Question about Pioneer VSX-504 Receiver
Can Not Access System Setup Denon AVR 3600
Had to initialize the microprocessor.  Since doing that can't access the system setup menu.  Worked fine before the initialization.   operating instruction are no help.  Everything else works fine. Any help is welcome.
  • 11 more comments
  • mert2jr Jan 27, 2009
    Denon avr 3600 the problem is the system setup screen will not come up with the on screen display since I did the initialization. It worked fine before the initialization. I think there is a special setup routine that has to be completed since the processor initialization .was done
    Tried welcomejee solution redid the initialization unplugged at the wall - did not fix the problem still not able to access system setup menu/on screen display.
    Denon AVR-3600 had to initialize the microprocessor, this reset to factory defaults which are not what I need. I am now unable to access the system setup menu that appears on tv screen. I was able to access the system setup prior to initialization. Would appreciate responses from people that have actually used this receiver and experienced the same problem. Thank you
    The remote on screen display and enter button for system setup bring nothing up on tv screen since the initialization was completed.  All the remote on screen and enter button for system setup worked fine prior to initialization of microprocessor.  I think there is a unique set up procedure you have to go through once you initialize processor.
    Went to Denon's web site,  one of their answers said call Denon to access setup after microprocessor initialization.  Did that, still waiting for reply - they didn't have owners manual-it is ten years old but puts out great sound.  I am using a passive sub with sat speakers hooked to the sub.  Thats why I need to access setup and change the default for front speakers to large so I can get the base from the passive sub
    did that no help
  • mert2jr Jan 28, 2009
    called them waiting for reply
  • mert2jr Jan 29, 2009
    Called them, to date, they have not been able to help either.  That is why I came to this site - still looking for solution that will work.
    Denon AVR-3600 had to initialize the microprocessor, this reset to factory defaults which are not what I need. I am now unable to access the system setup menu that appears on tv screen. I was able to access the system setup menu prior to initialization. Would appreciate responses from people that have actually used this receiver and experienced the same problem. Have unplugged from the wall, made sure that I was not on direct source. Have video cord from receiver video out running to tv video in. Denon support has been no help, again I was able to access the menu setup prior to the initialization.
    have already been to this page - once again after processor initialization I an not able to get to system setup menu using the remote control buttons for on screen display nor the enter button which would normally display setup menu on the tv screen.
    I have seen all of these, they don't answer my specific problem.
    I have read every thing on the Denon site plus any other thing I could find on the net.
    President:
  • 2,559 Answers
Hope this helps,You may also be able to find more info,Here
1) WHEN DO I "INITIALIZE THE MICROPROCESSOR" AND WHY?
You’ll rarely need to "initialize the microprocessor" under normal operating conditions. In a few cases, the microprocessor will temporarily freeze or "lock up" just as your home computer does. When this happens, just follow the guidelines in the back of your owner’s manual to "unlock" the microprocessor and restore normal operation. (This is directly comparable to rebooting your computer. It’s an electronic wake up call to your unit’s temporarily paralyzed microprocessor "brain.")
If you experience some unusual behavior -- a channel that’s suddenly silent, "forgotten" level adjustments, some eccentricities in your unit’s Personal Memory Plus system, etc. -- you may need to reset the microprocessor. Of course, you should check all connections carefully first. But if you’ve eliminated these items as a source of potential problems, you may need to go through the initialization process.)
initialization is easy. For the AVR-3600 and AVR-5600 receivers, for example, just turn the unit off with the front panel power switch. Then press and hold both the "AC-3 RF" and "Phono" simultaneously while you turn the unit back on. (Use the same front panel power switch.) That’s all that’s involved.
What causes these problems? Several things can -- a jolt of static electricity, a current surge through an antenna input, etc. But don’t worry, the microprocessor is well shielded from any permanent effects.
When you do initialize the microprocessor, remember that this erases any setup instructions you may have previously programmed into the unit. However, the on-screen menu will quickly get you through a new setup. And, if you write down your preferred settings BEFORE you reset your unit’s microprocessor, you’ll have an even easier job!
2) DO I ALWAYS HAVE TO "TOGGLE" OR "PAGE THROUGH" THE ENTIRE MENU WITH THE ON-SCREEN DISPLAY BUTTON, EVEN IF I ONLY WANT TO SEE THE FIRST PAGE?
Of course not. Just press "Mute" twice and the on-screen menu will disappear!
Here’s why.
When you press the remote control’s "On Screen" button, the on-screen menu appears. Most times, you’ll probably want to page through the menu to look for a particular setting and subsequent pushes of the "On Screen" button make that easy -- every time you press it, you find yourself looking at a new menu page.
However, there may be times when you just want to check the menu’s first page and it’s annoying to have to scroll through all the menu’s pages just to get to the end. To avoid this, just press the remote’s "Mute" button and the menu will disappear! However, you’re now in mute mode so you need to press the "Mute" button once more to restore your previous volume setting.
