Washer turns on lights up and works although it sounds the "door open?" alarm when I try to start the cycle. I changed the auto lock mechanism didn't fix anything! any suggestions?
SOURCE: remove bosch axxis 2060 washer motor
Remove the back panel to get to the motor which is at the bottom at the back. Notice two bolts holding the motor into the mount. Remove these two bolts. Notice the back part of the motor is sitting in the mount with black rubber washers. Carefully, pull the motor forward, and this will be abit hard. You can take a flat head screw driver and tap down (in between) on each front plastic washer and the motor will slowly come forward. Becarefull because there is a wire harness still attached to the motor. You have to take wire cutters and clip the placstic band holding the wire harness to the motor. Then grip the harness and wiggle it free. Then remove the single wire also. Putting the belt back is a bit tricky too. Make sure you put back the two black rubber washers and the two front plastic washers.
SOURCE: Bosch Axxis Washer Detergent slot codes; what do they mean?
soap goes in far left
softner middle
liquid all fabric bleach or powder bleach in far right
