Question about Maytag Atlantis MAV6260AWW Top Load Washer
Noisy When Agitating
Recently our washer has become very noisy when agitating the wash. It seems fine on the spin cycle. I replaced the drive belt to no avail. My next step was to replace the dogs, but apparently they are in the agitator. Am I correct about this? Anyone have any ideas where to look next? Should I buy a new agitator? Thanks in advance for any help. -- Craig
  • Craig Lambert Jul 26, 2007
    Well, I'm not certain it's the agitator. I just know the noise is only occuring while the wash is agitating. I hate to drop $60 to find out it's not the agitator.
    I hate to sound stupider than I already am, but how can I detect if the drum is creeping?
  • Anonymous Mar 21, 2008
    Washer is noisy when agitating on slower speeds. Sounds like gears are loose or something like it. Motor was replaced but still makes sounds at slower speed settings. Its a kenmore washer.
It may not be your agitator. Find out if the inner basket/drum is "creeping"(moving)during agitation. if it does and it squeeks then your problem is in the brake system. you may need new brake rotor and stator. In that case you can't do it your self because you need a special tool to compress the spring. DON'T REMOVE IT without the tool you may HURT yourself.
Posted on Jul 22, 2007
    Novelist:
  • 159 Answers
I belive on the maytag whers with the cork screw agitator, if your sure thats where the noise is comming from I belive the agitator is a 2 peice unit and you can not just change the dogs as you can in a whirlpool you have to replace the agitator.
SOURCE:
Fix agitator on a speed queen awm290
Is the drive belt in good condition?
Does the machine spin dry?
Is there water leaking from the bottom?
I suggest the gearbox needs to be replaced. Another sign is if the machine is noisy when it is washing (agitating)
Jul 04, 2014 | Speed Queen AWS45NW Top Load Washer
Ge frontload washer seems like it is not aggitating... what would be the problem???
Hello there:
The first thing to check when your GE washer is not agitating, is the belt. Let me tell you how to check the belt & the clutch with out having to take the washer apart.
The belt: Set the timer in the spin cycle and pull the timer knob to turn the washer on.
If the washer drains the water and then spins the way that it should, this tells you that the motor, belt & clutch are not the reason why your washer won't agitate.
A broken belt could be the reason your washer is not agitating or spinning.
The agitator: After making sure that the belt, motor & clutch are working ok, lets check the agitator.
The agitator uses a plastic agitator coupler that is couple to the transmission shaft by using splines cut in the coupler and on the transmission shaft.
Too much usage or overloading the washer too many times will wear the agitator coupler splines. With out the splines the coupler could not be coupled to the transmission shaft and that could be the cause why your washer is not agitating.
The clutch: A bad clutch could also be the reason the washer won't agitate or spin. Usually when the clutch is bad the washer will be noisy, like when you have bad brakes on your car.
The transmission: The transmission could be the reason your washer is not agitating. A common problem with the transmission is oil leaking right on top of the motor pulley and the belt.
As you can see, there could be different reasons why your GE washer is not agitating. You just need to keep checking each part until you find the problem and replace the part responsible.
Oct 03, 2010 | GE WSXH208A Front Load Washer
Maytag Atlantis 7700 - Noisy agitation/wash cycle from motor
Your drive motor may be fine. Check the water pump that is located in the back behind the small metal door on the left bottom corner and see if thats where your noise/water is coming from. These extraction pumps have bearings casing that gets mangled and locked up. Look right above the flywheel that the belt rides on in the W-pump.
May 09, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Crown series 12 cycle washer will not agitate and smells like something is burning like a for instance a vacumme belt kinda smell in that cycle it spins fine fills fine drains fine but just makes a so
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
May 07, 2009 | Frigidaire FWSB5700DS Top Load Washer
Washer won't spin or agitate
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Apr 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Machine wont agitate
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Apr 19, 2009 | GE WDSR2080D Top Load Washer
Will not adjatate
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Apr 01, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
My washer wont agitate ?
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Feb 07, 2009 | Maytag Performa PAV2200
Washing Machine Shaft Wont Move
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Dec 08, 2008 | Amana 3.2 cu. ft. Top-Load Washer
NAV6800AWW - noisy
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
Nov 04, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Maytag Atlantis MAV6260AWW Top Load Washer Logo
415 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
