Question about Dynex Televison & Video
Dynex AV 480i SD problem with DVD player
The DVD player keeps poping up a window that states AV 480i SD not rated. Picture quality keeps flashing in and out; picture color keeps changing; screen scrolls. Also having same problem with Wii.
  • 236 Answers
SOURCE: Diagonal lines and ghost images
You may have a bad flyback transformer (high voltage trans former). The lines you're seeing are retrace lines caused by the picture tube screen set too high. This is often caused by the screen control opening up. This control is part of the flyback.
Stargazer
Posted on Feb 19, 2008
  • 979 Answers
SOURCE: Issue with 480i display
Possible decoder problem in the respective IC...accordianman
Posted on Oct 20, 2007
MNfisherman
  • 11896 Answers
SOURCE: Problems setting up DvD Play and Wii
TRY DIFFERENT CABLES OR USE DIFFERENT INPUTS. AND BY THE WAY, YOU CAN PLAY DVD'S IN YOUR WII
Posted on Apr 05, 2009
  • 476 Answers
SOURCE: Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Posted on Aug 03, 2009
  • 15 Answers
SOURCE: color went to black and white
You have it hooked up to Analog TV with your RCA jacks. I had the same problem.
Posted on Jul 23, 2010
Dynex 32" 720p Flat-Panel LCD HDTV - Matte Black Logo Print Email Problem with Dynex 32" 720p Flat-Panel LCD HDTV - Matte Black I have a Dynex Bluray Player and when I connect it with AV Cab
If the item is under warranty return it asp. The problem is in the power supply, the cause is a open capacitor sometimes leaving a bulge at the top.
Apr 25, 2012 | Olympus Televison & Video
What is the screen resolution to the sharp 32C540 ?
480i is the highest resolution of your tv. The tv has composite, s-video and component inputs in the back. The manual states that with component connections are dvd compatible allowing you to enjoy the highest quality image playback than using s-video. Dvd's resolution are 480i or 480p. I'm guessing it's more 480i than 480p since the tv is a crt tube tv and does not have any of the digital inputs for higher resolutions.
Jul 06, 2011 | Sharp 32C-540 32" TV
I know dvd player can not play Blu-ray but is not the Samsung dvd hd870 different. It reads 1080i.
That refers to the video output - your player is capable of upscaling: it transforms, without changing the quality of the image itself, the resolution from SD (480i) to HD (1080i).
Jan 28, 2011 | Samsung DVD-HD850 DVD Player
Dvd screen comes up on TV but dvd player says "disc error".
unplug the pwr cord from dvd for 5-10 min..plug back into outlet..make sure the av cable is connected white-white yellow-yellow red-red...now press play on the dvd
feel free to rate help
Jul 04, 2010 | Toshiba SD-2800 DVD Player
Upgrading DVD quality
Hi.
It displays 480i or 480p because that is the maximum resolution of a DVD. DVD cannot go over that limit.That is already improved to the max.
To get an higher resolution you need to use blue ray.
Apr 08, 2010 | Samsung HT-Q70 Home Theater System System
Sony 2006 40s2010
It very much depends on:
the model of DVD player you have and whether it is a standard or blu-ray player
the settings on the player
the type of connection (component and HDMI will yield a better picture)
Oct 19, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
HD channles
Hi Scan 1080: Enables you to receive the 1080i, 720p, 480p and 480i digital TV formats. By using the VIDEO 5/6 IN jacks, you can connect a DTV (digital television) receiver to view DTV programs. q DRC Multi-Function: Unlike conventional line doublers, the DRC feature doubles vertical and horizontal lines, resulting in four times the density for quality sources such as DVD, Satellite and Digital camcorder. q CineMotion: Using the 2-3 Pull-Down technology, the CineMotion feature allows you to obtain a smooth picture movement when playing back movies or other video sources on film. q Twin View: Using Multi-Image Driver (MID-X), Twin View allows you to watch two programs side by side with the ability to zoom in one picture and listen to selected window. You can watch pictures from two different sources (1080i, 720p, 480p or 480i) simultaneously. q 16:9 Enhancement: Vertical Compression technology that maximizes picture resolution on “anamorphic” or “enhanced for wide screen” sources, including selected DVDs. q Steady Sound: Equalizes volume levels so there is consistent output between programs and commercials. q Parental Control: V-Chip technology allows parents to block unsuitable programming for younger viewers. q Component Video Inputs: Offers the best video quality for DVD (480p, 480i) and Digital Set-top box (1080i, 720p, 480p, 480i) connections. q S-VIDEO Inputs: Provides a high-quality image for connected equipment. q Favorite Channel Preview: Preview up to eight favorite channels
Jun 02, 2008 | Sony KP-61HS20 TV
Component Cable
Are you just using the yellow cable at this point, because the quality would in fact be awful? Using the green, red & blue cables (component cables) would not improve quality much, seeing as the yellow video cable has a resolution of 480i and component cables are set at 480p. Your TV (if it is in fact high definition) would either run at 720p or 1080p depending on what the manual says and what the native resolution is. I would say try and buy and upconvert DVD player and make sure to get an HDMI cable to go from the DVD player to the HDTV (some DVD players come with this cable, but you'll have to look around for them, otherwise look on buy.com or something for some cheap ones). HDMI connection and the upconvert DVD player will improve picture quality significantly.
Apr 23, 2008 | Televison & Video
DVD picture flashes on & off
our problem was because the hdmi on reciever was not compatable with hdmi on dvd player, different versions ex. 1.2, 1.3 , 1.1
ended up using component inputs instead
Dec 16, 2007 | Toshiba SD-6000
Sep 15, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
