Question about Jules Jurgensen 7996SS ( ) : Swiss Quartz Movement Watch for Men
What kind of battery to use in my jules jurgensen quartz watch
4 Suggested Answers
escapement
  • 2334 Answers
SOURCE: How do I change the battery of a Jules Jurgensen pocket watch.
First you have to get an eyeglass and examine watch caseback. Can you see the joint or is it monoblock? If there is joint, get strong knife and press into it. Some of watch casebacks are very tight, so, apply great pressure but do not let the blade slip or you will damage the movement.
If the case is monoblock, then you have to open it from dial side.
Be very carefull when doing it as any slip of the blade will damage your watch.
Good luck.
Posted on Dec 19, 2008
escapement
  • 2334 Answers
SOURCE: Hi there hope you can
All watches should arrive with battery fitted. As now there are too many variations of watch movements, it's impossible to tell exact battery code without seeing the watch. Nearest watch repair shop will be able to tell you that.
Posted on Jul 30, 2010
escapement
  • 2334 Answers
SOURCE: Looking to adjust the size
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Feb 25, 2011
I got the plastic cover off the face but cannot figure how to get to where i would put a battery in
Most pocket watches open in the back. Usually you have to have a very thin bladed instrument to pop off the back of the case. Since this is a gold watch I would take it to a jeweler to look at it since it is very easy to scratch up the case if you aren't careful.
Jan 28, 2014 | Jules Jurgensen 7381 Pocket Watch
How do I set the hourly chime feature?
Place the bottom window in the Date mode. Then press both bottom buttons simultaneously. A small "bell" symbol will appear in the top window, upper left corner. Hope that helps.
Sep 22, 2011 | Jules Jurgensen 7996SS ( ) : Swiss Quartz...
Hi there hope you can assist me. My first question to you, and thanks lots I have a Jules Jurgensen watch, and it arrived brand new without a battery. 1) Does a battery for a 7837BR normally...
Jul 30, 2010 | Jules Jurgensen Watches
Where can i place an order for jj watch band (5001YG)
The only place you can get an original band for a watch is from the actual watch vendor. If its more then a few years old, it may even be discontinued.
Jules Jurgenson Corp (610) 667-3500
101 W City Ave
Bala Cynwyd, PA 19004
Good luck.
Jul 23, 2010 | Jules Jurgensen 5001YG ( ) : Swiss Quartz...
Watch does not work after changing the battery
mcdevito75 here, You can try, double check the battery instalation in the watch, If all is good, try to pull out the stem and move the hands as if setting the time, then push stem back in. It"s also possible you have a weak or even dead battery, even though it was bought new.
Jul 02, 2010 | Jules Jurgensen 7793IF ( ) : Swiss Quartz...
Watch Instruction manual
The best thing to do for instructions for a Jules Jurgenssen is to contact them. You may also try retailers who carry their product.
Jules Jurgensen Helbrose International
101 West City Avenue
USA
Corporate Phone: cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif1-800-220-1233cb_transparent_r.gif
Sep 22, 2009 | Watches
Needs battery replacement
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here's my suggestion. Take it to the jewelry dept at Walmart. Do you have one where you live.
They'll replace for free - Battery $8
Watch how they do it with their tools and you'll know how to do it yourself in the future.
Good luck
Dec 12, 2008 | Oakley GMT OAK0531 Wrist Watch
New watch..Jules Jurgenson day-date..the stem cap is loose.
remove the cap and put a tiny drop of locktite glue on it. spill some glue onto a piece of glass or an old plate and use a sewing needle to put a tiny drop of glue in the hole then screw it back on and wait till the remaing glue on the glass is gone hard before pushing the stem back in .. this last bit is important so as not to glue the stem to the watch. if this helps please rate me joe
Nov 12, 2008 | Jules Jurgensen 5004PB ( ) : Swiss Quartz...
Jules Jurgensen 7996SS ( ) : Swiss Quartz Movement Watch for Men Logo
Top Jules Jurgensen Watches Experts
Tom Chichester
Jim Dowell
Buddy lotter
Buddy lotter
Are you a Jules Jurgensen Watch Expert? Answer questions, earn points and help others
