Question about Boating
I have a Lowrance X65, when you power up the unit the screen shows LCD test mode. you have to hit exit twice to get the unit to a full screen mode. However, the unit does not remember any of teh settings such as temp, fish ID, MPH. What can i do?
  • Larry Burke Jan 24, 2013
    The unit works fine after you hit the exit button twice. This sends the unit back to the full screen mode, only problem is you have to reset all your settings, such as fish ID, Temp, Speed. once you turn the unit off it will go back to the LCD test mode. Then you have to reset all the settings each time you power doen the unit.
    Champion:
    New Friend:
  • 227 Answers
Try doing what they call a soft reboot on your unit sets all your settings back to factory settings
Posted on Dec 25, 2013
  • 18 Answers
SOURCE: problem with interference lowrance x25fishfinder
Transducer will stop getting readings if it gets air under it. If it's lower surface is too much above or below the bottom of your boat, this can happen.
Posted on Jun 18, 2009
hydetech
  • 113 Answers
SOURCE: proper set up for lowrance sonar
Where do you use your boat?
There are so many variables it's hard to fit it all here, but there are some excellent tutorials on the Lowrance website. The most important thing is to pick the right frequency, for the depth of the water. (200khz for less than 70', and 50 khz for greater depths). Depending on how serious you are about fishing, there are a lot of extras that you may never use. The key is to figure out which features will help you the most and forget about the rest.
You may also get some help at this link: FixYa Service Directory
It's common for SONAR to lose contact with the bottom at high speeds. The better the transducer installation, the faster you can go. Turbulence and bubbles will cause the SONAR to drop out. Lowrance's transducer installation guide explains it very clearly.
Posted on Jan 08, 2009
  • 30 Answers
SOURCE: How do you get the fish to show up on the screen
Are you looking for the little fish symbols?
Press MENU, down arrow to SONAR FEATURES and press ENT. Arrow to FISH SYMBOLS and press ENT. Press EXIT twice. Any significant return in the water will now show up as a fish symbol.
Are you looking for the fish arches?
You won't get any arches unless the boat is moving and of course there are fish passing within the transducers signal. The shallower the water, the less area you are covering and less likely to get a fish return.
There is an OK guide to understanding what you see on the sonar screen at the link below. It if pretty technical but parts of it may help you out.
http://primus.lowrance.com/support/resultDisplay.do?gotoLink=5&docType=1000&contextId=351%3A5.47%2C11918.11930%2C22.47&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FSonar&contentId=9de88fa2-0b60-4b44-a470-29ee14767b3e&responseId=135ccbe2cfd4f608%3A1fe88d%3A122773df7e0%3A7c2&groupId=4&answerGroup=1&score=981&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FSonar%2FChart+Tutorial.htm&result=0&excerpt=Chart+Tutorial+Deciphering+Sonar+Charts.&question=chart+tutorial&resultType=5000#Goto5
An X96 owners manual can be downloaded from http://www.lowrance.com/en/Downloads/Manuals/
Posted on Jul 14, 2009
SOURCE: lowrance model 3500 digital depth sounder, unit is
i have the same problem can someone help
Posted on Mar 29, 2010
  • 12 Answers
SOURCE: When we are deep water
Im not familiar with your particular unit but you should be using a low frequency transducer for water over 500'; something like a 50 kHz transducer or a dual frequency transducer like a 50/200kHz for detail with the high freq. but increased depth range on the lower frequency. As far as setting it to 250 ft, you should be able to use the range feature and adjust the maximum to 250'. typically the factory default is automatic so it will caonstantly adjust the range based on the maximum current depth.
Posted on May 23, 2011
Lowrance x65 power issues
charge the battery
Mar 29, 2014 | GPS
The GPS component of my Lowrance Elite-5 Gold is malfunctioning about 50% of the time.
