Question about Gateway 450SX4 Notebook
The 450sx4 screen is bright but no video
My laptop computer screen is bright but cannot see any video or graphic information. Gateway 450sx4 is the model
  • Gateway Master
  • 5,660 Answers
Http://support.gateway.com/s/Mobile/Gateway/450SX4/3501271nv.shtml
Diagnose skybib05
See if the problem is the graphics chipset, or Video Cable, or inside the Display Assembly.
Graphics chipset:
Laptop OFF, monitor OFF, connect a VGA monitor to the VGA connector (port), on the laptop.
This is a general example of a VGA Cable, and VGA connector,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for the VGA Cable example
Connect to the Blue VGA port on the back of the laptop.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable attached.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the same time tap once on the F3 key.
[The F3 key is the Display Toggle-Over key ]
Still no display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F3 key.
Display on external VGA monitor, looks like the display on the laptop's internal monitor; means there is a graphics chipset problem.
Most of the time it is not a bad graphics chipset.
The problem is the MOUNTING of the graphics chipset TO motherboard, and this is caused by inadequate cooling for the graphics chipset.
If this is found to be the problem I will go into more detail.
I doubt it, but this is Not a guessing game. We are following a diagnostic flowchart.
Good graphics on external monitor?
Problem is the Video Cable, or inside the Display Assembly.
Video Cable:
This is an example of the Video Cable,
http://laptops-we-r.com/Category2/400,%20450,%20600,%20M305,%20M350WVN,%20600%20LCD%20VIDEO%20CABLES.htm#GATEWAY%20LCD%20VIDEO%20CABLE%20DDOOA6LC609
The Black plug connector at the Top plugs into the back of the LCD screen.
The White plug connector to the Left, plugs into the motherboard.
The small black wire next to it with the eyelet, is a Ground wire.
The long cable going towards the bottom, connects to the screen Inverter.
The Video Cable connects to the motherboard, in an area under the Keyboard.
It then routes up under the left Hinge, and into the Display Assembly.
From there the long single cable coming from the Video Cable, connects to the screen Inverter, and the main cable goes on up to connect to the back of the LCD screen.
All 3 connections of the Video Cable MUST be checked for tightness. You CANNOT visually check alone. You MUST physically try to plug each connection in more tighter.
All it takes is a hair's width of disconnection. You won't be able to see that.
A) Remove ALL power. Remove the AC adapter (Charger), and Battery.
B) Remove the Keyboard Cover.
C) Remove the Keyboard.
NOTE*
Keyboard:
The Keyboard Cable STAYS attached to the Keyboard. It removes FROM the motherboard connector.
You won't be disconnecting the Keyboard Cable from the motherboard.
All I want you to do is remove the Keyboard, from the Palm Rest Cover; and roll the LCD screen side over, so the Keyboard is laying on the Palm Rest Cover; with the Keyboard Cable still attached.
This way you can get to the motherboard side of the Video Cable connection, and not have to completely remove the Keyboard.
Also, you can re-connect the necessary wires, and test to see if the motherboard connection of the Video Cable; was the problem.
No? Go on.
Next is disassembling the Display Assembly, to check the screen Inverter connection; and Video Cable connection to Back of LCD screen.
I have a Service Manual link I will give later. (Free)
In it I have found there are no details about disassembling the Display Assembly.
Gateway at that time just states to remove Display Assembly, then reinstall the new Display Assembly.
Right.
The plastic frame in front of the LCD screen is the Display Bezel.
Gateway? Term used is probably LCD Bezel, or LCD Panel Bezel.
Looks like this,
http://www.ebay.com/itm/Gateway-600YGR-400SD4-450SX4-450ROG-14-1-LCD-front-bezel-cover-EAOA1004011-/321040328484?nma=true&si=KRo19vXoQw1V7k4dLlmj1aW1IGM%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Scroll down
Here you see 4 screw holes across the Top, and 2 at the bottom corners.
There are Screw Covers over these Philips head screws.
May be made of synthetic rubber, or plastic.
They are held on by a tiny tab of a rubber cement compound.
Use care when taking them off, and you MAY be able to reuse them.
Due to the age of the laptop this may not be so.
All you have to do is carefully remove any BUILD-UP of old rubber cement, apply a tiny tab of new rubber cement with a toothpick, and reuse the Screw Covers.
I use a computer pick to remove them. Whatever you use, be CAREFUL. Don't poke your fingers, or scratch the LCD screen!
Gently pry up at the Bottom of the Screw Cover.
I LIGHTLY stick them to the Display Bezel for safekeeping.
(They also like to stick to your fingers, the removal tool, and it seems passing satellites)
Remove the 6 Philips head screws.
(Use a multi-compartment container for the various screws you will remove. Label each compartment for the area the screw/s come out of. SOME screws look VERY similar to other screws.
