Question about Marantz Audio Players & Recorders
Reset Marantz sr5006 to factory settings
Need my Marantz SR 5006 back to its factory settings. Just as it had come out of the box
    Genius:
  • Marantz Master
  • 1,054 Answers
Hold the 'display' and 'zone select' buttons, then press power. Display should blink all segments. Let go of buttons, and your good to go
Posted on Jan 22, 2013
5 Suggested Answers
SOURCE:
SOURCE: Marantz SR 7200
It is likely that the PA stage has developed an offset voltage in the output stage. The faulty amplifier channel can be found by progressively disconnecting the collectors of the of the power transistors until the protection fault disappears. Once the faulty channel is found the the cause of the offset has to be traced to the faulty transistor or resistor. Don't forget that if you can smell smoke or burning then there are likely to be components(esp transistors) that have been damaged by the fault.
I had a Luxman unit that destroyed 5 transistors in the output stage that was due to an open .5W resistor in the driver stage.
Good luck.
Posted on Mar 29, 2009
SOURCE: Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Posted on Oct 02, 2008
killer_clown
  • 86 Answers
SOURCE: NO POWER - MARANTZ SR-5000
you mite not have to reset it, try checking ur fuses, it could of triped the cicrut when the power went out, normaly thats what happens unless it was a direct contact then, u mite wanna go get a nother receiver, and what i mean by direct contact, i mean like directly pluged into the wall
hope that helps
Posted on Feb 13, 2009
SOURCE: Marantz SR-18ex remote control number
If you mean the model number, that is: RC-18SR
Posted on May 15, 2009
Hi for some odd reason my Marantz sr 5006 is completely out of control I can't turn the volume up or down I tried resetting it several times what might be causing this
If it is a twist type knob that regulates the volume control they can often brake so you will need to take it off to inspect it you can do this by pulling it directly towards you ( a small screw driver placed behind it can help to get it off ) then you will be able to check to see if it is broken or not or if you can then control the volume by turning the shaft that the knob was meant to be attached to , a small amount of epoxy glue should fix the knob back onto the shaft if this is the problem .
Oct 18, 2017 | Marantz Audio Players & Recorders
Tip
Marantz SR-7200 reset
This was documented on the Marantz website briefly a year ago and is no longer available. My SR-7200 develops "click/pop" problems and a reset cures it of these issues.
While powered "off," on the front panel, press: A/D + FP +Dimmer (3 buttons) and power the unit on.
This reverts to original (out of box) settings. You then must reprogram input sources, speaker setup, levels and radio stations.
on Oct 03, 2011 | Marantz SR-7200 Receiver
Green screen
Try to reset to your Marantz to factory settings, or try the newest Firmware. :)
Jan 21, 2014 | Marantz Audio Players & Recorders
Turns off automatically
probably have a short in the amp section that needs to be repaired.
Nov 20, 2013 | Marantz SR5006
Won't log into pandora
http://us.marantz.com/DocumentMaster/us/PressReleases/PandoraProblem-M.pdf
Dec 01, 2012 | Marantz SR5006 AV Receiver with Networking...
I'd like to know how I can reset/initialize/reboot the microprocessor of the Marantz SR 8002 AV Receiver. That info is not available on the user's manual.
Hold down MULTI & SPEAKER A/B buttons on the front panel of your receiver simultaneously with the power turned on for 3+ seconds. *Please note ALL settings will be reset to factory default. This includes all of your digital audio and video assignments as well as your radio stations and calibration settings.
Jul 04, 2011 | Audio Players & Recorders
Marantz SR9200 shuts off intermittently while watching or listining.
Check all speaker connections. unplug everything.. start with just L and R speakers. Do a mic calibration..also check all your source inputs to the amp. start from the basics. Is the amp still under factory warranty? I used to install marantz...also make sure unit is well ventilated. IF you are using audio zones in your place..with in wall volume controls..make sure they are impedance matched. VOLUME may be set to high...overdriving the outputs..eventhough audio may not be loud. Set volume to -30...?
May 06, 2010 | Marantz SR-9200 Receiver
5,047 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