Hey Les, Since you have replace both the unit and transducer, you have eliminated/diagnosed most of your problem.. Its in the wiring... sometime when I am in full GPS mode I get erroneous depth readings..?? Have you tried a different GPS module (the "puck")?
https://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5-7_HDI_OM_EN_988-10647-001_w.pdf
Apr 22, 2017 | Lowrance ELITE 5 GOLD COMBO
I hit menu and it comes up but i hit it again for main menu and it just goes back to screen i have no main showing
Reboot procedure from from Eagle tech support:
1. Turn unit off
2. Press and hold pages key
3. Press and hold power key at same time
4. Unit will power up. Wen map appears, release both keys.
5. Press exit 3 times
6. Press the menu key twice and it should now access the main menu
May 30, 2011 | Eagle Fishelite 642c Color Fishfinder Gps...
LOOKING FOR MANUAL LOWRANCE X65
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/X65.pdf
May 23, 2011 | GPS
I have an older Lowrance, Model X65, which until a few weeks ago worked as if still new. I hadn't used the boat for the past few weeks and when I did the Lowrance screen now has a large brown spot in...
You need to contact Lowrance about the repair.
My really older, but loved, unit failed and Lowrance pointed out that techonlogy is SERIOUSLY imporved, and convinced me to upgrade to a new unit. I disliked the price, but LOVE THE unit. TONS easier to read, even in bright sunlight, depth sounder portion much improved...twin beams really makes accurate reading, and fast readings (unlike older units).
May 08, 2011 | Lowrance Boating
I have the code but only says on screen that it is waiting? on my kenwood kdc 6090r
• Security-related information
1. Forced Power ON mode (All models)
Even when the security (Mask key) is approved, resetting
the unit while holding the ATT and Preset 4 keys makes it
possible to turn the power ON for 30 minutes. After 30
minutes have elapsed, it is not possible to return to the
previous condition unless the unit is reset again.
2. Method of registration of the security code after EEPROM
(Tuner Unit ***'y) replacement
(Code security model)
(1) Enter the test mode. (See " 1. How to enter the test
mode")
(2) Press the CLK key to enter the security registration
mode.
(3) Enter the code using the Preset 1/2/3/4 keys.
Example: To enter "3510"
• Press the Preset 1 key 4 times.
• Press the Preset 2 key 6 times.
• Press the Preset 3 key twice.
• Press the Preset 4 key once.
(4) Press and hold the DISP key for 3 seconds until
"APPROVED" is displayed.
(5) Exit from the test mode. (See " 2. How to exit from the
test mode")
(Note) All Clear is not applicable to the security code of
this model.
3. Simplified method of clearing the security code (K Type
only)
(1) While the code entry is requested, press and hold the
VOL UP key for 3 seconds while holding the DISP
key pressed. (This should turn "----" off.)
(2) Enter "KCAR" from the remote. (Same way as the 00
model)
Press the 5 key on the remote twice, then press the
Track Up key. (This enters "K".)
Press the 2 key on the remote 3 times, then press the
Track Up key. (This enters "C".)
Press the 2 key on the remote once, then press the
Track Up key. (This enters "A".)
Press the 7 key on the remote twice, then press the
Track Up key. (This enters "R".)
(3) The security code is cleared and the unit enters the
ALL OFF mode.
(4) If you commit a mistake in the code entry, the unit
enters the code request mode again.
4. Method of writing the Mask key while the EEPROM is in
the initial status
mode")
(2) Press the CLK key to enter the Mask key registration
mode. "TRANSMIT1" should be displayed now. The
display at this time should show " < > " in place of " [ ]
(3) Point the Mask key remote toward the light sensor,
and press and hold its key for more than 0.5 second.
(4) When "TRANSMIT2" is displayed, press and hold the
key on the Mask key remote for more than 0.5 second
again. The first and second counter codes are not
compared at this time.
(5) When "APPROVED" is displayed, the write operation
is complete. Now the demonstration mode is initiated
and the test mode is terminated.
(Note) In the same way as previous models, if 30 minutes
have elapsed with no code written, an error occurs
and the power is turned OFF.
5. Method of initializing the Mask key
(How to reset the unit from the Mask key approved condition
to the factory condition)
mode")
(2) "TRANSMIT1" is displayed and the Mask key entry
request mode is initiated.
