Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Lamp replacement bulb replacement
  • Philips Master
  • 3,459 Answers
Its easy...just buy a bulb from sites like Tv Repair Kits and swap it out. To do that remove the back bulb cover, pull out the bulb box....remove the old bulb and put the new one in.
Posted on Jan 31, 2013
Replacement bulb/lamp availability
Google search your manufacturer make and model and the words replacement lamp. You can find reputable vendors it in the search results.
Mar 31, 2015 | Televison & Video
Tip
Before buying a projector bulb
1. Always be aware of bulb usage hours: bulbs normally last ~ 2000 hours
2. If the bulb pops and goes out:
  • Follow the manufactures safety instructions for this condition.
  • Normally, the bulb will need replacing.
3. If the lamp just turns off:
a. If lamp hours were getting high and the picture was getting progressively dimmer, normally the bulb will need replacing.
b. If bulb hours were low or a few hundred hours from 2000:
  • Clean all filters and air ports.
  • Try the projector again checking overall projector ventilation.
  • There is a heat sensor in most projectors that will shut off the machine if it overheats, so air flow must be unobstructed.
c. If ventilation does not solve the problem:
  • Take out the lamp, following the manufactures instructions.
  • Inspect the lamp bulb visually through the lamp glass window.
  • Look for cracks or damage in the bulb and whether one or both of the lamp wire elements is detached from the top of the bulb.
  • In either case, the bulb is bad and should be replaced by purchase or possibly by warranty if the lamp hours are low.
  • Normally, bulb replacement is the solution, but other issues could also exist.
d. If the lamp looks undamaged and/or you are unsure of the status, the problem could be a lamp ballast, power supply, or main control board issue, and should be evalulated by a technician. Unfortunately, a bad bulb can also result from one of the above issues.
on Feb 12, 2011 | Office Equipment & Supplies
I am trying to replace aleft rear turn signal bulb on a 2005 lacrosse. I removed two wing nuts but cannot remove assmbly. Is there another wing nut holding it in. I cannot find it?
3 wing nuts. here is the info needed.
gmlogoflat.gif Service Information
bhome.gifbpublication.gifbnumsrchbutton.gifbnews.gifymkbutton.giffeedback.gifbhelp.gif
2005 Buick LaCrosse ' Allure, LaCrosse VIN W Service Manual ' Body ' Lighting Systems ' Repair Instructions ' Document ID: 1537542 Tail Lamp, Turn Signal Lamp, High Mount Stop Lamp, License Lamp, Backup Lamp Replacement - Rear
Callout
Component Name
Notice: Refer to Fastener Notice in the Preface section.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Turn Signal/Stop Lamp Assembly Replacement - Rear 1
Nut, Turn Signal/Tail Lamp (Qty: 3)
Tip
Pull back rear compartment carpet to gain access to lamp.
Tighten
2 N·m (18 lb in)
Lamp, Turn Signal/Tail Lamp
Tip
Twist the bulb socket and pull inward to replace the bulb.
License Lamp Replacement 3
Screws, License Lamp (Qty: 2)
Tighten
2 N·m (18 lb in)
Lamp, License Lamp
Tip
Jul 29, 2011 | Buick LaCrosse Cars & Trucks
How to replace a bulb
Hello
To replace bulb in RCA rear projection TVs follow this.
Turn the lamp assembly so that the front of the bulb faces downward
Locate two clips approximately three inches apart along the back edge of the rear lamp cover. Depress the clips with your thumbs and pull upward on the rear lamp cover to disengage it. Move the rear lamp cover so that you can see the head of the bulb. Note that the rear lamp cover still connects to the base of the bulb by a cable.
Locate the three hex screws around the head of the bulb that, in a triangle formation, secure the bulb to the assembly. Remove the screws with a hex screwdriver.
Pull the bulb and rear lamp cover upward to remove them.
Remove the nut that connects the cable from the rear lamp cover to the base of the bulb with a wrench. Disconnect the cable from the old bulb and discard the old bulb.
Reattach the cable from the rear lamp cover to the base of a new bulb and install the nut. Tighten the nut with a wrench
Install the bulb face down into the lamp assembly. Install the three hex screws into the tabs along the edge of the bulb and tighten with a hex screwdriver.
