Question about Dryers
Noise from mde4000ayw - Dryers
    Genius:
  • Dryers Master
  • 1,669 Answers
What kind of noise? If it is bumping then check to see if the load is balanced in the drum and not gathered in a ball and rolling around. If it is squeeking, that's a belt problem...etc.
Posted on Jan 22, 2013
How do you change a 3 prong cord to 4 prong power cord on a maytag neptunre MDE4000ayw
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
The paddle is not off but loose on Maytag neptune model mde4000ayw dryer, how do you make a repair on it.
you need to remove the drum, and tighten the paddle,, look on this site on how to remove the drum http://repair2000.com/wpoolbelt.htm
May 29, 2011 | Dryers
I have a Neptune electric dryer model MDE4000ayw. The clothes keep getting stuck around the barrel as the dryer is operating. What is the problem? It also makes a very loud noise as it operates.
You need to disconnect the dryer from power source, open the unit, it sound like the drum has holes on it that stucked your clothes when turning. this problem common to all maytag dryers. The front support glide had chop up . You might likely change the drum or tumbler.
Comment if the solution solve your problem
Dec 06, 2009 | Maytag Dryers
Maytag mde4000ayw won't start. moisture monitor
This is either your start switch or your motor that is bad. I would suggest you begin with the start switch. We love Maytag appliances and we also love the moisture monitor on this model of dryer.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct switch out to you asap.
We look forward to working with you and hope to get you back to drying right away.
Happy Holidays to you!
Ella
Nov 12, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag Neptune clothes dryer Model# MDE4000AYW Noisey squeeking sound. However, after a few minutes when it heats up, the sound goes away.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
trxcvhj
Jul 05, 2009 | Maytag Neptune MDE6700A Electric Dryer
Maytag dryer model # MDE4000AYW, Serial # 28636682YK: When running the machine ha low pitch growl and vibration. Possible belt problem?
Friend,
ngfam1 At your service!
Yes, Possibly a belt needs to be changed!
Do not put off the service call for delay may cause more severe problems if it is not a belt. ANY TIME YOU HEAR GRINDING SOUNDS LOOKOUT! A belt is usually only a squealing noise!
A good company to use that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Aug 30, 2008 | Maytag Dryers
Have maytag neptune model # mde4000ayw.its elect.mod. mades loud noise when turned on and drum is turning.
IF IT IS A LOUD DEEP HUM WHEN YOU FIRST TURN IT ON AND GOES AWAY AFTER IT IS RUNNING, THE MOTOR BEARINGS ARE WEARING OUT AND WILL FAIL IN THE NEAR FUTURE.
IF IT IS CONSTANT SQUEALING NOISE, THE IDLER PULLEY OR THE DRUM SUPPORT ROLLERS NEED REPLACED.
Apr 06, 2008 | Dryers
I have a Maytag Neptune MDE4000AYW electric dryer. It has been trouble free until now. The problem: When I pushed the start button, it started slow several times. I stopped using ut for 4 hours. Now,...
its a motor problem check to see if theres a capacitor that starts the motor it may be burnt out it will have 16uf etc on it or the motor itself could be faulty if its covered in lint they over heat.hope this helps.
Mar 07, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
