Question about HP Pavilion Slimline S3123W Desktop PC - REFURBISHED
It goes to sleep and won't wakeup
It turns on but i don't see anything on the screen and message comes up on the monitor saying ''going to sleep'' and no post. the monitor is not on vga mode it's on the other one.
  • Ben Wine May 11, 2010
    Do you have your power saver settings correct?
  • 63 Answers
I believe this model only comes with Vista. Go to Control Panel, and on the left hand side click Classic View then click the icon for Power Options.
There will be a few options under Preferred Plans and one is selected (Filled in dot)
Under the Power Plan that is selected, click Change Plan Settings and on the next screen, click Change Advanced Power Settings.
You will have a new window that opens up with a bunch of categories with little boxes with + signs. Click the + Sign box beside sleep to open op the menu. In the options under sleep, change HYBRID sleep and HIBERNATE to NEVER. Especially the Hybrid sleep as this was a problem I found with Vista. It sounds like the computer is going into the Hybrid/Hibernation and not comping out from it unless you power off the computer and turn it back on
Also, click the + sign beside Hard Disk and make sure the option to "Turn off Hard Disks After" is also set to NEVER
Posted on Jan 28, 2009
  • Ryan Stiers
    Ryan Stiers Feb 03, 2009
    Did this solve the issue?
Thanks for your input ... much obliged.... Richard
Posted on Apr 09, 2010
Monitor won,t wake up from sleep mode
Open monitor and look at power supply board for capacitors which are "balooning" or deformed in any way. These look like cylindars on the board. These tend to dry out and make what you are describing occur. Replacing them usually fixes about 80% of the problem you are describing. Those parts run about $0.25 to $0.75 each.. well worth trying, right?
Jan 20, 2014 | HP 2009M Monitor
When i turn my pc on, monitor boots up then goes to sleep and will not come back on
you can make your monitor didn't go sleep from screen saver window select advanced and change option to never
if you see that is helpful please don't forget to vote me
best regards
Apr 22, 2011 | Computers & Internet
Hi ,My dell screen goes to sleep mode after a long wait of not being used, say an hour, ..............but the pc sleep is not set ? The message comes up to move mouse ,or press any key ,but this does not...
please check your monitor settings may be sleep time is defined there. secondly check your system sleep time again. and also check window power saving mode. may be your system goes to power saving mode.
If you like this rate me kindly
Oct 12, 2010 | Dell E153FP 15" LCD Monitor
Monitor going to sleep upon Bootup.
Open your cpu cabinet.
refix your RAM memory .
Pull cmos cell for 10 minutes so all settigns are defaults.
Also remove PCI cards from PCI slot .
Then check.
Let me know if you need more assistanse.
Aug 31, 2009 | HP w1907 LCD Monitor
Blank screen after monitor sleep just blue flashing light
First of all you can change the Power Settings in Control Panel. You can configure as you need. I mean after how much wait it should go for sleep n all.
If it takes 5 min. to wakeup that means you have so many applications running that system cannot manage or RAM is small.
The final solution just remove the Display drivers and reinstall it.
After removing please restart the system once to proceed further
Aug 03, 2009 | HP Pavilion dv9000z Notebook
Screen shows message "no input signal" and monitor goes to sleep.
monitor show "no input singnal" error masage when not gating any type of video singnal ,
so if u realy check your monitor wires for correctty plugged in .
Two possibilities:
either the video/mainboard of the monitor is defective; or
the video card/ CPU is the faulty.
A way to verify is to try the PC with another monitor or to try the monitor in another PC.
Apr 30, 2009 | HP vp17 Monitor
Monitor willnot come out of sleep mode
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
Apr 10, 2009 | HP w1907 LCD Monitor
Monitor TFT 5015 now says "going to sleep
Make sure the laptop's external VGA port is turned on. There will be a function key somewhere on the keyboard (location varies by manufacturer and model) that controls the connector. If the connector has gotten turned off the external monitor will go to sleep because it's not getting any input.
Apr 09, 2009 | Compaq TFT5015 15" LCD Monitor
Monitor "Goes to sleep"
Have you tried to go in thru the control panel and select "display"? From here you can go to the screen saver section and adjust the time it takes for the screen to cut out. Of course you want to use a monitor that you can read before you set up both of your screens.. See if that helps....
Sep 20, 2008 | Compaq TFT5030 (Carbon, Silver) 15.1" LCD...
Going to Sleep
Due to the power surge, it is highly possible that the monitor was given a boot by your computer on it's way out.
This will short out a very small transistor inside the monitor on the video board and in turn, then monitor cannot see that there is a signal so goes to sleep.
If you get brave enough to venture inside the screen, then check near the cable input. The transistors are only around 3mm and have 3 legs (two one side and one in the middle on the other).
If you find anything like that burnt (get a magnifying glass) then replacing the board is the easiest option. Just don't be tempted to wipe the board before you look at everything very closely, you may wipe away the tiny bit of evidence you are looking for.
Hope it helps =)
Feb 12, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
HP Pavilion Slimline S3123W Desktop PC - REFURBISHED Logo
398 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
