Question about Whirlpool LSR6334LQ Top Load Washer
Whirlpool type 111 cp1915409 top loader
The water fills up but when it goes to spin it makes a grinding sound. I am not sure I can fix it or I have to call a service person. Thanks for your help. Martha
  • 5,911 Answers
A few things may cause a grinding noise during the spin cycle. If the washer fills normally, but when it starts to AGITATE or SPIN, it makes a noise, this is usually caused by a bad motor coupling, bad transmission, basket drive assembly, or drive motor that's starting to fail. I also wouldn't rule out the clutch. It's really hard to tell without being there to see and hear what it is doing. I would also hate to tell you to call a repairman, but it may be wise in this situation because, even if you DO know what the problem is, it may be beyond your capabilities to repair. I could give you step by step tips on how to replace the parts, but diagnosing the CORRECT one would be the challenge. I hope this helps you some. PS The likely suspect in this case would be the transmission. Not a guarantee, but a guess.
Posted on Jul 22, 2007
Whirlpool type 111-05 Top Loading
The electronic timer is worn and requires replacement, this would be a bulky metallic box located just behind the large setting knob.
Dec 22, 2013 | Washing Machines
My maytag hav2558aww wont turn on wash cycle
Possible that the grinding noise comes from the drum, irregular movement or broken paddles.
You can try and attempt only if equipped with a fundamental understanding of the working .
I shall give you some tips to this click 1..: Washing Machine
2. Replacing bearings
Jan 24, 2013 | Maytag HAV2558 Top Load Washer
Machine gets stuck between rinse ans spin and sits for a while then spins but wont stop, then **** from the in the machine or hose is on the clothes???? Any suggestions? Machine is a top loader smart drive...
You could try a hot load with epsom salts....this will clean out the machine....Make sure it is with hot water. It goes slow in between rinse and spin possibly because it is slow draining...clean out the pump. Also as it FILLS make sure the water runs in properly and not just trickle in making a hissing noise. Good luck. Tony the technician.
Apr 02, 2011 | Fisher and Paykel Washing Machines
My top loader Kenmore type 111 is working fine until it get to the spin cycle. It won't spin and it makes a really loud buzzing sound. like a weedwacker or something. Help!!!
verify that hot and cold water are not reversed and BOTH are turned on. Sounds like water is shut off. Water valves are noisy without water pressure.
Sep 06, 2010 | Kenmore 22642 Top Load Washer
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
Kenmore 111 stuck mid cycle with water in barrel
Try unplugging it for a hour - see if it clears..
Hope this helps !!
Jul 13, 2009 | Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
WHIRLPOOL TOP LOADER OVERFILLING WATER
While it is filling up try this. Unplug the washer from the wall, if the water still runs then you need to replace the mixing valve. If the water stops then take the screws out at the base of the console and flip the controls back. Look for the clear hose that goes to the water pressure switch and make sure that it is connected. If it is connected take it off the switch and blow through it to see that it is clear of any obstructions.
If this only overfills after the first ore second wash then you may have the slow drain and the drain hose is in the downspout too tight.
Possible items needed;
#1 mixing valve
#2 pressure switch
#3 plumber
Jan 20, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSR6334LQ Top Load Washer Logo
905 people viewed this question
Dan Webster
Dan Webster
Sal De
