Question about Canon imageRUNNER iR C2880 Color Copier
Ohp sensor error in ir2880 - Canon imageRUNNER iR C2880 Color Copier
  • 128 Answers
OHP Sensor may be out of alignment with the reflector in the Paper Feeder Frame Assembly, there may be a loose connection, or it may be faulty.
Open the Right Door Assembly and the OHP Sensor (with a blue tinted lens) is located on the machine side in the center below the registration roller and the ITB. Ensure that the sensor is correctly seated in the mounting frame and re-seat the harness to the sensor. If code will not clear replace the sensor. (RH7-7129-020)
Posted on Jan 22, 2013
I keep getting an error E000045-0000 HOW CAN I RESOLVE THIS MY PRINTER IS CANON iR C3580
This error can be caused in case if OHP Sensor gets out of alignment with the reflector in the Paper Feeder Frame Assembly, or because of loose connection etc.
Follow the given steps to fix such printer problem:
Users may firstly open the right door assembly and the OHP Sensor which is found on the center of the machine side center just under the registration roller and the ITB. You may also check and conform that the sensor is correctly seated in the frame and reseat the harness to the sensor and in case if the code is not clear then immediately need to replace the sensor. For more Details Call Canon printer support Toll-free number 1-888-488-2930 (USA & Canada) and find instant help.
Mar 14, 2018 | Canon Office Equipment & Supplies
Error code E000110-0000 of the copier IR2880
Hi. That error is related to the laser unit . Mabye the shutter of the laser unit is malfunctioning
Jan 19, 2018 | Canon Office Equipment & Supplies
How do i reset error c20 in bizhub konica minolta
OHP sensor malfunction had a tech check it out and or replace
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 04, 2016 | Konica Minolta Office Equipment & Supplies
Error 000045
OHP sensor error, clean or replace.
Aug 08, 2013 | Canon imageRUNNER C3170U Color Copier
Error 000045 in ir2880
E045 is the HP sensor error located inside the right door. It maybe dirty or dislodged. Clean or replace. No special reset, just OFF/ON.
Jan 22, 2013 | Canon imageRUNNER iR C2880 Color Copier
Ir 3100 have erroe 000045-0001
OHP SENSOR ERROR.REPLACE OHP SENSOR
Apr 04, 2011 | Canon Office Equipment & Supplies
My epson c2000 printer have a "service req e033"
Because the Epson AcuLaser Color 2000 was made for Latin America, there's not much information that I can give you concerning your Service Error Condition. All I can tell you is that the Service Request error # E033 is an Engine Related Service Call Error Message for OHP Detection Sensor Malfunction [abnormal condition]. Check to see if the windows on the OHP sensor are dirty and clean OHP sensor window and the OHP sensor reflective window. I'm sorry, but I can't even tell you where the OHP sensor is located, or anything else about it. If you cannot figure it out using your Owners Manual/Users Manual, you can always e-mail Epson Technical Support for possible help or advice, at epson.com
Mar 10, 2011 | Epson AcuLaser C2000 Printer
Fatal error 21h; and problem printing even without the error
open side cover and there is a plastic, if you raise that plastic piece the ohp sensor should be located under this plastic
second problem, try uninstalling the printer and re install it, should solve this.
Nov 09, 2008 | Konica Minolta magicolor 2300DL Laser...
Xerox Phaser 6120 Error 21 OHP Detect Sensor
Hopefully you waited 30 min to an hour before moving it .if not you may have sloshed the ink within the unit witch will require a through cleaning these are great units but they can only be moved when ink wells have cooled off. To be safe at leased an hour. It's real hard to move them without sloshing because they are very heavy a must to cool. Good luck.
May 03, 2017 | Xerox Phaser 6250DP Laser Printer
Fatal Error 21H
FATAL ERROR CODE 21H / SERVICE CALL 21 TRANS DET SENS: Malfunction of the OHP detecting sensor
check the OHP detecting sensor (PC3A) (it's at the front above the waste toner sensor pc6)
May 22, 2008 | Konica Minolta magicolor 2300DL Laser...
Canon imageRUNNER iR C2880 Color Copier Logo
254 people viewed this question
old marine
old marine
