Question about Zebra Eltron TLP 2844 Thermal Label Printer
Our Eltron Thermal printer 2844 suddenly is "not recognized"
Using UPS window XP computer. Have rebooted and turned all machines on and off. Also tried other USB ports. Device show up on controll panel but it will not re spool etc.
It was a printer associated with UPS> They tried to install new drivers but it did not work: they are coming to repair machine today
Posted on Jan 28, 2009
Installed my zebra lp2844 on a new windows 7 machine. it worked at first until i turned the computer off, now it just says device has malfunctioned. USB Device not recognized. I have uninstalled and...
If you are using an Eltron printer, and you have not installed the printer driver, follow the instructions below. You must install the driver provided below. The driver provided with your printer will not work with UPS Internet Shipping.
Installing the Eltron Thermal Printer
Make sure you have set up your thermal printer equipment, cables, and thermal labels as described in your UPS Thermal Printer documentation.
The following instructions will help you download and install the UPS Thermal Printer driver program (UPS_319_117.EXE) to your selected directory.
  1. Select the Download the UPS Thermal Printer Driver link below.
  2. When prompted by the File Download - Security Warning dialogue box to choose Run, Save, or Cancel, choose Run. When prompted by the Unknown Publisher Security Warning, "Are you sure you want to run this software?", choose Run.
  3. Select Unzip to extract the files. Once files are extracted, select OK and then select Close to close the window.
  4. Navigate to C:UPSDrivers and double-click the file setup.exe to start the Installation Utility.
  5. Select the language to install.
  6. When prompted, select the Printer Interface you will be using, then click Next.
  7. USB Connection or Other Connection and click Next. You will be prompted to choose your printer model from a list. Click Next after choosing your printer model and the driver will install.
http://www.ups.com/content/us/en/resources/ship/create/labels/technical.html
Nov 24, 2010 | Zebra TLP 2844-Z Thermal Label Printer
LOOKING FOR LABELS FOR ELTRON-ZEBRA 2844 CTP UPS THERMAL PRINTER
If you are printing UPS labels, call UPS and ask for some. They will give them to you for free!
Aug 24, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Everytime I print a label it stops short of the
This is an easy printer to fix since there is only one control button. Turn the printer off. Hold the green feed key down while turning the printer on; once the red light begins flashing, let go of the feed button. This will do three things: the printer will calibrate with the installed media, it will print a configuration label and the printer will go into dump mode. Press the feed key again. One more label will come out with with the words "Out of Dump" printed at the top. If the printer still fails to print, remove the ribbon and try the same procedure with direct thermal labels (UPS or FedEx). From there, consult the manual for more troubleshooting tips.
Jan 29, 2010 | Zebra Eltron TLP 2844 Thermal Label...
LPT Zebra UPS Thermal 2844 Printer Printing Slowly
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash2.gif (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time.
You've just set the printer back to factory default and dumped whatever settings where mucking it up.
If this doesn't fix you, it is an issue between the software you are using (? what kind is it?) and the printer driver.
Aug 05, 2009 | Zebra Eltron LP 2824 Thermal Printer
Is there a driver for eltron 2844 ctp using windows vista.
http://www.zebra.com/id/zebra/na/en/index/drivers_downloads/drivers/results.html?productType=7&printerid=58
copy and paste and download from the zebra support site the drivers for Windows Vista.
Jun 17, 2009 | Zebra LP 2844 Thermal Printer
UPS Thermal 2844 errors out every few hours without use.
You probably need a better driver. Try www.seagullscientific.com or call Andrew @908-725-1699
Apr 26, 2009 | Zebra LP 2844 Thermal Printer
Eltron 2844 CTP Printer on Ubuntu
I got it working by selecting the Zebra manufacturer, EPL2 driver.
Mar 12, 2009 | Zebra LP 2844 Thermal Printer
How to configure eltron 2844 thermal printer for usps label use
We are manufacturers of jewellery labels and know the problems that you are experiencing. We can offer labels which have been produced specifically to work on these printers
For more information contact: Global Imaging Group Ltd, www.globalimaginggroup.com
Feb 23, 2009 | Zebra Eltron TLP 2844 Thermal Label...
2844 UPS Printer Prints Duplicate Labels
The quick and simple answer is to use a different driver instead of the 2488 driver that UPS provides, that is where the problem lies..
Under printer properties, Advanced Tab, I changed the printer driver to Zebra S4MDT-200dpi and now the printer works fine. Prints labels correctly, and most of all only one label at a time... The drivers are there in the UPS software, just change which one you use and go...
John Plemons
Dec 04, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLp 2844 (printer not connected error message )
Go to Control Panel, Administrative Tools (in Clasic view), and double click on Services. Scroll down and right-click on "Print Spooler". Start (or Restart) it and your printers will reappear in the "Printers and Faxes" window, and the spooler will try to send jobs to the printers again.
If you check the Properties of the Print Spooler, on the Recovery tab, you can set it to "Restart the Service". I set mine to Restart on the First Failure and Second Failure, and Take No Action on the Third Failure, in case something really needs attention.
Jun 23, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Zebra Eltron TLP 2844 Thermal Label Printer Logo
442 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
