Reset Marantz sr 5006 to factory setting - Audio Players & Recorders
SOURCE: Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Posted on Oct 02, 2008
killer_clown
  • 86 Answers
SOURCE: NO POWER - MARANTZ SR-5000
you mite not have to reset it, try checking ur fuses, it could of triped the cicrut when the power went out, normaly thats what happens unless it was a direct contact then, u mite wanna go get a nother receiver, and what i mean by direct contact, i mean like directly pluged into the wall
hope that helps
Posted on Feb 13, 2009
SOURCE: Marantz SR-18ex remote control number
If you mean the model number, that is: RC-18SR
Posted on May 15, 2009
  • 3 Answers
SOURCE: my Marantz sr 4001 receiver has no output. Is
my friend has the same problem with an SR 4001. the tech said it was an internal fuse soldered to the board. the display showed an error code that clued in the tech of the problem. I am trying to find the fuse on the board, and trying to get a value(Volts-amps) of the fuse
Posted on Jul 28, 2010
  • 11800 Answers
SOURCE: when i pout on my marantz sr-4320 receiver it is
The protection mode is engaged when there's a shor on one of the speakers outputs. This is a major malfunction and, to prevent the rest of the receiver to get fried, the entire system is put in an emergency shutdown mode - the Protection mode.
You must find out if the short is external - in one of the speakers - or internal - in one of the amplifying circuits. For that disconnect every single cable that plugs in the unit and start it .
If the protection mode is still activated then the problem is internal. The only way to identify the faulty circuit is to open the unit and test them all one at a time, starting with the 4 final transistors (2 per channel) - you need a good voltmeter and some basic electronics knowledge. In the worst case scenario the final transistors for both the channels have been shorted - it will cost you about $100 to replace them. Beware, soldering them in place is a delicate job, use grounding precautions and don't overheat them.
If the protection mode is gone then one of the speakers has failed. Either replace both of them or take them to a specialized repair shop, you can't fix speakers at home.
Posted on Nov 24, 2010
Green screen
Try to reset to your Marantz to factory settings, or try the newest Firmware. :)
Jan 21, 2014 | Marantz Audio Players & Recorders
Tip
Marantz SR-7200 reset
This was documented on the Marantz website briefly a year ago and is no longer available. My SR-7200 develops "click/pop" problems and a reset cures it of these issues.
While powered "off," on the front panel, press: A/D + FP +Dimmer (3 buttons) and power the unit on.
This reverts to original (out of box) settings. You then must reprogram input sources, speaker setup, levels and radio stations.
on Oct 03, 2011 | Marantz SR-7200 Receiver
Turns off automatically
probably have a short in the amp section that needs to be repaired.
Nov 20, 2013 | Marantz SR5006
Reset Marantz sr5006 to factory settings
Hold the 'display' and 'zone select' buttons, then press power. Display should blink all segments. Let go of buttons, and your good to go
Jan 22, 2013 | Marantz Audio Players & Recorders
I'd like to know how I can reset/initialize/reboot the microprocessor of the Marantz SR 8002 AV Receiver. That info is not available on the user's manual.
Hold down MULTI & SPEAKER A/B buttons on the front panel of your receiver simultaneously with the power turned on for 3+ seconds. *Please note ALL settings will be reset to factory default. This includes all of your digital audio and video assignments as well as your radio stations and calibration settings.
Jul 04, 2011 | Audio Players & Recorders
Marantz SR9200 shuts off intermittently while watching or listining.
Check all speaker connections. unplug everything.. start with just L and R speakers. Do a mic calibration..also check all your source inputs to the amp. start from the basics. Is the amp still under factory warranty? I used to install marantz...also make sure unit is well ventilated. IF you are using audio zones in your place..with in wall volume controls..make sure they are impedance matched. VOLUME may be set to high...overdriving the outputs..eventhough audio may not be loud. Set volume to -30...?
May 06, 2010 | Marantz SR-9200 Receiver
Do have an idiots guide as to how to wire up the SR-4200 to a TV
I will interperate this as:
"So you want to play sound through your Marantz SR-4200?"
You need to clarify what sort of system setup you have, however i will put down a few ways to wire this up to your TV.
If you have a Set-top-box that gets the TV Channels, that is where the sound comes from. If you have a TV that plugs straight into the wall, you will have to get the sound from the TV. Grab a RCA Stereo cable - (White and Red heads, if you don't know what they look like, Google it).
If you are unclear about this, i have tried to make a diagram down the bottom to explain how this is to work. What you will do is Take the sound from the Set-Top-Box or TV and reroute it into your fantastic Marantz SR-4200.
1. Plug Red Plug into the the Red Slot, and White into the White on the back of your set-top-box or TV Out (if you get it around the wrong way, the speakers will be reversed.)
2. Plug the other end of the cable into the back of your Marantz SR-4200 in the TAPE input or VHS input as they are analog signal inputs. Turn on Marantz SR-4200 and turn it onto Tape or Vhs (depending on where you plugged it in).
[Set-Top-Box or TV out] >-------> into >------> [Marantz SR-4200]
If you still don't get it, then try searching You-Tube for a guide "Plug Tv into Stereo". I myself couldn't turn up anything useful
Mar 09, 2010 | Marantz SR-4200 Receiver
Jan 10, 2009 | Marantz SR-18EX Receiver
hope that helps
Dec 24, 2008 | Marantz SR-5000
78 people viewed this question
 Grubhead
Grubhead