Advise DO NOT mix them up)
The Display Bezel is flexible. Made of space-age plastic. Pretty tough stuff, BUT can be broken. Especially due to the age. (Brittle)
Use care when removing.
This video I found should help you in removing the Display Bezel,
http://www.lcds4less.com/laptop-lcd-removal-instructions.shtml
(NO. I DO NOT recommend using a sharp utility knife!)
The screen Inverter is located behind the Display Bezel, and mounted towards the bottom of the LCD screen.
Once the bezel is removed, you can check the Video Cable connection TO screen Inverter.
Remove the screws from the Brackets, or Hinges; on each side of the LCD screen; that allows removal of the LCD screen.
L@@K close.
The metal frame going around the LCD screen is the Screen Frame.
The LCD screen is composed of layers, and the Screen Frame keeps them aligned in the factory set position.
DO NOT remove the screws which hold the Screen Frame together.
JUST the ones that hold the LCD Screen Frame to the Brackets, or Hinges.
Holding the LCD screen with one hand, you want to tilt the Top towards you, to access the Video Cable connection TO the back of the LCD screen.
You can set the LCD screen against the Display Cover, and test to see if this was the problem.
No? Go on.
More in a Comment.
Posted on Jan 22, 2013
  • joecoolvette
    joecoolvette Jan 22, 2013
    Tried physically plugging in the connections of the Video Cable, and this did no good? Do you see apparent damage to the sheath of the Video Cable? If so there may be damage to the tiny wires inside. (Stretched/Broken) Remove the Video Cable. A continuity test with a multimeter set to OHM's (1K), needs to be performed. EVERY wire checked for continuity. No access to a multimeter? Suggest taking Video Cable down to the nearest small computer shop, and have the resident tech check it for continuity. Should only be a couple of bucks. You MUST rule out the Video Cable, BEFORE going on. Video Cable checks out? Screen Inverter is next. The Backlight for your laptop is a CCFL. Cold Cathode Fluorescent Lamp. Similar to Fluorescent lighting used in homes, and businesses; but on a MUCH smaller scale. Average thickness is 2mm. That is a little larger than 1/16th of an Inch. Average length is almost as long, as the LCD screen is in height.http://www.laptoprepair101.com/laptop/20... View the last 8 photos. The screen Inverter converts the power (Electricity) from the laptop, for the LCD screen, and Backlight. It is a small circuit board, located behind the Display Bezel, and mounted towards the bottom of the LCD screen. To test requires a sensitive mutimeter. Read fairly expensive,http://www.fonerbooks.com/test.htm For this reason; the ease of accessing to replace, and the usually low cost; the screen Inverter is just usually replaced. One example,http://laptops-we-r.com/Category2/SOLO,%... Screen Inverter replaced does no good? Then the problem is the LCD screen. For additional questions please post in a Comment. Regards, joecoolvette
  • joecoolvette
    This Gateway 450RGH Service Manual crosses over for your Gateway 450sx4,http://www.tim.id.au/blog/tims-laptop-se... Go to where it states Gateway 400. (400 in Blue) Go across, click on the blue -> 450RGH.
  • Gateway Master
  • 27,725 Answers
Many computer users spend long hours online every day and don\'t realize that looking at a bright laptop screen can be hard on the eyes. If you spend a lot of time in front of a laptop screen, consider reducing the brightness of the screen at the earliest opportunity. There\'s a quick and easy way to perform this task so you can save your eyes as well as your battery power.
Press and hold the "Fn" key on the laptop keyboard. This key is usually located at the top right or bottom left of the keyboard. Press the "Up Arrow" and "Down Arrow" keys, which are usually located in the lower right of the keyboard, to increase or reduce the brightness of your laptop screen. Adjust the level so that you can gaze comfortably at the screen without any glare. Disconnect the battery charger from your laptop and repeat the above procedure. On some laptops, the screen brightness varies considerably, depending on whether or not the device is charged. Hope this helps.
flipbooks
  • 177 Answers
SOURCE: I want to disassemble Gateway 450SX4
Nowhere: Only HP and IBM and DeLL offer parts schematics for their laptops. But if you take a look at some of those,you'll have a really good idea how to work on your Gateway,because they're all very similar.
Posted on Mar 10, 2008
Geekman
  • 32281 Answers
SOURCE: Gateway 450sx4
Yes you should try ito adjust the brightness.
Can you see a slight image on the LCD, screen this indicates a backlight problem?
You can connect an external monitor to the video connector on the laptop, then boot it up and see if the is a display on the external monitor. You may have to press the blue Fn + one of the Function key so you can switch the video output to the external monitor. If you get an image on the external monitor then the video card is OK and the fault is with the LCD backlight. This could be a faulty inverter that supplies high voltage to the CCFL lamp or the CCFL lamp is faulty, 80% of the time it is the CCFL lamp that is faulty.
