Question about ASUS Computers & Internet
I have a k42jp asus laptop. It is not turn on with the first time peressing power button, actually when I press this button fan and device become to work but there is nothing on screen, I have to hold it and turn it off manually and try more.. somtimes needs to do it again and again.. what's the problem ? i'm sure it is not from display or power button
    Problem Solver:
  • 13 Answers
I had the same problem.
Switch on and see whether CAPS LOCK indicator works if not it is the problem of BGA IC and has to be taken to a service centre for replace
Good Day
Posted on Jan 22, 2013
Testimonial: "tnx for your answer, I tried that and caps lock indicator workd, I took that to a service center but they coudnt find the problem, so i said maybe It was BGA IC and stil i'm waiting for their call... they said it can be from the power circuits.. i am confused and sad because really i need this device for my thesis.."
  • Ashish Deepak Jan 27, 2013
    If the caps lock is working then it's the power problem and not the BGA IC,you can get your lap within a day or two
  • 34 Answers
SOURCE: have a Eee PC 701 SD. I can turn on the laptop but once it's on nothing is displaying on the screen. I tried every button possible but nothing works.
Its possible that the LED light that illuminates the screen is dead. If you look very closely can you make out any information on the screen or is it absolutely black? If you can see text or Windows, then its likely the backlight.
If you cant, try plugging an external monitor in to see if it is even booting. Also look at the HDD light (bottom right of the keyboard) to see if it flickers on and off while starting. If there are no lights, then you may have a dead unit... Get er fixed.
Posted on May 15, 2009
frankzjm
  • 191 Answers
SOURCE: NO VIDEO OUTPUT FROM LCD OR EXTERNAL MONITOR ON TOSHIBA SATELLITE L20 LAPTOP
you may do follow steps
1) eheck memory : reseat all RAM or change other same model RAM
2) take out wireless card at back of laptop MINIPCI. try it
3) still nothing run, your otherboard hardware damaged, need to change the motherboard. the parts please reference here
http://shop.ebay.ca/items/__Toshiba-Satellite-L20-motherboard_W0QQ_kwZToshibaQQ_kwZSatelliteQQ_kwZL20QQ_kwZmotherboardQQ_ckwZlaptop?_trksid=p3286.m104.l1200
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
Posted on May 22, 2009
  • 998 Answers
SOURCE: Laptop won't boot (display problems)
If the diagnostics displays on the LCD screen but you get no display when Windows starts to load, it sounds like you have a video software driver problem. Try tapping the F8 key when you power on your laptop and boot in Safe mode. If it works in safe mode then you need to check you driver. You can also try connecting the laptop to an eternal monitor and see what happens.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 09, 2008
jmgldsmth
  • 1889 Answers
SOURCE: My Compaq F750US won't turn on
There is a very good chance that your cpu got too hot and, has died. replace the cpu. you should be able to remove it with only a blade screwdriver.
e-bay sells replacements and, the manual for your computer and, instructions can be found at: HP.com
Posted on Jan 24, 2010
  • 266 Answers
SOURCE: my dell xps m1530 laptop seems to be on but nothing on screen
Remove the battery and power cable from the system and press the power button for about 5 seconds, then plug in the charger and start the laptop. it will work. shutdown it and put the battery back and start once again . now you can see its working
Posted on Feb 12, 2010
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Have acer 7540 On restart have error 0211 key
Try this fix:-
This problem was on a Gateway NV52 running Vista Home Premium (64) and this is how it was resolved, with the help of their tech support:
1. Turn off computer and unplug power cord.
2. Disconnect all external devices
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED's and listen for power supply fan.
7. If LED's are on or power supply fan starts spinning, watch for boot screen
8. If computer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
Sep 22, 2014 | Computers & Internet
No power model A8S
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
  4. if still there no sign of life then send it to nearest service centre
Mar 12, 2014 | ASUS R500N Laptops AMD A8-4500M, 750GB,...
My asus laptop's power button need to press several times to start...plz help
Mabie power buton is broken or else.... but i need to know what is your asus pc model...
Jul 09, 2012 | ASUS Computers & Internet
My ASUS Eee PC 1005P won't turn on. This had been working up until 4 days ago when I left Australia to Bali. When I pressed the power button the power light would come on but there would be no fan...
Try turning it on with the battery without the charger. Then try turning it on with the charger without the battery. If it still doesn't turn on either way, it's already a problem with the laptop's motherboard. If your laptop is still in warranty, you should have it serviced. Otherwise you need to bring it to a repair technician.
Apr 04, 2011 | ASUS Computers & Internet
My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
2. Disconnect all external devices(open up the computer tower and then )
3. remove battery
6. Check LED’s and listen for power supply fan.
7. If LED’s are on or power supply fan starts spinning, watch for boot screen
8. If coputer begins to turn on, turn it off.
This should work....all the best
May 19, 2010 | Computers & Internet
ASUS X80L has no display
hello..try to remove memory and make a clean using a paper eraser..thanks...^_^ ...
May 13, 2009 | Computers & Internet
My Asus A6 Entertainment Series Notebook Won't Boot Up/ More...
go to
http://support.asus.com/download/download.aspx?SLanguage=en-us
use the auto find function for new users and this will install a Auto Find Navigation Tools on to your computer,
Let the tool find your motherboard and it will give you a list of the drivers available and Manuals as well
There is a NB Probe available for this model and it will tell you all about the devices and the operating temperatures of each device installed,ie,hard drives,fan speed and temperature,
memory installed ,cpu usage etc......
Very simple to use and its free thanks ASUS
Cheers Misterdj
Apr 15, 2009 | ASUS A6U Notebook
Computers & Internet Logo
758 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
