My E1EB-015HA electric furnance only blows cool air when heat is on.
My heater has been blowing cool air,
  • 49 Answers
SOURCE: reverse unit. Heater only blows air, not warm air
If you have a reverse cycle unit (heat pump) your compressor and your fan should be running. You need to determine if your compressor is running.
Posted on Nov 08, 2007
  • 18 Answers
SOURCE: Heater blowing out cold air
Yes you could have a bad overload on the heater element which is fairly simple to fix. To test for this pull the heater out and get an ohmeter set it to continuity and check the continuity first through the entire heater element then if there is none pin point the overloads and check to see which one has no continuity.
Posted on Dec 23, 2007
  • 69 Answers
SOURCE: wiring diagram for intertherm ac heating unit
Your best bet is to contact Intertherm and see if you can get the Installation/ owners guide.
Posted on Dec 21, 2008
louislevel_2
  • 374 Answers
SOURCE: Heil airconditioner is not cooling? Heater works
If no blowing air is coming out to your ac or evaporator fin,your blowing fan is not working.There are several factor to check qualified electrician or ac techician should do this.If you have knowledge on electricity and motor control,beside you should have clamp ammeter to use in trouble shooting of ac electrical circuit.Unplug your ac If there is an opening of blower fan of your ac mostly the top cover open this one locate the wire connection of blowing fan take the color and size.Open the terminal box below the control panel of ac and locate the wire of blowing fan.Check how many leads make sure to make sketch where it was connected from low,medium, and high there is coded color on it,discannect from the terminal, using clamp ammeter set to ohms probe setting R10 check continuinity of winding motor start at common lines(mostly balck color) of one test rod and the other to starting line(mostly red color)take and read the resistance if has a higher resistance your motor is burn out, also with the running line w/c has multple line for speed.If resistance complied to your motor rating or good,If not or burn out replace fun motor.Check your capacitor,doing this set your ohmeter to a higher resistance,connect one red test rod (+) one terminal of capacitor and one black test rod on (-)the other terminal the pointer will deflect steady to higher resistance then reverse the connection of the test rod,the pointer deflect again to higest resistance it will go slow backward setting to zero if you got this result your capacitor is good.But if it does not go set back to zero your capacitor is short.Replaced capaciter.
Posted on Mar 13, 2009
  • 659 Answers
SOURCE: need a schematic for nordyne intertherm model
Nordyne no longer has the E1 model in there literature not even in their archieved documents but I have included a link to for the E2 model which will be very similar to yours. These units are very simple and all only vary slightly. It should give you enough info to get you through what you want to know.
http://www.nordyne.com/literature/7103180.pdf
Posted on Apr 08, 2009
Heater blows cold air
This is from Lifewire: If your heater was blowing lukewarm instead of cold, a thermostat that was stuck open would have been a potential cause. Another common problem is when air gets into the cooling system. Since the heater core is often the high point in a cooling system, air can move into it and become trapped.
Try this site too: https://axleaddict.com/auto-repair/Why-Are-My-Car-Heaters-Blowing-Out-Cold-Air
Apr 18, 2017 | Cars & Trucks
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
No heat blowing cold air
Heater blowing cold air? - Nissan Forums : Nissan Forum
www.nissanclub.com/...nissan.../233563-heater-blowing-cold-air.html
Nov 5, 2006 - 15 posts - ‎6 authors
... it idle, all guages normal, heater on HOT and HIGH, it blows cool air. .... thatNissan put out for some reason (I have no idea where it went to, ...
How To Fix Your Car's Heater - YouTube
? 3:03
https://www.youtube.com/watch?v=bmmn4ON_t0c
Nov 26, 2009 - Uploaded by Scotty Kilmer
... Scotty Kilmer shows how to fix your car's heater for those coldwinter ... How to Diagnose and Fix No Heat Issues - Also a Demonstration on ...
maxima blowing cold air while idling - Maxima Forums
maxima.org/...maxima.../599527-maxima-blowing-cold-air-while-idling....
Sep 21, 2009 - hello everyone, i have a 2004 nissan maxima sl. when the car is warmed up and the car is idling the heater will blow cool air, but when i am driving. ...Not sure whats involved in a heater core for the Max, but I had to pull the ...
Jan 15, 2016 | Halonet 95-99 NISSAN MAXIMA / 96-99...
Heater blowing warm and cool air
Try flushing the cooling system. The heater core us probably clogged. A flush may clean it out. Good luck.
Nov 18, 2013 | 1994 Oldsmobile Ninety Eight Regency
Heater only blows cool air out of heater
Check coolant level. If necessary, additional cooling fluid. It is possible that the air inside the cooling system.
Oct 11, 2012 | 2006 Pontiac Grand Prix
Heater started blowing cool air? 07 titan 4x4 LE.
auto ac? check for a coolant leak low collant level will cause air pockets in cooling/heater system.
Mar 21, 2010 | 2007 Nissan Titan LE
Heater blow cool air at idle
try flushing the cooling system. sounds like the heater core may be all gumed up inside. could also be the water pump starting to fail.
Feb 05, 2010 | 2002 Nissan Maxima
2000 satin sl1 heater blows cold air, had the
my 2000 saturn sl blows cold air with the heater on. I changed the thermostat,and checked out my heater core.Still blows cold air.
Jan 17, 2010 | 2000 Saturn SL
Hot air blows but cools down in 15-20 seconds.
You likely have a restriction in the heater coolant hose circuit - perhaps a coolant control valve not fully opening, or a kinked hose.
Insufficient coolant volume is flowing to keep the heater core hot.
Try back flushing the heater core system with a garden hose to check flow.
Nov 13, 2009 | 2003 Audi A4 Cabriolet
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