Easy, wasn’t it?
15) CAN I PROGRAM MY REMOTE CONTROL TO SEND MACROS (MULTIPLE COMMANDS ) WITH THE TOUCH OF ONE BUTTON?
Yes, you can. DENON remotes are fully macro-capable. If you’ll look closely at the top of your remote controller, you’ll see a "System Call" section (usually differentiated by three pale green buttons marked "Set," "One," and "Two.") These buttons allow you to program a sequence of up to ten different commands and assign that sequence to either of the two "macro memories" for easy one-button recall. For more detailed information, see the Owners’ Manual for the unit you’re interested in. 17) WHEN THE "PROTECTION" INDICATOR COMES ON THE DISPLAY PANEL OF MY DENON RECEIVER, DOES THAT MEAN IT NEEDS TO BE REPAIRED?
Most probably not.
The "Protection" light comes on when the receiver’s current sensing and thermal monitors detect some unusual operating condition that, if left unchecked, might damage the amplifier. The sensors disconnect the amplifier from the speakers by switching the high speed output relays "off." This can happen, for example, if there’s a dead short in a speaker wire, or if you’re using very low impedance loudspeakers at high volume for an extended length of time.
In most cases, the circuitry will automatically reset after a few moments and the Protection indicator will go out.
If the Protection indicator does not go out, or if it goes on immediately after you turn on the receiver check your loudspeaker connections to make sure no wires have inadvertently shorted.
If, after checking all your connections, the Protection indicator stays lighted, you may need to "initialize the microprocessor" (see the FAQ on that topic) or take your receiver to an authorized repair center for a checkup. Run through the reinitializing process first -- it’s easy to do at home without disconnecting the entire system.
18) I OCCASIONALLY SEE AN "OVERLOAD" INDICATOR ON THE FRONT PANEL DISPLAY. IS THIS THE SAME AS "PROTECTION"?
No it isn’t. Some DENON components have a front panel "Overload" indicator that tells you when you need to decrease the sensitivity of a particular analog input. Simply follow the directions under "Analog Input Level" to assure distortion-free operation that won’t continuously trigger the "Overload" indicator.
Please rate this fixya.
Posted on Jan 29, 2009
  • 2,071 Answers
Just copy paste this site ;
http://www.usa.denon.com/ContactUs.asp
Regards
Posted on Jul 07, 2009
    President:
  • 1,214 Answers
Do you have the manual? I downloaded earlier when I was going to reply to you.
Let me know if you need it as I have not been able to apply my time to help you, and I can forward it to you. There is something in it about resetting and setup.
    President:
  • 1,990 Answers
Welcome to Fixya! I had the Same Reciever about 1 Year ago and had to Replace it Due to Recurring Problems Like This. You are Correct, Customer Service really Did not Help and a Repair Shop Quoted me above Retail Cost For Repair. Please Rate my Solution, I need all the Help that I can Get! Thanks!
    Sergeant:
  • 250 Answers
  • Pioneer Master
  • 19,396 Answers
Call Denon support and get step by step assistance in setting the unit to the proper settings.
Click here to get contact details.
Posted on Jan 28, 2009
  • 10,594 Answers
Initialize the microprocessor or system control is called RESET process and after reset unit goes to factory default settings.
I think this unit has not been reset properly. Please initialize it again then unplug unit for couple of minutes and replug in AC and check.
Posted on Jan 27, 2009
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Jan 27, 2009
    Please check any on-screen display button on remote to bring screen display for further adjustment.
    I don't agree with unique procedure idea as RESET is procedure of any digital circuit to set it on default settings.
    Microprocessor of this unit has firmware and RESET does not disturb it in any case.
    We are missing some thing to bring screen display for amp adjustment menu.
    One more thing, Please check does amp set on Direct Source mode?
    If yes, select any other source, I hope screen display will appear.
    Genius:
  • 1,550 Answers
The steps to initialize the microprocessor
Just turn the unit off with the front panel power switch. Then press and hold both the "AC-3 RF" and "Phono" simultaneously while you turn the unit back on.
How to connect Denon avr 1804 connecting to roku hd
I connected by Roku to a Denon 1804 Receiver this way:- I plugged the cable that came with the Roku into VCR2 input jack of the Denon. (I used VCR2 because it was available).- Using the remote from the Denon, I made sure the slide switch was on "Audio." (See page 20 of Denon Manual).- I pressed pressed the System Setup button- *System Setup appears in display of Denon- Using the cursor buttons I scrolled to menu Digital in Assignment- I set Menu item 16 Coaxial to VCR2 since that was the input jack I used for the Roku. - After making the selection press the CH Select Enter button to save- To exit the System Setup press the System Setup button again- When using the Roku, select the input source as VCR2 (or whatever jack you used). You should now have sound through the Denon.The most important step is to read the Denon manual starting on page 20
Dec 08, 2012 | Denon AVR-1804 Receiver
Systems setup
Hii,
Try this out:
Go to the display settings in the settings menu. Pick HDMI for your video output and follow the steps to set your screen resolution. When I accepted the video settings I was taken automatically to the audio settings options. If you’re not given this option just go to the set audio output settings and enter this screen. Pick the optical connection and follow the screens choosing the audio options that match your receiver. DD and DTS.
