petrol and is very thin if wet sump indicated
remove tank and carb , clean tank, clean carby and replace fuel needle and seat - check float for hole reset fuel level and reassemble , adjust governor , drain and refill engine oil and replace air filter and plug, , check valve clearance and reset iff need
might pay to fit in line fuel tap too
have a look and let me know what you found
cheers paul
Aug 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
