My lap gets switched off automatically when i played Pro Evolution Soccer
4 years old. Recently i changed my BGA IC. 512mb graphics ATI RADEON 3200 3GB ram
  • Ashish Deepak Jan 23, 2013
    Thanks brian for your answer,i thinkk playing high end games may have caused the problem since mine is an on-board graphics
  • Brian Sullivan
    Brian Sullivan Jan 23, 2013
    no problems if you dont want to install more ram you could unindtall some unnecessary programs also Using a flash drive as RAM is a quick, easy and cheaper way to increase system memory.Insert your flash drive into a USB port. If you have auto-play enabled, there should be an option in the menu that appears that says, "Speed Up My System" that will allow you to enable ReadyBoost. Click the "ReadyBoost" tab.To use the entire flash drive to increase RAM, click "Dedicate this device to ReadyBoost." To use less than the entire flash drive for ReadyBoost, click "Use this device" and move the slider to the amount of space you would like to use.Click "OK." Right click the drive letter, and choose properties. Look for the ReadyBoost Tab, and select it. Look for the option to enable the flash drive as RAM, and allocate the amount of space on the drive you wish to use as RAM. Remember, most systems max out at 4GB RAM. So if you have a drive larger than that, or 2GB RAM already, you need to remember this limitation so as to prevent damage to your system.
  • 27,725 Answers
When you are playing games you use a lot of the computers resources.
If you are playing games that use lots of graphics. You might not have enough computer ram installed running your computer over its limits placing to much strain on the cpu central processing unit causing memory dumps and crashes.
If you're not sure if a module is right for your system, use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible. Hope this helps.
Posted on Jan 22, 2013
3 Suggested Answers
issken
  • 1472 Answers
SOURCE: The ATI Radeon 3400 HD goes in an infinite loop
jrz3305
To bee able to properly address your BSOD I will need some info from the BSOD. The link below will show you the info that I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Thanks
Issken
Posted on Mar 29, 2010
arjoon
  • 113 Answers
SOURCE: cannot install final cut pro.....the software says
yes it seems that your laptop dose not meet the minimum requirements to install final cut pro software.you will need to purchase a laptop with the correct requirements,sorry.
ken
Posted on Apr 04, 2010
I cant play resident evil 5,,it has but no video coming out
Unfortunately, your graphics card does not meet the requirements for RE5. You need at least a Radeon HD 4650 to play it.
Jul 23, 2011 | ATI RADEON X1600 Pro 512MB PCIE Graphic...
ATI Radeon X1650 Pro overheats and videocard shuts down
check if the games take too much memory so that the card not able to work, if you used to play it before without problem, check the card fan if its working,and at the same time check your computer cooling if its cool enough.
Jun 14, 2009 | ATI RADEON X1650 Graphic Card
Cant get my new graphic card to work
You need to install the drivers. Go to: http://support.amd.com/us/gpudownload/Pages/index.aspx Fill in the fields, download the full package of drivers, and install them. Now your games should work. I hope this helps, Yannick.
Jun 12, 2009 | ATI RADEON X1650 Graphic Card
My HIS Radeon x1650XT hangs after playing 3D Games.
change your graphics card or you may upgrade your card.
Jun 03, 2009 | ATI RADEON X1650 Xt, (256 MB) Graphic...
CONNECT 3D RADEON 9550 256MB display problem
That graphics card i'm afraid is not good for todays games, same thing goes for your pentium 4. A driver update may fix your problem but that card and cpu need changing, probably a new motherboard would be needed also to fit a pci express graphics card along with a core 2 duo processor.
May 25, 2009 | ATI RADEON HD 2400 PRO Graphic Card
CANNOT FIND GRAPHICS CARD INFORMATION
Reinstall. Go to www.ati.com and select the driver for your operating system. They use a one driver for all cards approach
Apr 26, 2009 | ATI RADEON X1600 Pro 512MB AGP Graphic...
Screen going blank for a second or two while video freezes then jumps.
If you have on board graphics try removing video card and reboot when computer rebooted turn it of and refit card and restart when restarted computer should recognize new hard ware and should find the already installed drivers if not try installing drivers again
Sometimes windows does not recognize new hardware until its refitted
had this problem with modems alot and the above method solved it
Jul 31, 2008 | ATI RADEON X1650 Graphic Card
Is My Computer Compatible With New Graphics Card?
You need to know if *********** board supports PCI-E, since your new VC is an PCI-E device. Check the mobo's manual if this can support PCI-E, if it is then it will be compatible (the next thing is the OS, check if the card supports your OS).
Jun 07, 2008 | ATI RADEON X1650 Pro, (512 MB) PCI...
Not getting ATI Radeon 512MB graphics card
Go for :
ATI Radeon X1650 Pro 512MB AGP
ATI Radeon X1600 Pro 512MB AGP
plz rate me if this info is helfull to you... Thanks
May 14, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
