Question about Cobra Ga-cs Or Ga-cl Microtalk Charging Stand Charger For Priss Walkie Talkie
What (low voltage) goes from wall plug into (charger stand)? Thanks, Richard
  • Cobra Master
  • 3,904 Answers
I don't know what the question is here for sure but the voltage is converted to 12 volt from the wall to the charger. Milliamps is the only variation from charger to charger.
Posted on Jan 23, 2013
Laptop charger not working
If the charger case has a power LED and its not litup then either the charger is shot or the cord to wall is bad. Wiggle cord all around and seeit the LED comes on. If it has no LED then check voltage with volt/ohmeter at the plug end that goes into laptop. Proper voltage should be on bottomof case label.
Jul 23, 2014 | Sony VAIO EA Series Notebook Computer
Galaxy Samsung tab 10.1 won't turn on
you had to plug it in the charger for a while and then you hel the power button for more than a minute
if it not work hold power button and volume up for 20 sec.
Mar 22, 2013 | Tablets & eReaders
What volt charger is needed for (cobra microtalk pr560wx)? Thanks,Richard
Hi Richard,
Volt Charger??? I'm not sure what you mean, but if you mean what voltage to recharge the batteries, then you need to look at the unit, all over to find the AC input, there should be something tht states voltage and polarity there, if it infact has one.
Pease reply with more detail re: your query.
Regards,
Peter
Jan 20, 2013 | Cobra Ga-cs Or Ga-cl Microtalk Charging...
Charger not holding charge, not turning on
You will have to verify that the charger is actually putting out the voltage it is supposed to. The input transformer could still be good while the secondary that goes to the output could be bad or a fuse or other component could be bad in the out put OR the wire from the adapter could be bad. Replace the charger with one that has the correct voltage and amperage ratings and the correct plug on the end.
Aug 04, 2012 | Vector Black And Decker High Frequency...
How I can convert 110volts to 220 voltage in Craftsman charger 145301 because in the Peru country we use 220 v. thanks.
_Some_ chargers will allow a range of input voltages. This will probably be "Input: 100-240V" or something like that written on the charger. __You need to be sure__. Others may have a switch from one voltage to the other. The trick here is to make sure the switch is in the right position. In both cases you may also need a plug pin adapter. If the charger you have has neither of those abilities then you either need to get a different charger from Craftsman, or get a voltage converter, which will give both the right plug for your wall sockets and convert from 220V (from your wall) to 110V (to the charger). Unless the charger has voltage range or a switch, you can't just use a simple plug pin adapter.
Feb 20, 2011 | Craftsman Drills
HELLO I HAVE A SAMSUNG 24 INCH MONITOR. MODEL P2450H I WOULD LIKE TO REMOVE THE STAND FROM THE UNIT AS I WOULD LIKE TO WALL MOUNT IT, THANKS RICHARD KEENE
The stand is secured to the back of the monitor with screws.
Your wall bracket may need modifications if the mounting holes on the monitor.
Dec 04, 2010 | Computers & Internet
Battery and Charger problems
Hello
Thank you for using
FixYa for your problem
Can you check the charger is outputing the correct amount of voltage, (power surge maybe)
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 18, 2009 | Apple iBook G4 Mac Notebook
Have lost charger or the 2 prong adapter. Not sure as we have a 16 volt charger with single prong that may be for our light. Need to know what voltage required for the light to be sure.
According to the instruction manual for these swimming pool lights, the charger specifications are the following:
USA and CANADA: 14 VAC,1.5A UL/CSA-approved wall plug
adapter and charger
AUSTRALIA and NEW ZEALAND: 240VAC 50Hz/14VAC 1.5A wall
plug adapter and charger
EU: 220-240VAC 50Hz/14VAC 1.5A CE-approved wall plug
adapter and charger
SOUTH AFRICA: 220-240VAC 50Hz/14VAC 1.5A wall plug
adapter and charger
UK: 240VAC 50Hz/14VAC 1.5A CE-approved wall plug adapter
and charger
Aug 13, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
About charging.
Just get a USB/AC converter. You can use the same computer cable to plug into the wall.
Paul
Mar 28, 2008 | Archos 604 WiFi Digital Media Player
Cobra Ga-cs Or Ga-cl Microtalk Charging Stand Charger For Priss Walkie Talkie Logo
121 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
