Question about General Filters 1099-LH Humidifier
Vibration in water feed
When the humidifier turns on,their is a vibrating noise and the vibration can be felt in the tubing from the hot water pipe to the selenoid.
  • robert kowalski Jan 24, 2013
    I removed the screen filter and that eliminated the vibration.ordered a new filter and will install it upon reciept.
    New Friend:
I have a General Aire humidifier on my furnace. I was having the same issue with vibration noise. I took the solenoid off and took it apart. There is a part that had a screen and a very small hole. I cleaned all the parts in my ultrasonic cleaner. The I reassembled the solenoid. It had an electromagnet that was held on by one nut. I reinstalled the solenoid mechanism and started the system. I had way better water flow, but still some vibration. I tightened the nut holding the solenoid and electromagnet together and the vibration stopped.
Posted on Jan 22, 2015
Unclog personal humidifier doesn't work
If this is an ultrasonic humidifier, in the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Feb 25, 2015 | Humidifiers
Slant fin doesnt turn on
In the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Jun 23, 2014 | Slant Fin Humidifiers
Noisy start-up
If it is a vibrating motor noise, then some oil may help but make sureit doesn't drop into the tank. The little Motors used in these things have a limited lifetime and bearings and corrosion a of insulated iron plates that the copper wire of the motor coils wrap around do tend to corrode and lose their efficiency.
Otherwise, try a bit of foam padding to isolate the tank from the motor assembly - there might be some slight vibration there.
Mar 13, 2014 | Crane Evaporative Cool Mist Drop Shape...
Have an HE225A, B By-pass Flow thru humidifier about 9 yrs old. Just change the antimicrobial pad with recommended Aprilair 110/220 and when the furnace comes on, there is a loud, hum-like, vibrating noise...
Make sure the new pad you installed is in the right position. The pad is marked with a black dot about the size of a quarter. This end should be up for proper water flow through the pad.I fwater flow is being restricted at the pad the vibrating nosie that you are hearing is the dry portion of the pad vibrating agaist the platic housing of the humidifier. This noise stops once the pad has absorb enough water in this area of the pad.
Jan 23, 2011 | Honeywell HE220A1019 Whole House...
Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
Feb 03, 2010 | Aprilaire 550 Humidifier
Routing waterline to pad
1/4" flexible copper pipe. Tap into your cold water line using the included saddle valve (pierces the pipe), attach the 1/4" flexible copper pipe to the saddle valve on the cold water pipe and the solenoid valve on humidifier unit using the included compression fittings. Tada!
Dec 10, 2008 | Aprilaire 550 Humidifier
Loud noise
Replace the water valve... It"s vibrating when closing. Do you have hot water feeding the unit?
Oct 22, 2008 | Aprilaire 550 Humidifier
Lack of humidity
Try the following test, ( I will resume this is a flow through humidifier)
Spray water directly oin the filter make sure it is saturated. Some water should leak from the bottom. After 10 min measure the Humidity to see if this helped. If there is a higher level of humidity the pbm is that not enough water is saturating the filter. Check the level of the filter & water feed nozzle.
Option 2 is to connect the water feed tube to a Hot water source.
Hope this helps.
Dec 28, 2007 | Honeywell HE220A1019 Whole House...
Noisy humidifier
A noisy humidifier may be the result of an unlubricated fan motor or a drive mechanism clogged by debris. Periodically clean the water reservoir, fan, and nozzle to ensure that they are clean and working properly. To keep your humidifier working smoothly and efficiently, lubricate the fan motor bearings with SAE #20 oil. Be sure to consult your owner?s manual for proper care and maintenance procedures. If it seems loose, vibrating parts are causing the noise: 1) Disconnect the power. 2) Remove the cover and look for any vibrating parts. Tighten screws, if necessary. 3) Wiggle the fan to see if it is loose on its shaft. If it is, tighten the mounting fasteners. Lubricate the motor's bearings if suggested in your owner's manual. 4) If it still makes noise, call an appliance repairperson or take the unit into an appliance repair shop.
Jan 18, 2006 | Honeywell HCM530 Humidifier
General Filters 1099-LH Humidifier Logo
398 people viewed this question
Top General Filters Humidifiers Experts
Paul Carew
jdthefixer
Steve
Are you a General Filters Humidifier Expert? Answer questions, earn points and help others