The inverter is easy to replace, the CCFL lamp requires a lot more work and requires soldering skills.
Go to www.lcdparts.net for parts and/or repair service and DIY info.
Posted on Mar 03, 2009
SOURCE: black screen on gateway 450sx4 laptop
Inverter board. Promise.
Posted on Mar 10, 2009
PaulRepair
  • 66 Answers
SOURCE: need to replace the cmos battery on a gateway 450sx4 laptop.
Some are way deep inside, and you have to remove the top part of the case from the bottom.
Some others, you can remove the top power strip, (unscrew screws in the battery compartment, and sometimes on the bottom) and then unscrew the keyboard, and when you remove that, sometimes you can get right to it.
The only problem is, some of the laptop batteries are odd ducks, and not just the standard, they have wires or a metal tag on them. You can always order a new one onces you get to it.
Posted on Apr 12, 2009
kamal1984
  • 1383 Answers
SOURCE: CMOS battery Gateway 450SX4 notebook
it is in back sdie of alptop.
You have to remove 4 screw on each side of square.
then you find motherbord chipset.
cmos cell is fixed on motherbord circuit.
Posted on Jul 16, 2009
I need a wiring schematic for gateway model 450sx4 lcd screen
The manufacture will not release that information to the general population.
May 29, 2012 | Gateway 450SX4 P4-M Notebook
I have a gateway 450sx4 laptop...im having a problem with my screen. When i turn it on, you can't see anything...i've even tried conneting a monitor and still don't see anything...what else could it be???...
You can try 2 things: 1. Start in safe mode ( start tapping f8 when you start) and see if that works. If it is ok try to update-or reinstall- drivers for your video card. 2. Reinstall OS-whatever you have.If that failed-your video card is probably out.
Nov 15, 2010 | Gateway 450SX4 Notebook
Yea i have a gateway 450sx4 laptop and when i turn it on it stays black for a while and when the screen finally turns on it blurry and its different colors and it just shows lines how can i fix this?
It's likely that your screen is "fried" (faulty) ... try to connect your laptop to an external VGA monitor, and see if the screen shows up (on the external monitor) properly. You may have to toggle the output display (device) from computer screen to external monitor ..using Fn+F3.
If it displays on your external monitor properly, it means your laptop screen is no good. You can replace the laptop screen, or just continue to use the external monitor.
If it does the same (blurry & different color, etc.) on your external monitor, then, your video card/module on your laptop is bad. This usually happens less often.
Aug 11, 2010 | Gateway 450SX4 Notebook
My 450sx4 mysteriously changed the screen resolution from 800X600 to 640x480 & now won't let me change it back. any suggestions?
It is definitely a drivers problem. Some driver files have gone corrupt and you need to reinstall the Video/Graphics driver on your computer. Most probably the drivers would be in the Disk that you got with your laptop, else you can download the latest drivers from the Gateway website.
Aug 08, 2009 | Gateway 450SX4 Notebook
Gateway 450sx4
Mar 03, 2009 | Gateway 450SX4 Notebook
Question regaurding two different gateway laptops
Hi!
I compared them, the on you have is a good laptop, the one you consider to by is not.
The one you have has on mobile prosessor 2,7ghz, the 450 has an pentium4, that will get that laptop warmer and it will consume mote electricity
The 7320 have 512mb ram and you can upgrade it to 1,5gb ram if you want. The 450 have 512mb ram and thats the maximum it can have.
The 7320 has an 15.4 in TFT active matrix 1280 x 800 ( WXGA ) screen. The 450 has 14.1 in TFT active matrix 1024 x 768 screen.
The 7320 has Intel Extreme Graphics 2 Shared video memory . The 450 has ATI Mobility Radeon M6-P 32.0 MB
In my opinion, the only thing thats better on the 450 is the videocard, and that just a little bit better.
So my advice is..DONT buy that 450, there are better laptops out there for a good price.
I hope the info i gave you helped
If you have further questions, just ask me and i will do my best to help you
Good luck
Nic
PLEASE rate me
Dec 30, 2008 | Gateway 450SX4 Notebook
Black screen on gateway 450sx4 laptop
sounds like ,audio card went died or mite be screen has shorted out try hooking it up an orther screen and see if it boots up if so either viedo screen card or screen it self
Jun 02, 2008 | Gateway 450SX4 Notebook
Mar 07, 2008 | Gateway 450SX4 Notebook
Screen becomes jumbled when computer base is handled
It could possibly be the video card, I don't know that much about how hardware is laid out in that model, whether it is an built in card or a connected one so I cannot give you any trouble shooting tips. Do you still have tech support available with Gateway?
Sep 09, 2006 | Gateway 450SX4 Notebook
Computers & Internet Logo
61 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