At this point you should have video to your TV through HDMI and audio to your receiver through the optical cable.
Goodluck,
please dont forget to rate me as fixya..
Jan 28, 2008 | Denon AVR-3801 Receiver
How to access denon avr-3300 system setup
First make sure that your remote control is set to "Amp" as it can control many different devices.
Then make sure that you have connected the Monitor Out socket on the receiver to your TV.
Next make sure your TV is set to show the picture from the input you connected to the Denon monitor out.
Now press set-up button on the remote and the System Setup menu should appear on your TV.
If this helps then please rate my answer,
Many thanks,
Chris
Mar 02, 2011 | Denon AVR-3300 Receiver
How to reset the protector circuit in a Denon AVR 3801 unit?
14 INITIALIZATION OF THE MICROPROCESSOR
When the indication of the display is not normal or when the operation of the unit does not shows the reasonable result, the initialization of the
microprocessor is required by the following procedure.
1 Switch off the unit and remove the AC cord from the wall
outlet.
2 Hold the following AUTO button and PCM button, and plug
the AC cord into the outlet.
3 Check that the entire display is flashing with an interval of
about 1 second, and release your fingers from the 2 buttons
and the microprocessor will be initialized.
NOTES:
• If step 3 does not work, start over from step 1.
• If the microprocessor has been reset, all the button settings are
reset to the default values (the values set upon shipment from
the factory).
• Calling out preset stations from the main unit‘s panel.
1 Press the TUNING PRESET button. TUNING
PRESET
FUNCTION 2 Turn the FUNCTION knob and
select the desired station.
TV CD CDR/MD/TAPE RECEIVER
VCR DBS/CABLE
SKIP
SKIP
ENTER
MEMORY
CHANNEL VOLUME
VDP DVD
TUNER PHONO CD
DISPLAY
SETUP RETURN
MENU
SHIFT
SURR.
PARA. OSD
A/B
MUTING
BAND MODE
TUNING
TUNING
2 1
(Main unit)
Jun 11, 2010 | Denon AVR-3802 Receiver
How do i connect my denon RC7000CI to denon amp. 2801
I cannot access the setup menu on the unit display or via the s-video monitor out -- everything was working fine a few days ago. I have reset micro, unplugged all night, reset again, and still cannot get to the menu in order to correct connections, esp for digital. My problem is on the avr5600 but seems like this happens on many of the denon units
Mar 03, 2009 | Denon AVR-2801 Receiver
Cant Access System Setup on Denon AVR-588
Are you connected with video cables to a tv or "monitor" this is more than likely were the setup is visible for speaker configuration, input assignment etc, most denon receivers work this way so I would suspect you need to re-check the video connection until a set-up picture appears.
Feb 07, 2009 | Denon AVR588 Receiver
Denon 1508
This should resolve your propblem... taken from the Denon USA FAQ...
If you experience some unusual behavior -- a channel that’s suddenly silent, "forgotten" level adjustments, some eccentricities in your unit etc. -- you may need to reset the microprocessor. Of course, you should check all connections carefully first. But if you’ve eliminated these items as a source of potential problems, you may need to go through the initialization process.)
Initialization is easy. Please refer to your owners manual for instruction on reseting the microprocessor as each unit may have its own individual protocal for reset.
If in the event you do intialize microprocessor reset please refer to your owners manual for instructions on setup..
Sep 20, 2008 | Denon AVR-1508 Receiver
Unresponsive remote
Had same problem with this reciever over the weekend. I had to hook up a TV to the COMPOSITE monitor jack and then I could see the menus. I could never get it to show the menu over the component outputs, however a DVD player hooked up played perfectly. Anyone have a solution?
Jan 21, 2008 | Denon AVR-2803 Receiver
Denon AVR-987 System setup lockout
YOU NEED TO HAVE A MONITOR OUT CABLE FROM THE DENON COMPOSITE, S-VIDEO, COMPONENT OR HDMI TO AND UNUSED INPUT ON THE TV.
SELECT THAT INPUT ON THE TV AND PRESS THE SETUP BUTTON ON THE DENON REMOTE AND YOU SHOULD GET A VIDEO SIGNAL ON THE TV TO UNLOCK
Sep 14, 2007 | Denon AVR-987 Receiver
No system setup menu on screen
its related to the control AVI switch inside on the right side with the contact and 7 Ri sisters.
about 200.00 something to repair.
I can help with some money do you have the reciever still???
Jan 04, 2007 | Denon AVR-1706 Receiver
516 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
