Question about HP PSC 2355 All-In-One InkJet Printer
I get an error messege (carrige jam)
Some time I get the error messege carrige jam, but there is no jam that I can see,a little wile later it prints ok.
can you help? HP PSC 2355 all in one printer- scanner- copier
I have found that when I slide back the carriage to the left by hand and expose the bottom right hand side, there has been an accumulation of ink that is preventing a part from sliding from front to back. Inspect the bottom right hand side where the black and color cartridges normally sit. You will find a flat sliding piece directly beneath the position where the cartridges normally sit, that will not slide forward to the front of the printer and back towards the back of the printer easily because of the ink that has accumulated and is causing a drag. I used q-tip swabs and some alcohol and cleaned out the rails that the piece slides in. Use a flashlight to inspect. After cleaning it appears that it is printing normally again. Repeat the process as needed. Bob in NC
Posted on Jan 28, 2009
Printer screen showing paper jam. There is no paper jam.
Hi, this is a well worn path.
I know its a bore, but follow this, with your CSI Torch open up the rear access covers and look in carefully look. Satisfied replace cover, lift scanner lid, again using your CSI Torch check out the print area for a little peice of offending paper, if needs be try moving the rollers but gentle.
If no, left side hidden away, gentle move the print head carrige to the left there is every possibilty you will find a sodden inkedpeice causing the problem.
If still no paper, then as a lasrt resort reinstall the printer prog, it could be corrupt.
Did you have a paper jam that cased the original error message, if so then the odds are there is a little peice causing the problem. Good Luck.
Peter.
Feb 10, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
It keeps reading 'carriage jam, close door then press ok ... ' it will not stop.
If you open the printer cover you should be able to see a guide bar where the print carrige runs, if you can touch it feel if it is dry, if it is very dry (it may have black residue) then you will need to wipe the bar with a tissue or rag to clean it and then with a toothpick carefully add some singer oil (Machine Oil) maby 4 -5 drops along the bar, and slowly move the print carrige over the newly oiled section this should lubricate the bar again and stop your carrige jam issues
Feb 09, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Carriage jam
You could try clearing the jam and then removing power from the printer altogether to re-initialize the printer. However, if that fails either the printer diagnostics chip has gone awry or you have a virus.
Oct 28, 2009 | HP Photosmart 4180 All-in-One Printer
My ink jet cannon printer MP600 is saying i have a paper jam there is no paper in it and it is still saying this and wont let me access any other functions or print
Recheck all jam clearing areas on the machine. Open doors, reseat the doors. Check for safety interlock switches, they are small and hard to find.
make sure the acuators are still in place, on the switches.
With the power off, move the ink carrige over left and right make sure there is no paper back there.
Make sure the carrige comes to its home position.
Other than this, possibly malfunction sensor or main board problem.
Oct 15, 2009 | Canon Office Equipment & Supplies
Carriage Jam - HP Officejet J3680 All-in-One
the silver bar the carrige slides on has lost all its lubrication. Try putting some chapstick on the silver bar
Sep 30, 2009 | HP Officejet J3680 Multifunction Printer...
Carrige Jam
carriage assembly defective..uneconomical to have repaired. Sorry
Jan 26, 2009 | HP PSC 2355 All-In-One InkJet Printer
Carrige and paper jam at the same time
The paper jamming is the result of the carriage problem. The paper is starting to feed and then carriage problem -- so paper jams. Look in the optical cavity and see where the carriage is stopping. You can take off the platen glass ( about 3-6 screws) and see if you can remove or fix the hang up.
Dec 30, 2008 | Office Equipment & Supplies
HP6200 all in one printer "carrige jam clear carrige jam then press ok" There is no carrage jam or any other jam that I can determine. When turned off for an extended time then turned on it...
In order to help you better let me provide you a web-link to a web document which has clear graphical representation of the solution.
Click on the link below to open webpage and follow all the steps given in web document:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00304007&dlc=en&lc=en&jumpid=reg_R1002_USEN
Thank you.
Nov 28, 2008 | HP Office Equipment & Supplies
Carriage jam
This can be many things, but inspect the paper path for anything stuck. remove the cartridges with printer off and see if you can manually move the carriage you may need to force it a little but not allot, sometimes it may jump a gear causing this error.
move the carriage away from home position and turn on, the printer should reset the carriage position.
hope this helps
Jan 07, 2008 | Office Equipment & Supplies
HP PSC 2355 All-In-One InkJet Printer Logo
136 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
