Question about ASUS P5N73-AM Motherboard
How to fix front pannal wire like led,Hdd - ASUS P5N73-AM Motherboard
2 Suggested Answers
CreativeTECH
  • 1719 Answers
SOURCE: I dont know how to
Hi!
You have to make make the four Front Panel Connection as shown below: -
(IDE LED is the same as HDD LED and Ground means negative '-')
Hope it helps! Good Luck!
Thanks for using Fixya!
CreativeTECH
Posted on May 31, 2011
The led on the front won't light, and I have power connected, but nothing. Is there a reset somewere?
I am assuming you are trying to power up an installed motherboard, based on the category selection. You say that you have power connected. That means that you have connected the 20 (24) pin main connector and the 4 or 8 pin CPU power connector to the motherboard. Have you connected the front panels controls to the motherboard header? There are connections for the power switch, power LED, HDD LED, reset switch (optional). They must be connected in order for the motherboard to start. THe HDD and Power LED connections are polarity-based, so if you hook them upo backwards, their respective LED will not light. The HDD LED plug is usually red and white with the red being on the positive (+) terminal. The Power LED plug is usually green and white with the green wire going to the positive terminal. The power switch and reset switch wires can be connected either way as they are not polarized.
Jul 14, 2015 | Computers & Internet
Where to fix the power switch,power led and HDD led
There will be a set up pins pointing up from the mother board - usually along one edge, and the cable you have that come from the switches / LEDs on the front panel will fall in the general direction of those pins. If you look very carefully at the writing next to those pins you will see words like PW = power switch, HD LED = Hard Drive LED lights, SP = speaker and so on. You really should visit the motherboard manufactures web site, find your board and download the manual which will show you as well as tell you how to connect up the wires. LET this be a lesson to you! Write down or draw a picture BEFORE you start pulling wires out!
Dec 22, 2013 | HP Vectra VL400 P3 Skt 370 Motherboard...
Can not take off front pannal to get to gasket as the machine is a box with no pannals only small one on the back. zanussi zwf1421w. can you help please thank you.
Washing machines are hard to open. If you have a front loader, you will need to remove the top. Unscrew the rear top screws and slide the top panel towards the rear. Once the top is open, you will need to remove the front screws from the inside! Keep track of want you are doing so you can put it back together, especially the wires. Good luck!
Sep 14, 2011 | Washing Machines
I dont know how to fix the Front Panel Audio Connector. And I dont understand what is ATX power switches. I'll tell you what wire i have: H.D.D. LED, POWER LED +, POWER LED -, RESET SW and POWER SW....
Hi!
CreativeTECH
May 31, 2011 | ASUS P4VP-MX Motherboard
Pulled off front cover. three sets of wires came off. need to know where to reconnect. white/red wire HDD LED, white/green wire POWER LED, white/black wire POWER SW
Hi. You may want to check your motherboard for this wires to connect to, First, check your motherboards manual and look where the FRONT PANEL is located, then on the front panel or in the manual itself it will tell you where are those wires should be connected to. If you dont have the manual for your motherboard search it on google and do the same, and if still you coudnt find it over the internet then just look closely on your motherboard and look for the words HDD LED, POWER LED and POWER SW, usually those words or the FRONT PANEL is located on the left side bottom part of your motherboard. Hope This Helps
Jun 09, 2010 | E-Machines T3302 PC Desktop
I have 3 wires on my pc and i dont know where to connect them on my motherbaord - the wires have writen on them "HDD LED" "PWR LED" "PWR S/W" can any1 help me?
Hi Dan,
The wires are from the front panel. HDD LED which causes an led (usually red) light to turn on when the Hard Drive is active. The PWR LED turns on an LED light (usually green) when you turn on your computer. The PWR S/W turns on your computer when you press the on button of your computer. The front panel connector riser is usually located on the bottom right of your computer. They fit on little pins. Unfortunately there is no standard, so connections vary. Sometimes the pins are labeled on the motherboard. . Check your manual. For more info do a google search for "Motherboard front panel connectors". Hank
Mar 12, 2010 | Intel Computers & Internet
T6410 EMACHINE TRYING TO CONNECT START BUTTON
The motherboard in your computer is an MSI MS-7145, which is also called RS480M. You can download a copy of the manual here. The front panel connections are on page 2-20.
Looking at the header JFP1, pins 1 through 9 (odd numbers) are the front row, pins 2 through 10 are the back. Pin 10 is the missing pin. The power switch connects to pins 6 and 8. The power LED connects to pins 2 and 4. The HDD LED connects to pins 1 and 3. The reset button, if used, connects to pins 5 and 7.
May 13, 2009 | E-Machines eMachines Desktop PC
I have an 945gzt-m v 1.0 and dont know were the pwr sw wire goes
Yes.
First, let's orient the view of the motherboard, so we are both looking at it the same way.
The processor is at the top middle, and the Front panel header, is to the very bottom right hand corner.
Right next to the motherboard mounting hole.
The Front Panel header goes across the bottom edge of the motherboard, lengthwise.
Looking at the top row of pins on the Front Panel header, No.2 Pin is at the far left. Pins 2, 4, 6, 8 and 10, go across the top.
Looking at the bottom row, No. 1 Pin is at the far left. Pins 1, 3, 5, 7, and 9, go across the bottom.
The power switch wires go to Pins 6 and 8.
The HDD LED wires go to Pins 1 and 3.
The power LED wires go to Pins 2 and 4.
On the power switch wires, the Positive (+) wire goes to Pin 6. Just in case this wire is marked.
(Doesn't really matter which way it goes, because it's a switch!)
On the HDD LED wires, the Positive (+) wires goes to Pin 1.
On the power LED wires, the Positive (+) wire goes to Pin 6.
Apr 15, 2009 | ECS 945GZT-M (V1.0) Motherboard
Wiring front panel
if you go to this website
http://www.foxconnchannel.com/support/downloads.aspx
You can select motherboards --> socket 754 --> your make of motherboard and then download the manual which will tell you what the pins are for and where abouts they are on the motherboard.
Apr 13, 2009 | Foxconn 760GXK8MB-RS Motherboard
Wires unpluged
these normally go at the front of the motherboard if you are looking at it where the power supply box cables are at the back. There are litlte pins that these fit onto that will say on the motherboard Hdd led etc... in small writing.
hope this helps
Oct 31, 2008 | E-Machines eMachines Desktop PC
ASUS P5N73-AM Motherboard Logo
102 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
