Question about Apple iPod Audio Players & Recorders
Ipod classic has no sound
Everything works fine but there is no sound. It wasn't dropped on the ground or into water. It started with a little static type noise then nothing. When it started i would fiddle around with the wheel and the sound would come back, but not anymore. Is it worth fixing it ? It's an iPod 5th gen 30 gig.
  • Apple Master
  • 27,725 Answers
Damaged hardware is responsible for the most obvious iPod sound problems. In such cases, Apple may be able to help you fix the problem, depending on the status of your warranty. All iPods have a one-year warranty according to Apple's website. Software problems can also affect your audio. For example, downloading a non-certified Apple application can stop your sound from working correctly. Returning your iPod to its original factory settings fixes many of these software glitches.
Plug in a different set of headphones and test the sound. If that set works, your old headphones were the cause of your audio problems. If your iPod still doesn't work, proceed. Open iTunes. Plug the iPod into your computer with a USB cord. Click on your iPod on the left-hand menu. The iPod will be listed under the name you assigned it when you first set it up. Click the "Restore" button on the menu. Leave the iPod alone while it restores. It may take several minutes. Test the sound once the restore is complete. The iPod syncs after restoration. Once the sync is complete, the process is over. Contact the Apple Technical Support line at 1-800-275-2273 if your audio still doesn't work. Have your iPod with you. Hope it helps
b>
b>
Posted on Jan 22, 2013
  • Serge Bergeron
    Serge Bergeron Jan 24, 2013
    Thanks, but it still won't work. Apple offered to replace it with a new 160gig model for 150$
  • Brian Sullivan
    Brian Sullivan Jan 24, 2013
    Thats a bit rich How tecky are youhttp://www.youtube.com/watch?v=slIo8PX06... A step-by-step tutorial on how to replace the headphone jack & hold switch assembly in the iPod Video 5th generation (30gb, 60gb, or 80gb). Anyone with a little patience should be able to complete You can buy these on eBay for roughly $6 if you want to have a tryhttp://www.ebay.com.au/itm/Original-head... $3.89
3 Suggested Answers
jazzyboy11
  • 728 Answers
SOURCE: 30 gig ipod is frozen. Hard reset doesn't work.
You may be doing the reset wrong. Try this just to be sure: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps you!
Posted on Aug 05, 2009
  • 96 Answers
SOURCE: my ipod screen is blinking & won't turn
1. Try a 'Restore'. Connect your iPod with the cable that came with it to the USB port on your computer. In iTunes, click and (Restore). 2. It's possible that the hard drive is dying. Google "iPod repairs" in your country and you should be able to find someone who can fix it. The usually have a self diagnosis on line so will get an idea of the cost before you begin
Posted on Dec 01, 2009
Ipod classic won't turn on, screen flickers
It sounds like you have a hairline fracture in the mainboard. These circuit boards are very sensitive, thin and fragile. Once they break, electronic parts may short out or remain disconnected entirely. not repairable I am afraid.
Dec 23, 2013 | Apple iPod classic MP3 Player
Feul pump
Sounds like vapor lock. Leave the cap from the gas lid undone for a little while.
May 05, 2013 | Cars & Trucks
My new Panasonic SC-HC57 is showing a 'checking connection' message when I put in my ipod Classic into the dock. I've upgraded my ipod to the newest software through iTunes, but still no
Not all ipod classic work with your SC-HC57 you need an older Panasonic SC-HC30 to work with that ipod :( or an iphone or ipod touch to work with your SC-HC57
Dec 26, 2012 | Panasonic SCHC57 SC-HC57 SC HC57 Compact...
My iPod classic has a white screen
Sounds like it's broken. Not likely to be easy to repair.
Aug 06, 2012 | Apple iPod nano
White screen on ipod, 2 beeps on restart
I just had this problem as well, i tried everything, so i let it sit here for like a month, while deciding what to do with it. I just found a response today that said if you don't care about losing it try dropping it on the floor a few times, I'm not kidding you that it worked lol. After i dropped it twice I restarted it and the apple logo showed up and works fine now, anyways hope this helps, although i don't know that I'd recommend it for everything it did work for me.
Jan 30, 2010 | Apple iPod nano MP3 Player
The middle button does not work. i cannot select anything. everything else works perfectly fine. i have a case and never dropped it once. please help thank you thank you.
Try resetting the iPod. To do this, turn on the iPod and hold down the middle (select) button and the play button at the same time. Hold buttons down until the screen turns off then back on. NOTE: This will NOT delete your iPod content.
Dec 28, 2009 | Apple iPod classic MP3 Player
I have a 1991 chevrolet caprice classic and
BAD GROUND. CHECK GROUND CONNECTION IN THE KICK SIDE OF THE DRIVER PLACE, UNDER CARPET YOU WILL FIND A NUT ATTACHING SEVERAL CABLES TO CHASIS, CLEAN AND RE ADJUST
Sep 18, 2009 | 1991 Chevrolet Caprice
Ipod wont play tracks
Does your iPod start up normally?? Is it an iPod with a clickwheel? If everything else is working fine, can you navigate at all?
Nov 22, 2008 | Apple iPod classic MP3 Player
41 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
