Question about Saeco Vienna De Luxe Espresso Machine
Hi guys, My machine (Saeco Vienna De Luxe)  only makes coffee at 160 degrees F, not hot enough for crema. What should the correct temp be? Thanks, Flyer 123
I will be taking the machine back into the shop for a new boiler, looks like I got a dud.
Flyer 123
Posted on Jan 28, 2009
I have a Vienna my question is temerature of hot watheroutlet and coffeeoutlet temperature i have about 70 degreds celsius is it okej?
The temperature varies according to the use if you just pure out hot water for fist time should be around 90 degrees however after one or two mugs can go up to 75 to 80. The same is for coffee. In any case the 70 degrees is low. Please note that I mention the temp. at exit point not in the cup since some seconds after the exctraction is normal to go at 70.
Jul 01, 2010 | Saeco Vienna De Luxe Espresso Machine
Machine will not steam
It sounds like the booster boiler is not functioning properly, either the thermostat tripped or the element is damaged.
Feb 07, 2010 | Saeco Vienna De Luxe Espresso Machine
I've owned this saeco vienne de lux for about 3
Hi
When was the last time you descaled the machine? Scale will build up inside the boiler and insulate the water from the heating elements. The thermostat is on the outside by the heating elements so it gets hot but your water is warm. There are other things but check this first.
Nov 22, 2009 | Saeco Vienna De Luxe Espresso Machine
Change the grind in Saeco Vienna Deluxe coffee maker
Hello kgspco.
You will need to work the 'dial knob' untill it free's it-self.
The higher the number the Coarse(r) the grind.
If you want rich - dark - strong coffee, set number between 4 - 8.
(if you can free it up - keep trying
Jul 06, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Deluxe not hot enough
Hi
They should have checked the temperature before shipping it out. There is a sensor on the back of the boiler that has (depending on how old the machine is) 2 orange wires. In the wire or on the wire is a resistor. You can remove the resistor and raise the temperature about 6 to 12 degrees, but I think you need a new sensor.
Jan 27, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Aug 05, 2008 | Saeco Vienna De Luxe Espresso Machine
Is there anywhere in Ontario that I can get a replacement portafilter for my Saeco Gran Crema esspresso machine?
Try to contact Saeco Canada to see if they can help you.
Saeco Canada Ltée
8145 Boul. St. Laurent
Montreal-Quebec
H2P 2M1
Tel: +1 514 3855551
Fax: +1 514 3855585
E-mail: info@saeco.ca
Visit the Web: www.saeco.ca
Jul 29, 2008 | Saeco Vienna De Luxe Espresso Machine
Vienna de luxe saeco
I look at the picture and the hole should not be there. You have to replace the boiler:-(
Jul 28, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe (Trevi)
Hi Mike,
Try to open the steam knob to see if the pump is starting.
Jul 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
167 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
