Icom-718 wont transmitte - Office Equipment & Supplies
Can you give me details about your station, antenna, ground, power supply, etc. I would be glad to help if I can.
Ed Sagen, K5ES
Sagens@juno.com
Posted on Feb 13, 2009
Cannot transmitt
The Icom 756 Pro is a very expensive radio. If you bought one and it's not transmitting I really recommend taking it back. It could be anything from the mic, power supply, final transistors, board, anything really. It's going to need to be scoped and looked at in person.
Jun 30, 2016 | Icom Transceiver Ic-756proii
? new bp 200 replacment for bp 199 will not operate my ic t8e radio
The IC-T8E is the Icom VHF / UHF Amateur (or "Ham") transceiver capable of wide-band AM & FM receive and 6 meter (50Mhz - 54Mhz) , 2 (144Mhz - 148Mhz) meter and 70 centimeter (430Mhz - 450Mhz) FM only transmit - when appropriately licensed by your country's communications authority.
RigPix Database Icom IC T8E
Any FM transmitter operating in those frequency ranges will be received and played thru the speaker - unless they are encoded with a squelch decode sub-audible tone or digitally encoded squelch control that does not match the one set to the IC-T8E. Program the squelch to be open or to match that of the transmitter so that the radio will play only when that particular transmitter is transmitting.
An FM transmitter operating in APCO25, DSTAR, etc. will not be decoded as these are digital signals that the ICT82 is not capable of decoding.
I was unable to locate any "BP200" radio you mentioned, so I can't comment on their capabilities or if they have an incompatibility in encoding, frequency, etc.
Mar 11, 2015 | Radio Communications
Hallo iam using a icom 718 on 28mhz up to 14mhz have a problem of a high swr reading but the antenna is fine then power drop away
Check the feedline to the antenna, and the antenna itself. High SWR means that power is being reflected back from the antenna. A good discussion of SWR may be found here: http://www.hamuniverse.com/wc7iswr.html
If you antenna is designed for 10M and your are trying to transmit 20M on it, there will be a significant mis-match. You may want to look at installing a better broadband antenna, such as an OCFD that will operate better on multiple bands.
Feb 18, 2015 | Icom IC-718 Base radio, HF, 100W
How to get up/down functions on hp508 ham mic to work with icom 718
The IC-718 requires a 470Ohm resistor for the down button and grounds pin three with the up button directly. That isn't standard on the hp508 mic. It is designed so that the up/down buttons work for kenwood radios, and they are completely different. The kenwood uses pin three for down and pin 4 for up and they use a different pin for ground. You could make a special cable with the resistor built in and the correct pins connected to the up/down buttons and that would work.
Oct 10, 2014 | Radio Communications
Icom ic 718
try unplugging it the plug it back in.I am not up on ham but they are basically the same as CBso I would have to dig around to get an answer to the question .It may be worth your while to call icom to see if they can answer your question.
Apr 19, 2014 | Icom Radio Communications
149 people viewed this question
k24674
jasbo
jasbo