The display at this time should show " ∗ ∗ " in place of
(3) Press and hold the key on the Master key remote for
more than 3 seconds.
key on the Master key remote for more than 3 seconds
again.
(5) When "APPROVED" is displayed, the Mask key is
cleared, the demonstration mode is initiated, the test
mode is terminated and the unit returns to the factory
condition.
6. Method of clearing all Mask key-related data
mode")
(3) Point the Master key remote toward the light sensor,
and press and hold its key for more than 3 seconds
(until the level display shows the full condition).
(4) When "TRANSMIT2" is displayed, hold the key on the
Mask key remote for more than 3 seconds again.
If "TRANSMIT1" is displayed in place of "TRANSMIT2",
restart the procedure from step (3).
(5) When "APPROVED" is displayed, all security data is
cleared and the unit returns to the condition before
Mask key writing with the EEPROM in the initial status
Apr 05, 2010 | Kenwood KDC-6090R
Hello- My 332c will not show speed. It worked before.The spinner wheel is not damaged.Speed just flashes 0.00 mph Thanks, Jeff
Try setting up the speed in the overlay data menu again:
1. Press MENU, arrow down to OVERLAY DATA and press ENT
2. Highlight the option for speed (WATER SPEED or GROUND SPEED) and press ENT
3. Highlight the REMOVE button and press ENT
4. Highlight (PRESS ENT TO ADD) and press ENT
5. Arrow down to SONAR DATA and press ENT
6. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box
7. Press EXIT twice
If the speed is still flashing, the data is still invalid. Try resetting the unit completely:
1. Turn unit off
2. Press and hold the PAGES and POWER key until the "DO NOT RELY..." alarm appears
3. Set up the overlay data for speed again: 1. Press MENU, arrow down to OVERLAY DATA and press ENT; 2. Highlight (PRESS ENT TO ADD) and press ENT; 3. Arrow down to SONAR DATA and press ENT; 4. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box; 5. Press EXIT twice
If the speed is still flashing, good chance the speed sensor is bad even though the wheel still spins. Install the latest LMS-332 updates from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/ and set up the overlay data again.
If it turns out that the speed sensor is bad, just use speed from the GPS. This can be set up from the overlay data menu as GROUND SPEED.
(note: the overlay data must be set up for each page individually. So if you set up speed to be displayed on the map screen, it will not also be set up on the sonar page)
Jul 12, 2009 | Lowrance LMS-332C GPS Receiver
How do you get the fish to show up on the screen on a lowrance X96 depth finder? We just got it and there is no manual with it.
Jul 11, 2009 | Lowrance X96 200khz Fishfinder
How to reset my copy counter to my kyocera km-1500
Sorry you cannot reset your counter if you pass the 10,000 copies, if you are under you can, but just to let you know that you can reset the counter only for 1 time, you can do that by entering the maintenance mode of the machine and reset the counter.
hit 1087 twice it let you go to maintenance mode then start touch the screen up or down till you see the counter life reset, then hit start buttom, then highlight the buttom that come on the screen and hit start or reset and u will be fine.
to exit the maintenance mode hit reset buttom twice till you see 000 on the screen, then hit number 1 then start.
Best regards
Mar 01, 2009 | Kyocera Mita Office Equipment & Supplies
Cannot access main menu or pages screen
I think I can help with your issue. I have an LMS 334c and have had a few issues in the past. Called the factory (this answer is not listed any where in your manual) and they instructed me to "Soft Re Boot" my unit and it would put everything back to factory settings. Try this anytime it does not respond for whatever reason.
Turn the unit off.
At the same time press the Pages and Power button. Hold both down until you see the square box come up in the screen. You should have your factory settings again. May need to try a few times.
Lowrance said it works just like a computer, ever now and then it just tries to disect to much information at one time and hangs up.
Good luck. James Cantwell
Nov 03, 2008 | Lowrance LMS-330C GPS Receiver
Boating Logo
99 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
