Kenmore washer model 16962502 will not spin at all times and can hear clutch kick in sometimes
Lid switch is ok. clutch wii not activate at all times. if it does it will spin
Jimster
  • 240 Answers
SOURCE: Kenmore Series 70 Washer Model 110
That would be your lid switch that has went bad.  Remove the console caps, then remove the two screws that hold it down (sometimes these screws are in the rear of the console)  Rotate the console out towards you gently, then fold it up and over the top of the unit.  You see 2 gold colored hold down clamps on top, and either side of the unit.  You will also see a wire and disconnect going down through the cabinet on your right hand side.  Disconnect these wires (be sure unit is unplugged) and rotate the whole cabinet towards you.  You remove the two screws that hold the switch in place and a 5/16" screw underneith that holds the ground wire.  Unclip the connector from the rear top of the cabinet and remove the switch.  Be sure to bring your whole model number 110.************** when you get the new part, there are two of these, and they look the same except the wire ends are different.  Good luck    Jim
Posted on Oct 17, 2007
watugot
  • 290 Answers
SOURCE: Kenmore 80 series won't spin
If it is draining then the motor is turning the pump so it is ok.
This washer has no belt so that is not the problem.
Remove the cabinet and bypass the lid switch wires and put into a spin. Watch the clutch to see if it is turning. If the clutch housing is not turning and you know for sure the coupler is not broken then you need a new transmission. If the clutch housing is turning but the basket is not spinning you have something binding the basket or you need a new basket drive and clutch.
If you have only looked at the coupler from underneath you may not be able to tell if it is broken in the center. If it is broken again your transmission is not staying in neutral drain until the water is drained. That means it is going into spin with full load of clothes and water. This puts a lot of pressure on the coupler and causes them to fail prematurely. If this is the case you will need a new transmission.
Post back if you have any questions.
Posted on Nov 05, 2007
the dr
  • 447 Answers
SOURCE: Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Posted on Jan 23, 2008
SOURCE: GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Posted on Sep 04, 2008
  • 1937 Answers
SOURCE: My kenmore washer 80 series model 110.23832100
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23832100
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is an illustrated guide for how to access the console.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=5f1af8349a77f9dc5632b02160e0d6c6
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on how to bypass the lid switch and on the transmission.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If the washer will drain but not spin the problem points to the Neutral Drain Assembly in the transmission.
The Whirlpool PDF has a very good explanation of how the assembly works.
Ours had the same problem, no draining or spinning unless the washer was stopped and restarted.
We replaced the neutral Drain Assembly for about $15 vs. $170 for a transmission.
If the Lid Switch is OK, please re-post a request for how to replace the neutral assembly.
Posted on Nov 19, 2009
I have a Kenmore washing machine: Model 110 20722990. When it gets to the final spin cycle sometimes it works sometimes it doesn't. You can hear it going but the agitator is not moving and it does...
ok first, i need you to do a little test,,,put unit on final spin ,does it spin at this time ,,yes so pick the lid up every so lightly ,,did it stop ...put the unit in final spin again unit does not spin push down on unit lid and it spins..in both cases you have a bad lid switch.,,the part # is 3949238 the picture is how it look,,if you need help installing just repost...good luckonthejob5130_1.png
Sep 09, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore 44152 3.5 high capicity washer will not spin
Open the lid of the washer and let it down gently to see if you hear a click when it closes. There is a lid switch that sometimes fails and prevents the washer from going into a spin cycle. If you don't hear the click when the lid closes, then you may need to have the lid switch replaced.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Washing Machines
Kenmore washer will do everyything but final rinse
Sounds like a lid switch to me. The symptoms you describe are often caused by a lid switch malfunction. The switch may be loose or not making good contact. As you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it.
Replacement parts can be found at searspartsdirect.com. Just type in your model number and the lid switch will be located under the "Top and Cabinet" heading as item number 11 (part #3949238). The lid strike is listed as item 20 (part #350733). You may also check repairclinic.com. They carry the SAME parts and sometimes offer a better price. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple and inexpensive repair if you wish to accomplish this on your own. A replacement switch usually costs between $25 and $35. I hope this helps you. Let me know if you require further assistance.
