Question about Kenwood Sirius KTC-H2EC
My Kenwood Mod H2E Sirius Satellite Radio no longer gets a signal
Hi, When I turn on my three-year old Kenwood Model H2E Sirius Satellite radio you just see the word ''Sirius'' flash by on the screen and all you hear is a beep every six or seven seconds. I tried calling Sirius to do a reset and I tried turning the power on and off many times and I tried using a different antenna but nothing works. Can you help? If not, do you know any place in Southern California where they can fix it?
Thanks!
Mark
  • 5 more comments
  • Anonymous Feb 01, 2009
    Funny, I came onto this site searching for a solution to the EXACT same problem!?!
  • dobrien504 Feb 01, 2009
    Funny, I have ethe EXACT same problem! COuld it be because of the XM merger? Or is it something to do with the FCC making Sirius use a less powerful trasnsmitter? I heard from a salesperson at Best Buy that the FCC came down on them because of the signal bleeding into other cars in the near proximity.
  • Anonymous Feb 07, 2009
    I have th exact same problem too.
  • duece105 Feb 10, 2009
    I have the same problem also. Time to get a new radio I guess.
  • bad101bnc Mar 06, 2009
    I have the same problem . I wonder if sirius did this? Did any one have a lifetime subscription on there radio.
    Walt
  • mjndugg Mar 07, 2009
    I had the same problem last summer and after a couple of months with no Sirius I bought the Stratus as it was the cheapest solution. While I had no car sirius, I still could log on and listen online.
    I was immediately suspicious as was one of the other guys reporting the same problem with the Kenwood H2E, that it had to do with the FCC and the power of the unit bleeding into other cars.
    ...pretty sleezy if Kenwood/Sirius could actually cause the radios to 'fry' upon command.. or be pre-programmed to self destruct after a certain length of time in service. I'm now suspicious about the Stratus and how long will this one last???? At least with AM and FM the radios built 50+ years ago still pull in the signal, and you can get them repaired if they die!!!
  • joegramont May 18, 2009
    Same problem has any one found out why this is happing.
     Mine just started doing this today  May 17th 2009
2 Suggested Answers
SOURCE: My Kenwood Mod H2E Sirius Satellite Radio no longer gets a signal
Debi Mann from Temecula/Murrieta?
Posted on May 29, 2009
Have sirius and hands free phone features with sirius antennae. I do not get good signals from local FM or AM Radio stations. Why?
Sirius is a satellite biased service , so it uses a satellite antenna , local stations how ever don't use that antenna and use a dipole antenna , are both type antenna's connected to your radio , lots of installers don't bother to connect local antenna to new radio installs , im mean you got Sirius why'd you want local stuff anyway is there thinking
Oct 20, 2015 | Kenwood Car Audio & Video
I just bought a 2007 Dodge 3500 Laramie and signed up for Sirius radio. I gave them the 12 diget number that came up on the radio screen (channel 184) and when they tried three times to activate it nothing...
I bought a used 2008 Ram 1500 SLT Sport; satellite would stay stuck on channel 184 with no sound, etc.
Solution: Disconnect negative wire from vehicle battery; wait 1-hour then reconnect. This clears satellite radio cache (a.k.a. hard reset).
Turn on satellite radion; Call Sirius support to send activation signal. Wait on phone with tech support; may take them 2 - 3 tries to get signal to take on radio.
Aug 21, 2010 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Unit keeps beeping and turning itself on and off. Have had this radio for 5 years and never a problem until now.
Hi sasutton,
SIRIUS-Ready radios are usually identified by the SIRIUS dog symbol appearing somewhere on the radio itself. A SIRIUS-Ready radio is a radio that may require the purchase of a SIRIUS tuner in order to be activated.
Every 90 minutes if you do not interact with the player, player display a notice and play a small audible alert to ask if you're still listening to the player. If you're not, the player will shut down after five minutes of the message being up there. If you are there, all you have to do is click the button and you can continue listening. Sirius player do this so that we're not streaming to computers that have no listeners, to maintain optimum performance for active listeners. You are probably not sitting at your computer when this message pops open which is why you get interrupted.
And Thanks.
Mar 19, 2010 | Kenwood Here2Everywhere SIRIUS Radio...
2-3 years old, acquring signal, not ant-error,
Do you get audio out of the stereo jack? Do you have the proper antenna with TWO leads for TERR and SAT ? It could also be as simple as your antenna alignment not being to the SW, or you could have had a local repeater get shutdown. Also, this radio is several years old (designed in 2001) and could be 'shot' already from heat damage as these get really hot. I would try the radio in the car with a car antenna perched on the roof and see if it works; if it does, then it's your antenna alignment. Good luck my friend and report back please.
Jan 09, 2010 | Kenwood KTC-H2A1 SIRIUS Radio Receiver
Doesn't receive and displays "acquiring signal"
The "hideaway tuner" is bad. On the antenna input board there is a cold solder joint and it looses it's ground. If it's out of warranty you can get a rebuilt tuner on Ebay for about 50.00 This has been a huge issue among sat radio users for the past three years. The rebuilt units are better than the new ones. Hope this helps
Jun 23, 2009 | Sirius Satellite Radio Sirius Sportster...
Lost ESN number in Kenwood Radio
It would help if you supplied the model number of the radio?
Thanks Leadispenser
Aug 27, 2008 | Car Audio & Video
Sirus radio
I had the same problem and I replaced my car antenna. That resulted in immediate signal improvement. But three months later, the same thing. So, another dot micro car antenna. Three months later, the signal went out again. The home kit worked perfectly. In my case, I bought a Sirius outdoor home antenna and replaced the standard indoor/outdoor antenna that came with the home kit. I took the home kit antenna and connected it to my S50 car kit and positioned the antenna on the front of the dash. No problems since then. Not one. Those dot antennas are horrible. I'd check that before getting a new radio.
Jan 13, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Unit is not locking onto signal
Check your antennae installation. Mine was frayed and I had to buy a replacement for the car.
Apr 17, 2007 | Kenwood Here2Everywhere SIRIUS Radio...
Satellite No Longer An Option on My Kenwood KDC-MP228
Your going to need to pull off the battery cable for about 2 to 5 minutes and see if this will reset the radio. Good Luck
Mar 23, 2007 | Kenwood KDC-MP228 CD Player
Kenwood Sirius KTC-H2EC Logo
520 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
