Question about Sharp MX-2300N Laser Printer Toner Cartridges
Sharp mx-2300n code: h4-30
Code: h4-30
SOURCE: Sharp MX-2300N
throw it out, buy a Xerox
Posted on Jul 17, 2008
  • 24 Answers
SOURCE: Sharp MX-2300N Reset
Type in "p" "*" "C" " *" (that is p button, star button, p button, star button.) the machine will go into sim mode enter 14 then press execute which appears on the lcd and the yes to confirm, then press CA and the machine should turn off then back on again
Posted on Sep 12, 2008
  • 3 Answers
SOURCE: Sharp MX-2300N Maintenance required.code:TA
Maintenance TA is indicating the machine has reached its 100K scheduled service interval. It requires Transfer Belt Unit, Usually Black Drum & Developer, any feed rollers wornout replaced, any old firmware updated to latest version, and a general clean & check. It is reset in service mode once these parts are replaced.
Posted on Dec 26, 2008
007tech
  • 95 Answers
SOURCE: sharp mx-2300N printer error maintenance required
VK means black developer has reached end of life. You can safly carry on using the copier with this message displayed but over time the copy quality may slowly degrade. You will need to call a Sharp authorized dealer to replace the developer in the developer unit.
Posted on Jan 15, 2010
  • 14 Answers
SOURCE: Sharp MX-2300N with error code H3-00. . how do I
Ensure you are in COPY mode
press # * C * ( one after the other, fairly quickly)
when the screen changes enter the number 14 on the keypad
press the B&W start button
press 1 for Yes when the question displays
press thw CA button
machine will re-boot and fault should clear. If it doesnt you need a service engineer. This is a fuser temperature fault
Posted on Mar 09, 2010
A LOUD NOISE WHEN I TURN ON MY COPIER SHARP MX-2300N AND IT CAN NOT COPY OR PRINT
Hi Patience .
Have you got anything on the display ?
Any error codes ?
Jun 27, 2016 | Sharp Office Equipment & Supplies
Sharp mx 2300N error code H5-01
http://www.copytechnet.com/forums/sharp/76512-sharp-mx-2300n-error-code-h5-01-a.html
Feb 15, 2015 | Sharp MX-2300N Color Copier
Sharp mx 2300N error code U2-41
The U2 errors are usually related to memory or board level issues. You should try to disconnect the fax and network and then kill the main power inside the cover. Turn the main power on and then when you get a solid green light on the control panel press that power switch. If the machine boots with everything disconected then try conecting the options one at a time and try rebooting each time to see if you can narrow down the problem.
Oct 16, 2014 | Sharp MX-2300N Color Copier
Sharp MX-2300N Maintenance Required: Code VC
Time for some scheduled maintenance! Call a local sharp dealer.
google sharp service locator, enter your model and your zip code to find a dealer near you.
Copier Collin Houston TX Copier and Imaging Expert
Jul 11, 2014 | Sharp MX-2300N Color Copier
Mx-2300n firmware
The firmware is only available from a dealer. You can make an arrangement to get it on a USB thumb drive and update the machine using SIM 49
Apr 19, 2014 | Sharp MX-2300N Color Copier
SHARP MX 2300N Have cleaned the glass but still
Try cleaning the smaller part of the glass on the machine located to the left hand side of this machine!
Aug 25, 2011 | Sharp MX-2300N Color Copier
MX-2300N Color Copier: I have a Sharp MX-2300N that has just suddenly sta...
yes open the front door remove the waste toner and you will see the 4 drum units each with a little green stick pointing out
pull this in and out a few times on each unit ...
hope this helps
May 18, 2010 | Sharp MX-2300N Color Copier
Sharp mx-2300N printer error maintenance required code vk
Dec 23, 2009 | Sharp MX-2300N Color Copier
Network printing from a mac computer to sharp mx 2300n printer
HI,
Sounds like driver problem..
go to this site: Driver Update and make required updates.
wish you best of luck
cheers
Dec 17, 2008 | Sharp MX-2300N Color Copier
Sharp MX-2300N Laser Printer Toner Cartridges Logo
27 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