Reinstall the rear lamp cover onto the lamp assembly and line up the tabs with the holes along the side of the assembly. Press downward until the cover snaps into place.
Reinstall the lamp assembly into the back of the television, facing the bulb towards the center of the TV set. Tighten the screws securing the assembly and reinstall the lamp access door. Tighten the screw on the lamp access door.
Mar 22, 2011 | RCA D61W20 61" Rear Projection Television
I am trying to figure out how to replace my replacement lamp, but do not know where it is located.
Lamp Access door for Sony KF50WE610 is below the screen on the front of the TV. This page shows location of Lamp access door and DIY bulb change instructions for most SONY LCD TVs:
DIY Bulb Installation Guide
XL-2000 XL-2100 XL-2200
XL-2400 XL-2500 XL-5000
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
Feb 05, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
How to replace headlights bulbs in a grand cherokee 2001
  1. Remove the jack screw attaching the top of the head lamp to the head lamp mounting module.
  2. Grasp the upper inboard and lower outboard corners of the head lamp and pull the head lamp outward.
  3. Remove the bad bulb socket from the head lamp module and remove bulb from socket.
  4. Install new bulb into socket and reinstall socket into head lamp module.
  5. Position the head lamp on the vehicle and align the ball studs with the sockets.
  6. Push the head lamp inward to secure the ball studs with the sockets.
  7. Install the jack screw attaching the top of head lamp to the head lamp mounting module.
Do not touch glass of halogen bulbs at the oil can cause the headlight to blow out
Nov 12, 2009 | 2001 Jeep Grand Cherokee
How do I replace the lamp? Do I need just the bulb, or also the housing?
just the bulb.. write down the model number of the unit and they will give you the same bulb that you need, just give them the model number.
If you are going to install the bulb just remember DO NOT HOLD directly the bulb, use any clothe or gloves, because even a fingerprint can busted the bulb even thou it's not yet use
Nov 08, 2009 | Sony XL-2100U Projector Lamp for...
1999 Dodge Neon rear license Plate bulb
LICENSE PLATE LAMP BULB
REMOVAL
  1. Remove screws attaching license plate lamp to rear bumper
  2. Remove lamp from bumper.
  3. Remove bulb socket from lamp.
  4. Pull bulb from socket.
INSTALLATION
  1. Install bulb into socket.
  2. Install bulb socket into lamp.
  3. Place lamp in position.
  4. Install screws attaching license plate lamp to rear bumper.
Oct 08, 2009 | 1999 Dodge Neon
How do you replace the fog light bulbs on a 2004 buick regal?
Notes FOG LAMP BULB REPLACEMENT - FRONT
REMOVAL PROCEDURE
  1. Remove the front bumper fascia deflector.
  2. Disconnect the electrical connector from the front fog lamp bulb/socket. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Rotate the front fog lamp bulb/socket counterclockwise to release.
  2. Remove the fog lamp bulb/socket from the front fog lamp assembly.
  1. Install the fog lamp bulb/socket to the fog lamp rotating clockwise until fully seated. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Connect the electrical connector to the front fog lamp bulb/socket.
  2. Install the front bumper fascia deflector.
Jun 16, 2009 | Buick Regal Cars & Trucks
NEED TO REPLACE A TAIL LIGHT BULB IN A 2005 CHEVROLET IMPALA
and Repair Notes TAIL LAMP REPLACEMENT REMOVAL PROCEDURE Open the rear compartment. Remove wingnut and pull back the rear compartment trim panel from the tail lamp. Remove the wingnuts from the tail lamp. Remove the tail lamp from the rear body panel. Disconnect the electrical connector from the tail lamp. Remove the tail lamp socket, turning counterclockwise. Remove the bulb from the tail lamp socket. Remove the sidemarker lamp socket, turning counterclockwise. Remove the bulb from the sidemarker lamp socket. INSTALLATION PROCEDURE Install the bulb to the tail lamp socket. Install the bulb to the sidemarker lamp socket. Install the sidemarker lamp socket, turning clockwise. Install the tail lamp socket, turning clockwise. Connect the electrical connector to the tail lamp. Install the tail lamp to the rear body panel. Install the wingnuts to the tail lamp. Pull back the rear compartment trim panel to the tail lamp and install the wingnut. Close the rear compartment.
Jun 08, 2009 | 2005 Chevrolet Impala
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