NOTE: Future reference (this is just constructive advice), if you are in the habit of slamming the washer lid or placing heavy objects on the it, this will cause damage to the lid switch. In addition, also make sure your washer lid is not bowed. Placing objects on the lid can cause the lid to bow and prevent it from making the proper contact with the lid switch. This will give you the same symptoms.
Aug 22, 2008 | Washing Machines
Washer spins after lifting lid several times
I would bet you have a lid switch starting to go bad. This is a common symptom. This is an inexpensive and simple repair job if you wish to pursue this on your own. If you open and close the lid, you should hear a distinctive "clicking" sound as the lid switch is activated when the lid closes. If you hear no sound, you need to check the following:
Some washers have the lid switch under the right-hand side of the wash tub opening and is activated through a small slot on the wash tub casing rim by a small plastic piece on the lid called a lid strike. If this is the type you have, make sure the lid strike is still intact or the switch will not activate. Check the two mounting screws next to the slot and make sure they are present and tight. These are the mounting screws that hold the lid switch in place. If they come loose it can prevent the switch from activating.
Newer models have the lid switch mounted under the washer casing in the left-hand rear adjacent to the left washer lid hinge. The switch is activated by a rod on the lid hinge. Sometimes a simple adjustment of this rod can correct contact problems.
If you make all these preliminary checks and the switch still does not work, replace it. The following link will give you step-by-step instructions on how to replace the switch:
Let me know if you require further assistance or part sources. I hope this helps you.
Jul 07, 2008 | Washing Machines
Kenmore 70 series
It sounds like you have a bad lid switch. If you open and close the lid, you should hear a distinctive "clicking" sound as the lid switch is activated when the lid closes. If you hear no sound, you need to check the following:
No matter what configuration you have, if you make all these preliminary checks and the switch still does not work, replace it. The following link will give you step-by-step instructions on how to accomplish this:
If you require further assistance, please let me know. I hope this helps you.
PS If you provide me with your COMPLETE model number (located under the washer lid along the tub rim) I can also assist you with locating parts.
Jul 03, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer will not spin
KENMORE 80 SERIES 110.92582110 - NOT SPINNING. I REPLACED THE TRANI, CLUTCH, COUPLER BUT I FORGOT TO PUT BACK IN THE AGITATOR WASHER. IT STILL WON'T SPIN SO WHAT NEXT
Jun 12, 2008 | Kenmore 23822 Top Load Washer
This is a very typical symptom of a lid switch that is either broken or has come loose. If your lid switch is mounted on the right hand side of the lid, make sure the mounting screws are tight and the lid strike is in place (this is a plastic piece on the lid that activates the switch when closed). If your lid switch is on the left hand side in the rear under the washer rim (out of view), you may have to adjust the rod that activates it. For instructions on how to access the lid switch and/or replace it, click on the following link:
If you need further assistance, please post back and let me know. You can also go to my profile and use the "Ask Me" feature for a quicker response.
May 27, 2008 | Kenmore 22422 Top Load Washer
Kenmore model #110.22802100 drains but no spin
If it is draining, then the motor is ok.
If it is agitating properly, then the motor coupler is ok.
This leaves the gearcase, clutch, basketdrive(brake), basket drive block, or timer.
Raise the lid and hold the lid switch down. Start a rinse cycle and let it go through the cycle. It should drain the water, then stop the motor for a split second then kick the motor back in and start spinning. If it doesn't drop out that split second then the timer is holding it in neutral drain. You can recreate this by letting it start draining, then let off the lid switch, then depressing it again. The basket should start spinning. If not,
Raise the lid and hold the lid switch closed. Start it in spin and see if you can get it started spinning by hand. If so you probably have a slipping clutch.
Post back with any questions.
You can go to sears.com, click on parts, and enter your model number and see parts diagrams of the washer. This can be helpful.
Nov 25, 2007 | Zanussi F1045W Front Load Washer
Spinning problem
Following your description the problem is with the lid switch. Get an access to it and find out whether something prevents his smooth movment,its has a loose wire connection or the switch is malfunction and should be replaced. Good luck!
Sep 04, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
