Toshiba 32kv500b screen problem
Screen problem, after switching on the screen starts to go really bright after a few minutes, some times get little dots appear aswell
  • 18 Answers
SOURCE: two little white bright dots
these are lit pixels! which can only be caused by a bad dmd chip (the micro-mirror-device). the chip can be replaced but it requires an experienced technitian to align the chip so your picture is straight, centered and in focus.
Posted on Jan 04, 2009
scott9411
SOURCE: little black flashing dots appear on my tv screen wen playing 360
does it look like the is a checkerboard pattern on the screen aswel?
Posted on Jan 06, 2009
Geekman
  • 32281 Answers
SOURCE: toshiba satellite a135 monitor goes black
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 04, 2009
  • 10 Answers
SOURCE: brightness pop-up window on screen for a long long time
There are a few things that could be wrong; someone could have a remote and be messing you about, a button could be stuck on the monitor so its increasing, the computer could be slow or signals might be getting mixed up. try and figure it out based on what ive said. good-luck!
Posted on May 20, 2009
dave1645
  • 834 Answers
SOURCE: dots on the screen
this sounds lie a bad panel but could just be a bad T-con board I would have a tech take a look and give you an estimate
Posted on Jan 03, 2010
Toshiba 32kv500b
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 26, 2016 | Toshiba Televison & Video
When I take a picture the picture is all black
I just tried something that I read a few days back tried it then but just tried it again. I held my Canon Power Shot S3 SI Camera Lens up to a Very Bright Light and started Taking Pictures started in TV mode then kept switching modes but taking lots of pictures in the different modes kept checking after taking a few I could start noticing that the screen was getting lighter and lighter with each picture that I took ... and Finely it started looking more and more like a picture.. and now my baby is back working...... thanks to who every the person was that posted about using a light to get her the Death of the Black Screen working... Just a little hint make sure that the light is really bright a flashlight did not work the yesterday for me so today a used a lamp and now me and mt Camera are both doing the Happy Dance .... Hope This May Help Others Who's Cameras Have Been Hit With The BLACK SCREEN OF DEATH....hope this works for you like it did me.:)
Feb 04, 2013 | Pentax *ist DL Digital Camera
Samsung television flickers to bright white fuzzy picture
In such cases, we have to ensure that it is not the input device that is causing this problem. So, please switch your input device to something you are sure, works. If you notice same problem, look for loose contacts in inter connecting cables and jacks. If problem persists, please refer it to a qualified service technician.
Jul 28, 2012 | Televison & Video
My tv's screem is little dark
Hello
If you set the lamp mode to LOW POWER, each time you turn ON the TV the lamp will start out at HIGH BRIGHT mode, but will switch to Low Power mode after a short period of time. You may notice a change in screen brightness when this happens. This is not a malfunction.
Just check whether you have selected this mode. Go to its user manual [P57]. All details are there about the lamp brightness settings. If it is not set to Low Power and still you get a dim picture, the lamp may be weak and has to be repaced. OK.
Nov 23, 2011 | Toshiba 65HM167 65" Projection Television
I have a toshiba dlp, replaced the ballast and the lamp. Now the problem is when i put the tv on it takes a while before i get a picture, It starts off very dark then will lighten up gradually. What can be...
It is normal for your TV to take a few moments to reach a brightness level that you can enjoy. A typical Mercury vapor lamp will take amout 2 minutes before it reaches it's optimal brightness. It will continue to increase slightly about 10 minutes longer, but you will not see those subtle changes. So, your TV is functioning as it should, just enjoy the show. If you want to learn a little more about the Mercury Vapor lamp it your TV, please check out my Tips & Tricks. I hope this was of some assistance.
Mar 27, 2010 | Toshiba 52HM95 52" HDTV Projection...
Replaced lamp, still having picture problems.
take it to an authorized samsung service center, your color wheel may be broken or your dmd maybe damage.
Apr 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Black screen. Power light binking from dim to bright
I have exact same problem but mine happened to 2 of my x2gen monitors at the same time,really strange.
One was purchased 01/07 and the second 04/07
Took my PC in, no problems
Took one of the x2gen in,was told monitor is bad
How could both monitors go bad at the same time???????
Mar 20, 2009 | X2Gen MW22U Monitor
Horizontal stripes & a buzzing screen
When it does this, can you press on the back of the screen and get any change? If so, then you have a loose screen connection. If not, then you most likely have a bad or failing screen that will eventually go out completely. The thing is, if it's a failing screen, it may last years, or it may go out the next time you turn it on. You can never tell with them. I'm betting on a loose connection.
Aug 22, 2008 | Toshiba Satellite A135 Notebook
Toshiiba Screen Dimmin
bad video, possiblem, but if the battery is low needs a recharge, to see if problem persists remove battery and run soley on home power.
Jun 29, 2008 | Toshiba Satellite A135-S4527 Notebook
Screen shrinking
You have bad solder connections on the vertical output IC or on one or more of the surrounding components. Good Luck
Jul 21, 2007 | Toshiba 36A40 36" TV
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Electro Med Services...
