I have a Philips 42pf7421d/37 lcd tv having problems. When you first turn the tv on it seems to work perfectly fine. About 5 minutes later my picture cuts out and I get a scrambled screen. Turn it off and on, same problem. Any ideas? Hoping I can get this fixed cheaply doing it myself. Im handy but dont know much about televisions. Thanks
    Genius:
  • 1,669 Answers
First, you need to make sure all of the vent panels on the tv are clear of obstructions. Heating may be causing the problems. Next, get a hold of a clean, dry source of forced air and blow out the inside of the case and the internals of the tv.
Posted on Jan 22, 2013
SOURCE: RCA L32WD12 32in. HGTV LCD Television
I had the same problem happen this afternoon, so I took it apart, and the source of the problem is the key controller panel (behind the buttons). It's held in place by 2 screws, if you take the case apart, which is literally only 15 or 20 screws, and then loosen the 2 screws holding the key controller panel on, and then use a small screwdriver to space it out from the button caps. Tighten the screws, and put it back together. Just be careful not to let it go too far to the other side, or you'll have a problem with the menu going on and off at random, which is just as annoying.
Posted on Aug 01, 2008
SOURCE: LCD TV won't turn on, Screen and Standby light blink
I had a similar problem which I have partially solved. The power light flashing could be due to a shorted electrolytic on the power supply board but in my case it was a shorted IC on the main board, the one with the input connectors. The IC marked 7001 shorted and got hot enough to melt the plastic. Replaced it with a new one from Mouser. The supply measured on the end of inductor 5001 farthest from the IC reads 12V now. This is a surface mount part and has a pad on the bottom that may be soldered to a pad under it. I had to cut the IC apart carefully with a Dremel cutoff wheel to remove it. That fixed the problem with the light and the remote now turns the TV on and off so the logic is working.
I now have the problem of the backlight not turning on. The driver board, the ones with the transformers, are made by Intechwave, the only info I can find is here: http://www.peopleworks.co.kr/kor/product/product_list.php?intDivision=4&intClass1=16&intClass2=41
This a 45kHz RF driver and it is not starting. If I can figure out why I'll post it for all the people who reported slow or no turn on of the backlight. These boards should have 24V between the red wires on the connectors and ground, as mine do.
Posted on Jan 27, 2009
  • 187 Answers
SOURCE: 47" Philips LCD TV will not stay on and show a picture.
Your mainboard needs to be replaced.
You can get one on ebay and replace it or get someone who can do that for you.
if you still have guarantee, it is covered, if not you will need to buy it.
Posted on May 27, 2009
  • 61 Answers
SOURCE: TV freezes at "Philips" screen
a professional. -These electronics go threw a self diagnostic when they start up, normally they turn off when they find a problem.
Posted on Jun 01, 2009
roety
  • 585 Answers
SOURCE: my 42pf7421d/37 flashes a red light when i turn
Hi, philips (sony and others) uses the flashing red lights to give an error code, but all that means is that a circuit is probably shorted and doesn't always indicate specific components,.
42pf7421 is an LCD that basically has two large circuit boards in it. If you have technical ability you can examine the power supply to see if any capacitors are swollen on their top sections. this is a common failure in many LCDs and Plasmas, but would require soldering to replace them. If no caps look swollen troubleshooting this set would involve voltage checks , a service manual and board replacement.
Could be either the main board, power supply or possibly a bad screen (panel) If you have the set open you can sometimes see the LCD bulbs light for a split second indicating that a problem with either the panel itself or the ballast power section. If it lights for a second sometimes I can see that one bulb is not lighting. One bad bulb will cause the set to go into shutdown mode , indicating a bad screen (panel) .
I hope this info helps you decide on the options before you
1. call a tech expect to pay an estimate fee, parts and labor btwn $200-$1000
2.check the power supply, reseat the panel cable, look for a momentary light of the screen. order a suspected part and replace it yourself.
3. buy a new TV (sry bad option)
hope this helps
Eric
Posted on Sep 01, 2009
Philips TV model no.42PF7421D/37 has green line on left and clear picture goes to snow in 3 to 5 minutes
the tcon boar or the lcd panel is faulty. can confirm by replacing the tcon board .
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 04, 2017 | Philips 42PF7421D 32 in. LCD HDTV
I want to raise the picture on my Philips 42PF7421D/37
It is hard to understand exactly what you want to do. Here is a link to the product support site for this item. You can download all the manuals and software updates. You may also want to review the FAQs section. http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=us&ctn=42PF7421D/37
Feb 03, 2015 | Philips Televison & Video
I have a philips lcd tv model 42PFL7332D/37. Suddenly, the picture lost, but the sounds works perfectly. Can anyone help me to solve this problem?
Tv turn on now,u just get a flashes of a picture only a few sec. than dies and have sound left only?Yes,than those 2 long boards that call the LCD inverter boards are dead.These 2 long LCD inverter boards job are to help the LCD picture screen panel to have a backlight to produced the picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter boards for the replacement.
Nov 29, 2010 | Philips 42PFL7432D 42 in. LCD Television
I have a Phillips LCD tv model #42PF7421D/37. and
I know on the plasma TV's it was a matter of updating or downloading and re-installing the firmware/software for the TV to fix the issue. Go to the following page and if the model you have is indeed a 42PF7421D/37 download the software on the page. Make sure you follow the installation instructions to update the software otherwise the set will become a 150 lb paper weight.
&scy=US&slg=AEN&sct=LCD_TV_SU&cat=TV_CA&grp=SOUND_AND_VISION_GR&session=20091111140139_64.85.227.44&ctn=42PF7421D/37&mid=Link_Software&hlt=Link_Software">Philips Support Page
Nov 11, 2009 | Televison & Video
My 42pf7421d/37 flashes a red light when i turn
hope this helps
Eric
Sep 01, 2009 | Philips 42PF7421D 32 in. LCD HDTV
Screen Shift PLZ HELP
burn in run  a white screen
Jun 06, 2009 | Philips 42PF7421D 32 in. LCD HDTV
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
