Question about Canon imageRUNNER iR C2880 Color Copier
Error 000045 in ir2880 - Canon imageRUNNER iR C2880 Color Copier
  • 128 Answers
E045 is the HP sensor error located inside the right door. It maybe dirty or dislodged. Clean or replace. No special reset, just OFF/ON.
OHP Sensor may be out of alignment with the reflector in the Paper Feeder Frame Assembly, there may be a loose connection, or it may be faulty.
Open the Right Door Assembly and the OHP Sensor (with a blue tinted lens) is located on the machine side in the center below the registration roller and the ITB. Ensure that the sensor is correctly seated in the mounting frame and re-seat the harness to the sensor. If code will not clear replace the sensor. (RH7-7129-020)
Posted on Jan 22, 2013
Canon ir2880 power is not coming
check the power cord or AC outlet
Apr 17, 2014 | Canon imageRUNNER 2018 Copier
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
Feb 05, 2014 | Precor Exercise & Fitness
Error 000045
OHP sensor error, clean or replace.
Aug 08, 2013 | Canon imageRUNNER C3170U Color Copier
Need a error list for a Canon IR 600 imagerunner
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
Ohp sensor error in ir2880
Jan 22, 2013 | Canon imageRUNNER iR C2880 Color Copier
Ir 3100 have erroe 000045-0001
OHP SENSOR ERROR.REPLACE OHP SENSOR
Apr 04, 2011 | Canon Office Equipment & Supplies
HOW DO I CHANGE THE RIBBON?
You can use the below link that will take you to the brother FAQ website. Follow the FAQ to change the ribbon.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000500/000045/faq000545_001.html?reg=us&c=ca&lang=en&prod=fax575_us&Cat=7
Thanks,
Pat
May 13, 2010 | Brother FAX-575 Plain Paper Thermal
Canon ir 3530
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
How do I change the drum in a ir2880 copier? I cannot locate the drum units
open front door lower large blue handle below the toners there is a cover with a latch on it move the latch the door will open the drums are behind that cover
Oct 06, 2009 | Canon imageRUNNER iR C2880 Color Copier
Canon imageRUNNER iR C2880 Color Copier Logo
76 people viewed this question
old marine
old marine
