Question about Mitsubishi Heating & Cooling
I need instruction on how to operate mitsubishi remote type KM08C
3 Suggested Answers
  • 6 Answers
SOURCE: lost manual to rca universal remote, lost programing to operate remote
RCA Universal remote codes for the Mitsubishi TVs are...006,011,014,019,022,027,041,056,061,068.
First, turn on TV
Press and hold code search button on remote
Press and release the TV button
Enter the three digit code you want
Release code search
Push channel up, if device responds, that code worked.. If not, repeat steps 1-5 with each code until you find the one that works. This information can be downloaded from http://www.thompsontv.com/rcarc.html
If you want a hard copy with codes for all TVs.
Posted on Jun 02, 2009
SOURCE: programming instructions for 2006 Mitsubishi raider remote
Note when entering program mode using that fob, all other programmed transmitters will be erased and you will have to reprogram them for your vehicle. Use the following procedure to program additional key fobs if the vehicle is not equipped with Sentry Key:
1. Enter your vehicle and close all doors.
2. Fasten yo belt to cancel any chiming that may confuse you
3. Place the key into the ignition turn to on pos. do not start
4. Press and hold the UNLOCK button on the key fob.
5. After holding the UNLOCK button for four seconds, also press the PANIC button within 6 seconds.
6 When a single chime is heard release both buttons. The chime is an indication that you have successfully entered program mode. All transmitters that are to be programmed must be done so within 60 seconds of when the chime was heard.
7. Using the fob to be programmed, press and hold both the LOCK and UNLOCK buttons, simultaneously for 2 seconds and them release.
8. Press and release the UNLOCK button a single chime will be heard,
9 Repeat steps 7 and 8 to program up to six additional transmitters.
10. Turn the ignition to the OFF position.
11. Your vehicle will remain in program mode up to 60 seconds from when the original chime was heard. After 60 Seconds, all programmed transmitters function normally.
Posted on Sep 27, 2010
How to program an all for one remote to operate a mitsubishi
You might want to try a One for All remote and use its code search function to find the code you need. If you do not have instructions, you may be able to obtain them from the One for All site
Apr 08, 2014 | Mitsubishi WD-52525 52" Rear Projection...
Need instructions and codes for Circuit 6 in 1 remote control purchased at Dollar General
If you wish to get instructions, check this link. It is difficult to type in all here by this window.
Nov 07, 2012 | Circuit Electronics Universal 6 In 1...
Mitsubishi remote
0005 0151 0051 0004 0009 0254 0022 0141 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Mar 28, 2012 | Mitsubishi Televison & Video
Coed neededfor hd 1080 tv
fsteddie97
Since you did not provide your TV manufacturer or the receiver type, I have provided a link with instructions on how to program a DISH remote to your HD TV. Included with the instructions are links for the TV codes. I hope this helps.
http://www.dishnetwork.com/SupportSection/remote-setup.
Ray Calo
DISH Network
Mar 12, 2011 | Mitsubishi Televison & Video
I need download the user guide of Mitsubishi rkn502a remote control
Search Results
    [PDF]user's manual mitsubishi daiya room air ... - 3D Air Sales Ltd
    www.3dair.co.uk/DOWNLOADS...manuals/O&M%20RAC%20-%20SR...
    MITSUBISHI DAIYA ... performance, read and follow this User's Manual carefully before using your air condi- ... Operation and indication section for remote control . ....Symbols which appear frequently in the text have the following meaning:.
    Air Conditioning User Manuals - Mitsubishi Electric Australia
    www.mitsubishielectric.com.au/Air_Conditioning_Use...
    Mitsubishi ElectricUser Manuals/instruction booklets (including remote control instructions) forMitsubishi Electric Air Conditioners. ... Air Conditioning Downloads ยท Residential Air ...Need to know how to operate a Mitsubishi Electric air conditioning system?
    Remote Control Symbols - Mitsubishi Electric
Aug 20, 2010 | Heating & Cooling
No instruction for my remote
hello there well maybe try typing the model of the remote on search ..would probably hep ya remeber to add what you are looking for make model and search for specs or try info...this may help you
Feb 05, 2009 | One For All URC-9910 LCD Remote Control
Need a substitute remote for mitsubishi hs-u431
If you go to www.remotes.com you can order an original replacement for your unit!
Please rate my response
Thank
You!
Jan 11, 2009 | Mitsubishi HS-U431 VHS VCR
I need code mitsubishi
Code for Mitsubishi are :0093, 0150, 0178
If this doesn't work with your new remote there is always the way that I have done it in the past and that is to use the find the code function on your new remote. It is a pain but can be done and is quite effective. Each remote is slightly different, but for the most part you would hit the set up botton and hold it in until it starts flashing then hit the T.V. Button and then hit the first code it tells you to hit and then hit the power switch if it doesn't turn off your T.V. then you hit the increment button up, (this is different for each remote so it is important to follow the instruction manual on this part) You bassically keep hitting the incriment button until your code comes up and then it will turn off your t.v.! Then your done. Note: It may take up to 400 pushes of the increment button, but it will work.
Dec 13, 2008 | GE JASRM24912 Remote Control
Lost manual to rca universal remote, lost programing to operate remote
First, turn on TV
Release code search
Aug 29, 2008 | RCA Universal Remote Control
Remote Control Programming
Go online and search for the owners manual for your TV. It has the common codes for receivers, DVD players, etc. listed in the back with the instructions on how to program the remote.
Apr 24, 2008 | Mitsubishi WS-48315 48" Rear Projection...
Heating & Cooling Logo
368 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
