Question about Jandy Pool & Spa
Jandy AE-Ti model ae1500t with a message "shorted h20 sensor" appearing and unit not running.
Model AE1500T - Serial number q09aj0262 - not sure if covered by warranty.
    Top Expert:
  • Jandy Master
  • 5,061 Answers
Replace temp sensor mounted on side plumbing goes in with plastic black screw remove take out unplug and replace
Posted on May 28, 2015
JANDY EA2000T POOL HEATER H20 ALARM
shorted temp sensor replace
Apr 10, 2014 | Jandy Pool & Spa
Legacy Model Lrz heater code Shorted H20 Sensor
replace temp sensor it mounted on front of right side header the one with the plastic nut in it with 2 black wires
Aug 05, 2013 | Jandy Pool & Spa
Jandy ae heat pump
make sure wiring is correct for 220 volt or 115 volt and check fuses
Mar 20, 2013 | Jandy AE3000T AE-Ti Heat Pump 137K BTU
How do i fix H20 sensor on a jandy pool water heater AE-TI
remove the two black wires from the PCB board and remove the other part from the copper line going to the header where the pipes connect
Dec 28, 2012 | Jandy Ae2500t 115,000 Btu Heat Pump
Aqualink reads " water temp short " . Is this a
This code menad that the water temperature sensor has gone bad. These will cost around $60-80 retail, unless you buy Jandy OEM, then you will be paying well over a $100.00. But you can also use a Jandy, Goldline, or Pentair sensor and it is a fairly simple repair.
Pentairs Part Number: Model # : 520272 Hayward Gold Line: Model # : GLX-PC-12-KIT Jandy: Model # : 5089
Dec 07, 2010 | Jandy Aqualink Rs4 One Touch Control...
Jandy AE-TI H20 error message - pool not heating
just looked at the manual for this unit. It does not list an H20 code. Is this all it says on the screen?
Nov 13, 2010 | Jandy Ae2500t 115,000 Btu Heat Pump
Jandy AE.TI AE3000T .263 BOARD SHOW FAULT SHORTED H20 SENSOR
The H20 sensor is the Pressure Switch. Locate the pressure switch, remove the two leads and jump them together. If the error code goes away, you need a new switch. If not, it could be a software, or other hardware issue.
Jan 08, 2010 | Jandy Ae2500t 115,000 Btu Heat Pump
Pool & Spa Logo
89 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
